Old Feb 17, 2012, 08:24 PM
D Johnson is offline
Find More Posts by D Johnson
Just some guy
D Johnson's Avatar
Joined Aug 2006
The plane loves 240's
D Johnson is offline Find More Posts by D Johnson
Old Feb 17, 2012, 08:47 PM
brushless55 is offline
Find More Posts by brushless55
big ignore list
brushless55's Avatar
United States, CO, Longmont
Joined Nov 2011
Originally Posted by IndyMatt View Post
Yep bone stock lipo, hit the LVC because my timer didn't start on the TX. Probably try the hyperions tomorrow if the winds aren't howling.
ok, thank you
looks like you got about 2min 15sec before the LVC kicked in
brushless55 is offline Find More Posts by brushless55
Old Feb 17, 2012, 08:48 PM
IndyMatt is offline
Find More Posts by IndyMatt
Indianapolis, IN
Joined Oct 2010
It was windy (full throttle) and I was doing some testing before taking off. So take that into account.
IndyMatt is offline Find More Posts by IndyMatt
Old Feb 17, 2012, 08:49 PM
IndyMatt is offline
Indianapolis, IN
Joined Oct 2010
We will see tomorrow morning!
Old Feb 17, 2012, 09:04 PM
big ignore list
Joined Nov 2011
Yep, WOT LVC times is what I'm looking for...
Old Feb 17, 2012, 11:35 PM
smasher41 is online now
Find More Posts by smasher41
United States, GA, Snellville
Joined Nov 2005
Today I did 3:10 wot flight then setup for landing battery was warm and I think it was 3.7, probably would have settled at higher voltage when cool
Manage throttle a tiny bit and I can definately see 4 minute flights however I will be stepping up to 240-250mah lipos for this as I would like the bit of nose weight they provide
smasher41 is online now Find More Posts by smasher41
Old Feb 18, 2012, 12:01 AM
big ignore list
Joined Nov 2011
Yeah I could see 4min flights with managed throttle, like 50-75% the whole flight... but WOT is only going to give 3min tops on the stock battery..
Some are only getting low to mid 2min flights before the LVC kicks in
And 3 is long for a bird like this at WOT
I have two 230mah 25c lipos and got 5 more in the mail today!
So that's a total of 8 flights before any charging baby!
Old Feb 18, 2012, 12:17 AM
Joined Nov 2005
Mine was flying so good i just kept doing full speed circuts about 10-15 feet off the ground so the other guys at the field could see it.
I have well over 100 flights on jpower 50mm F86 and dozens more on 4 cell (77mph), So im pretty comfortable with the F-86 airframe. I feel its actually more stable then the larger Jpower since adding the 2 grams of nose weight, which will be traded for a larger lipo in the future
FYI i am not using the factory charger, but an Icharger 306b, so it may be charging a bit more ( reading 4.2 on each cell when done) than the stock chargers do. If this weekend turns out not flyable then I will charge the lipo with the stock charger and see what voltage it charges to.
what brand lipos are you guys using in these ? only small 2 cells i see available are the hyperion 240's and thunderpower 250's. Thinking about getting 2 of the hyperion UMX connector ones to use for my UMX stryker and use an adapter for the f86
Old Feb 18, 2012, 01:12 AM
auto_flyer is offline
Find More Posts by auto_flyer
auto_flyer's Avatar
United States, UT, Bountiful
Joined Sep 2007
Originally Posted by NitroCharged View Post
To top it off - the jet comes with the new AnyLinkô system allowing you to connect your own 2.4Ghz Txer and bind to the models Rxer in seconds.
http://www.youtube.com/watch?v=ht6j_Sw52_w
So, am I correct to think after watching this demo video that, like the parkzone micros, the RX is put into bind mode simply by powering it up before the transmitter? And then, the first transmitter to be powered up after the RX becomes bound to the RX? A clear explanation of how to bind an anylink TX to the micro RX would be appreciated. Thanks!
auto_flyer is offline Find More Posts by auto_flyer
Old Feb 18, 2012, 08:53 AM
IndyMatt is offline
Indianapolis, IN
Joined Oct 2010
That is how its done power plane power anylink done.
I am going to be using the hyperion umx cells with adaptor today.
Old Feb 18, 2012, 04:17 PM
Kevin Greene is online now
Find More Posts by Kevin Greene
United States, TN, Jackson
Joined Mar 2007
I'm happy to be able to say that the hobby shop that I deal with found a plane for me!!!...Looking forward to being in the GP Sabre click......
Kevin
Kevin Greene is online now Find More Posts by Kevin Greene
Old Feb 18, 2012, 04:37 PM
auto_flyer's Avatar
Joined Sep 2007
Awesome, thanks!
Old Feb 18, 2012, 06:07 PM
Just some guy
D Johnson's Avatar
Joined Aug 2006
Auto Flyer, once bound, always turn on your AnyLink first and shut off the plane before the anyLink. That way your plane will always stay bound to your AnyLink and not another Tactic Signal. Once bound, the receiver seeks the last TX it was bound to before binding to a different signal.
DJ
Old Feb 18, 2012, 06:22 PM
eltreato is offline
Find More Posts by eltreato
"Unappreciative tosser"
eltreato's Avatar
Canada, BC, Vancouver
Joined Oct 2011
Kevin
Congrats man. Definitely post your impressions when you get it. It's strange people are buying this thing off the shelves when the shop I "bought" mine from a month ago hasn't gotten it in yet!
eltreato is offline Find More Posts by eltreato
Old Feb 18, 2012, 06:35 PM
big ignore list
Joined Nov 2011
Not sure but I thought I would post this
I used a scale to get an idea of thrust from this little guy
I used the stock battery and some 230's I have
on the stock battery I got 47g at 50% throttle and at WOT I got 58g of thrust...
and on the 230's at 50% was 51g and WOT was 69g
and total weight with the 230mah was 64.4g
and the stock battery was 63.47g
New Product Sabre Jet F86 30mm EDF by Great Planes..TX-Ready (TX-R)..or RTF Version 15'' WS modfly Micro Ready-to-Fly 151 Dec 20, 2012 08:20 PM
Sold Eflite F-86 Sabre BNF EDF Jet NEVER FLOWN ready to fly!!!! thutt3430 Aircraft - Electric - Jets (FS/W) 1 Apr 17, 2011 10:34 PM
