Old Apr 02, 2012, 10:08 PM
NitroCharged is offline
Find More Posts by NitroCharged
Team30 Micro EDF
NitroCharged's Avatar
Adelaide, Australia
Joined Apr 2004
Users Sabre Manual.!
OK - here's revision 1 of the 'user manual', now called the "user's manual" as edited by us.
NitroCharged is offline Find More Posts by NitroCharged
Old Apr 02, 2012, 10:19 PM
livonia bob is offline
Find More Posts by livonia bob
Heli collector
livonia bob's Avatar
United States, MI, Livonia
Joined Apr 2009
Page 9 needs "light posts" added in things to be free of when choosing a flying site..
Other than that so far I can't believe the good job you are doing...
livonia bob is offline Find More Posts by livonia bob
Old Apr 02, 2012, 10:38 PM
giuseppi is offline
Find More Posts by giuseppi
CV-15 VB-16
giuseppi's Avatar
USA, TX, Friendswood
Joined Jul 2007
Officially replaced copy of manual with NC's New and Improved User's Manual.
Edit the warranty page. Make it a 5 Year Free Replacement Warranty and Guarantee Against Tree and Light Pole Damage.
JoshB,
You're welcome.
g
giuseppi is offline Find More Posts by giuseppi
Old Apr 02, 2012, 11:33 PM
Razors edge 29 is offline
Find More Posts by Razors edge 29
QuAd FaNaTiC
Razors edge 29's Avatar
Canada
Joined Aug 2009
Maybe there should be a page with common sense suggestions and basic flight skills
Lol
Razors edge 29 is offline Find More Posts by Razors edge 29
Old Apr 02, 2012, 11:44 PM
JoshB is offline
Find More Posts by JoshB
Novice in training
JoshB's Avatar
United States, NC, Statesville
Joined Aug 2011
giuseppi, I went online and almost ordered it, but remembered my F-86 will be here tomorrow from them and I think they usually send coupons. lol The weather is suppose to be pretty nice here tomorrow with 70's and lite wind, 3-5 mph so hopefully I can maiden her. Heres hoping. : )
JoshB is offline Find More Posts by JoshB
Old Apr 03, 2012, 03:46 PM
bushong572 is offline
Find More Posts by bushong572
United States, TX, Midland
Joined Apr 2012
Originally Posted by livonia bob View Post
Just a hair forward of the back edge of the little circle. Or right at the 70mm mark if you measured from the front of the wing at the fuselage on the bottom. Or at 63mm if you are measuring as told to do in the instructions. This was with the new 250mAh battery it comes with placed all the way forward...
Did you also have a dime under the 250 mah battery?
I just received my F86 (with the new 250 mah battery). If I push this all the way forward will the CG be right, or do I need to add a dime under the battery?
bushong572 is offline Find More Posts by bushong572
Old Apr 03, 2012, 04:32 PM
nurserob is offline
Find More Posts by nurserob
Joined Jun 2010
Has anyone had problems with the DX6i radio working with this plane?
None of the channels map up in either of the channel map modes with the any link receiver. I have no throttle on either of the 2 maps, one map if you use the elevator the ailerons also move. I am also getting tons of servo glitching when i plug the battery in. It seems to have been bound to the any link at the factory as it worked with the plane out of the box.
nurserob is offline Find More Posts by nurserob
Old Apr 03, 2012, 06:10 PM
GBR2 is offline
Find More Posts by GBR2
Stress Be Gone
GBR2's Avatar
Snohomish, WA
Joined May 2000
Did you read the Anylink instructions regarding channel mapping? If it isn't right you have to rebind in a certain way according to the manual.
GBR2 is offline Find More Posts by GBR2
Old Apr 03, 2012, 07:12 PM
nurserob is offline
Joined Jun 2010
Seems it defaulted to elevon mode. I took it out and it works great.
One question though,is it normal for the servos to be 'glitching' or buzzing all the time? These do.No amount of trim adjustment fixes it either.
Old Apr 03, 2012, 10:32 PM
fredmdbud is offline
Find More Posts by fredmdbud
fredmdbud's Avatar
USA, MD, Frederick
Joined Jan 2010
The buzzing is normal for digital micro servos.
fredmdbud is offline Find More Posts by fredmdbud
Old Apr 03, 2012, 11:00 PM
nurserob is offline
Joined Jun 2010
Thats good to hear. I have a micro Corsair and it has a hum,but these are really loud. Guess I will just have to get used to it.
Old Apr 03, 2012, 11:38 PM
Team30 Micro EDF
Adelaide, Australia
Joined Apr 2004
These servo's should NOT be buzzing. Which one is buzzing?
Old Apr 04, 2012, 12:26 AM
nurserob is offline
Joined Jun 2010
They all are,as soon as i hook the battery up,I hear the buzz/hum/glitching, whatever it is called.My mini corsair does it too but not quite as loud as the sabre.
Old Apr 04, 2012, 03:14 AM
JoshB is offline
Novice in training
JoshB's Avatar
Joined Aug 2011
Ok, got my F86 today and I have to say its a beauty. I can see where the vertical stabilizer is weak. It moves every time you move the rudder. The rx or something is making a bussing noise but I think it is just the servos humming a little. Don't think it will be a problem.
Now for an issue I can't seem to find an answer for. I checked the fail safe function and it dont work. If you cut the power to the Any Link the surfaces stay in whatever spot its in. The motor actually goes full bore. I didn't see anything in the F86 manual or the Any Link manual. Any ideas?
Old Apr 04, 2012, 01:55 PM
19000rpm is online now
Find More Posts by 19000rpm
Joined Aug 2009
I maidened it today. Nice little bird. Not too exciting, all stock, but it flew as advertised. Maybe 35mph. Is was hard to tell exactly because of the variable breeze.
Flown with a DX7 (not DX7s). The mapping had to be changed as per the Any Link instructions as did the reversing on the controls.
Stock battery and location held down with a bit of velcro. The velcro was the only thing I added. I left the pilot out for now.
I used the LG even though I hand launched it just to see how it handled the weight and air resistance. It did just fine.
I underhand launched it WOT (and kept it there for most of the flight) into a 5-10 variable breeze. It went straight as an arrow. Looped and rolled and looped and rolled. It was very stable considering the variable conditions. I detected no hint of either tail or nose heaviness using the 70mm CG.
What I found the most interesting was that it didn't need any trim it at all. Narry a click.
The only things I wished for was a symetrical airfoil and another 10-15mph. Those would be improvements, not neccessities, IMHO.
19000rpm is online now Find More Posts by 19000rpm
New Product Sabre Jet F86 30mm EDF by Great Planes..TX-Ready (TX-R)..or RTF Version 15'' WS modfly Micro Ready-to-Fly 151 Dec 20, 2012 08:20 PM
Sold Eflite F-86 Sabre BNF EDF Jet NEVER FLOWN ready to fly!!!! thutt3430 Aircraft - Electric - Jets (FS/W) 1 Apr 17, 2011 10:34 PM
