Old Mar 16, 2012, 10:08 PM
dwatson is offline
Find More Posts by dwatson
Yosef Sailor
dwatson's Avatar
Singapore, Singapore
Joined Jul 2011
Little set back tonight. While working on little mans pinewood derby car, my seawind fell off the stand and landed on the concrete. Chipped the paint on the bow and stern and rails. I sanded it down, re-primed and sprayed as much white as I had left in the can. Instead of putting on my color tomorrow, I will be spraying more base white.
When will I get this done?
DW
dwatson is offline Find More Posts by dwatson
Old Mar 17, 2012, 02:08 PM
Boomer1 is offline
Find More Posts by Boomer1
Boomer1
Boomer1's Avatar
United States, CA, Temecula
Joined Sep 2009
DW
Ugh! That is a shame! Just glad there was no structural damages! Don't ya just hate when things like that happen!
Boomer
Boomer1 is offline Find More Posts by Boomer1
Old Mar 17, 2012, 09:18 PM
dwatson is offline
Yosef Sailor
dwatson's Avatar
Joined Jul 2011
Well.......
After I sanded, primed and repainted the boat, I got in a hurry and apparently did not let the white base fully dry before applying my vinyl logos and the 1st color down red. When I went back to apply a second coat of red, parts of hull looked mottled while other had a bright gloss to them. Not sure if it is a cure issue or capatibiltiy issue.
I used Duplo-color Acrylic Enamel sandable primer followed by Duplo-color Acrylic white as a base coat. Wet sanded, everything looked ok. Used alcohol to wipe down hull followed by tack cloth.
Next applied the Red, Duplo-Color auto match. I looked at the label and I hope it is Acrylic Enamel also. If not, that may explain the result.
Either way, I am traveling for a entire week starting tomorrow and I will order a new set of vinyls and upon return, sand down to bare hull and most likely try some Krylon this time.
I just down understand. It was looking so good also.
DW
Old Mar 27, 2012, 04:03 PM
stevezero is offline
Find More Posts by stevezero
Joined Aug 2009
sorry to hear about your luck. i think i stripped mine at least 2-3 times before it finally got its last color coat on it....3 races in, and it got more than a few chunks taken out of it.....now, the top of the hull has this nice, faded patina of what used to be flourescent orange. Just like a kayak or a regular boat, the first scratch is the hardest....after that, the stories that cause the scratches get alot more fun.
stevezero is offline Find More Posts by stevezero
Old May 06, 2012, 08:39 PM
dwatson is offline
Yosef Sailor
dwatson's Avatar
Joined Jul 2011
After much to do with my paint, I finally got the milkiness polished out of both the color and the clear.
According to Dupli Color, the milkiness is a result of the lacquer not fully flashing off. Over time, it dried to a haze that I was able to polish out and make glossy.
I installed the accessories and servos, trays, rudder steering wheels. I sails insalled on the mast and booms, I need to rig my lines and sails and finish the ballast off and paint it.
It is finally starting to look like a boat instead of project.
Will post photos later.
DW
Old May 13, 2012, 04:51 PM
dwatson is offline
Yosef Sailor
dwatson's Avatar
Joined Jul 2011
Final Paint Job
After many issues with paints, this is the final outcome.
I used white and clear Testers decal paper and printed the logos on it and cut them out with an xacto and applied them the hull.
I cleared the hull after application and used scratch remover and buffed to a shine using my drill and a buffing pad.
I sprayed the steering wheels and other accessories in a stainless and cleared them.
I am finishing up fairing my keel and bulb then will shoot it white and coat it.
DW
Old May 14, 2012, 01:35 AM
MILLERTIME is offline
Find More Posts by MILLERTIME
Taking care of the pond.
MILLERTIME's Avatar
United States, CA, Sanger
Joined Apr 2004
Looks great.
MILLERTIME is offline Find More Posts by MILLERTIME
Old May 15, 2012, 09:17 AM
Boomer1 is offline
Boomer1
Boomer1's Avatar
Joined Sep 2009
I agree. DW you have to be happy with the outcome. All that work has finally paid off!
Glad you hung in there! Looking forward to some fully assembled pictures and on the water shots.
Boomer
Build Log Seawind Build Threadů First RC Boat orthobill13 Sailboats 30 Feb 10, 2012 09:22 AM
Discussion Seawind with onboard camera video. ROLO1963 Sailboats 14 Sep 15, 2011 02:14 PM
Discussion HobbyKing Seawind 800mm sapok Waterplanes 0 Sep 06, 2011 11:50 AM
Build Log R2Hobbies Seawind build Dakrat Waterplanes 19 Jul 02, 2009 09:56 PM
Discussion Seawind - build drawing/scheme? richardmrazek Electric Plane Talk 1 Jan 16, 2009 02:38 PM
