Old Feb 20, 2012, 10:49 PM
mithrandir is offline
Find More Posts by mithrandir
TEAM FUTABA TEAM DURALITE
mithrandir's Avatar
Joined Nov 2004
Awe CRAP!!!
I LOST my F-86 Saturday!!!!!
TOTAL Loss!!!
My son flew it and decided it is his.....
..... I haven't flown it since!!
he has since put 6 more flights on it....
mithrandir is offline Find More Posts by mithrandir
Old Feb 20, 2012, 10:53 PM
brushless55 is offline
Find More Posts by brushless55
big ignore list
brushless55's Avatar
United States, CO, Longmont
Joined Nov 2011
Originally Posted by glenn2626 View Post
For you folks with this plane, I now have a new adapter, by request from a customer.
This will let you use one of your existing 2S JST-male batteries with the GP Micro F-86.
JST-Female to minideans, with the positive line exposed. (I think this is backwards too, personally)
Available here:
http://www.rc-connectors.com/index.p...roducts_id=359
I will also have one soon for all your Parkzone/Horizon 2S batteries (Beast, Sbach, Mig-15, Stryker 180, etc)
Glenn
RC-Connectors.com
Better off cuting the jst connector off and putting a micro deans... we are trying to stay away from added weight, with our cg issues..
brushless55 is offline Find More Posts by brushless55
Old Feb 20, 2012, 11:31 PM
glenn2626 is offline
Find More Posts by glenn2626
RC Connectors dot com
glenn2626's Avatar
United States, CO, Colorado Springs
Obviously, for those that are willing and able to solder, that's best.
But I get lots of customers that are not comfortable with that.
Glenn
glenn2626 is offline Find More Posts by glenn2626
Latest blog entry: Horrible "MX" connector on...
Old Feb 21, 2012, 12:47 AM
big ignore list
Joined Nov 2011
Glenn
this jet could use a little wight savings and adding two jst connectors is not going to help, specially if it throws back the CG
really not sure what packs come with jst connectors that would even fit my F-86
think I need to get into the connector making business
Old Feb 21, 2012, 01:00 AM
mithrandir's Avatar
Joined Nov 2004
Awe why sweat it....
8 bucks a piece... just get a couple extra with the next tower order!
http://www3.towerhobbies.com/cgi-bin...?&I=LXZCD8&P=7
Old Feb 21, 2012, 01:22 AM
big ignore list
Joined Nov 2011
Bingo buddy!
cheap flying, and no heavy connector needed...
Old Feb 21, 2012, 01:37 AM
big ignore list
Joined Nov 2011
Ok, I'm so thankfull that we still have snow on the ground around here and I'm being a big sally and not flyin this Sabre!
cuz I need to add about 2.5g of weight to the front of this plane just to get to the 70mm cg
so what is and where is the best place to add the weight??
I was thinkin on the bottom of the nose of the plane... adding weight low I thought that would be the best??
anyone with good ideas here?
Old Feb 21, 2012, 01:49 AM
smasher41 is offline
Find More Posts by smasher41
United States, GA, Snellville
Joined Nov 2005
If you look in the back of the manual, there are larger 250mah 20c lipos listed as optional accessories, i am waiting on these to come instock instead.
smasher41 is offline Find More Posts by smasher41
Old Feb 21, 2012, 06:06 AM
jhark37 is offline
Find More Posts by jhark37
Flyr John in Floyd VA
United States, VA, Floyd
Joined Nov 2007
Batteries
TP 250's fit well.
John
jhark37 is offline Find More Posts by jhark37
Old Feb 21, 2012, 06:25 AM
RealGambler is offline
Find More Posts by RealGambler
Way to many airplanes!
Canada, QC
Joined Oct 2009
Originally Posted by livonia bob View Post
Well I have had tabs that I just couldn't solder too,, so now I just solder as short as it will take the solder and what ever is left I trim off. I don't trim first. The NanoTech tabs were already short and had solder on them so it was a easy thing to just solder my made up already charger plug and Deans assembly.. Takes longer to remove the plastic cap and hot glue then to solder on the new wires..
I was looking at the Hyperion 250's and it's going to be a lot harder to take the plastic caps off them as they use a lot more glue..
I made one pack of Hyperion 250. My conclusion was: it's not worth the trouble. Not because the plastic cap is harder to remove, but simply because the 240mah bare cells give pretty much the same result particularly because you're gaining a bit of weight with the 250mah for only 10mah more... When I was flying it, I found out that I didn't even bother changing my timer or flying an extra few seconds, so why bother with all the trouble. Save those batteries for the mCPx! Still not so sure about the 300mah Nanotech (price wise and trouble wise), but at least, with an extra 50mah, you can get longer flying time.
RealGambler is offline Find More Posts by RealGambler
Old Feb 21, 2012, 06:50 AM
xlrDALLAS is offline
Find More Posts by xlrDALLAS
Going broke, dam this hobby
xlrDALLAS's Avatar
cleveland oh
Joined Mar 2009
Im the one that asked for this adaptor , this plane needs weight up front so this will help, plus i have alot of batteries with jst plugs , and i cant change them so this works perfect for me
heres the batteries i use that come with jst,s
http://www.allerc.com/hyperion-g3-cx...ck-p-4501.html
xlrDALLAS is offline Find More Posts by xlrDALLAS
Old Feb 21, 2012, 08:43 AM
mithrandir's Avatar
Joined Nov 2004
I didn't feel mine.......
well.......
my son's needed nose weight.... what flying quality does
yours have that causes you to think it needs nose weight?
Old Feb 21, 2012, 09:25 AM
pdawg is online now
Find More Posts by pdawg
Need 4 Speed!
pdawg's Avatar
United States, OH, Dayton
Joined Apr 2004
well.......
In my case I checked the CG prior to the first flight and it was tail heavy according to the recommended location. A dime taped to the stock lipo resolved the cg position and the test flight was a no brainer unlike the experiences that some here have reported.
pdawg is online now Find More Posts by pdawg
Old Feb 21, 2012, 09:55 AM
big ignore list
Joined Nov 2011
Oh man, when I saw that I went straight to my manual!
GPMP0810 and I'm not seeing them up yet??
hope they come out
Good to know..
I'm going to make a connector to use my MCPx Lipos with this little bugger.. that way I can use all 4 different brands of lipos for my F-86
and I'v found a way to utilize the weight of the lipos to move them more forward
we need extra weight up front but that long wire and big over priced connector has the weight more back than forward like we need.. so it kinda hurts ya a little
But good luck though.. if you lived near by I'de make something up for ya that would be kick ass
Old Feb 21, 2012, 10:12 AM
Razors edge 29 is offline
Find More Posts by Razors edge 29
QuAd FaNaTiC
Razors edge 29's Avatar
Canada
Joined Aug 2009
Glenn
Its good to know that a professional like yourself thinks that the "industry standard" is backwards.
Available here:
Glenn
RC-Connectors.com
Razors edge 29 is offline Find More Posts by Razors edge 29
New Product Sabre Jet F86 30mm EDF by Great Planes..TX-Ready (TX-R)..or RTF Version 15'' WS modfly Micro Ready-to-Fly 151 Dec 20, 2012 08:20 PM
Sold Eflite F-86 Sabre BNF EDF Jet NEVER FLOWN ready to fly!!!! thutt3430 Aircraft - Electric - Jets (FS/W) 1 Apr 17, 2011 10:34 PM
