Old Feb 13, 2013, 03:25 PM
pugsam is offline
Find More Posts by pugsam
LiPo-Sucker & Airframe EMT
pugsam's Avatar
Charlottesville, Virginia, USA
Joined Aug 2010
Originally Posted by bwoollia View Post
Problem with that is - elevator authority approaches zero at lower airspeeds.
Ah, thanks.....I'm starting to grasp the situation, and my mental fog is beginning to clear-up.......
pugsam is offline Find More Posts by pugsam
Old Feb 13, 2013, 04:00 PM
NitroCharged is offline
Find More Posts by NitroCharged
Team30 Micro EDF
NitroCharged's Avatar
Adelaide, Australia
Joined Apr 2004
If you're nosing up when hitting the power - you're nose heavy.
NitroCharged is offline Find More Posts by NitroCharged
Old Feb 20, 2013, 09:29 PM
Robert Belluomini is online now
Find More Posts by Robert Belluomini
EDF Jet Jam 2016, June 16 -19
Robert Belluomini's Avatar
United States, KY, Crestview Hills
Joined Dec 2000
laser cut battery cradle
I drew up this battery cradle to hold the battery securely in place. The tongue slips into the recess in the nose of the. model and the rear edge rests against the lip in front of the rx. The battery is glued into the cradle flush with the bottom.
Robert Belluomini is online now Find More Posts by Robert Belluomini
Old Feb 21, 2013, 12:14 PM
BadLemon is online now
Find More Posts by BadLemon
Just having fun before I die!
BadLemon's Avatar
DeKalb,IL
Joined Dec 2008
How I resolved my issue on shorting the power plug to the balance plug.
Here is an update on how I resolved my issue with shorting out the power plug to the balance plug. the other day I was hot gluing some wires to secure them and it came to me to use hot glue to seal the back of the connector on the balance plug. To me this will work great and it is a simple fix.
Originally Posted by BadLemon View Post
I have not been on this thread in a while so this problem I had may have been talked about so if it has I'm sorry about the duplicate post.
Yesterday the Weather was good enough to get a couple of flights in with my F-86 at a local park. I even took off with the F-86 sliding on the snow.
While at work today I was walking between buildings and put my hand in my pocket and found I put a battery in my pocket. I got a phone call on my cell while I was talking the battery started to get hot in my hand. I open my hand and quickly noticed the positive lead was stuck into the back of the negative lead of the balance plug! This created a dead short as you all know it would, I know this happen while I had the battery in my hand because it wasn't hot when I pulled the battery out of my pocket.
I know "I'm Stupid" it wasn't very smart to put the battery in my pocket in the first place so I'm very lucky the battery didn't short in my coat pocket while hung up in the closet. I'll said it again I'm Lucky for being stupid! I could be homeless right now or even worse I could of lost my family. I will never do this again I'm thinking a fix for this could be to make a protection cover for the micro dean connector or even change the connector to a JST female or something else. So I would like to know if others have foreseen this and what changes did you do.
Lastly I want to be clear on this matter I'm not blaming the manufacturer this was clearly my fault.
BadLemon is online now Find More Posts by BadLemon
Old Feb 21, 2013, 03:37 PM
Tyler83 is offline
Find More Posts by Tyler83
United States, TX, Katy
Joined Dec 2010
Anyone no of good place to shop for charger leads? I just recently bought my first real charger and would like to find a place that has one of those multi-lead deals with this plug on it
Tyler83 is offline Find More Posts by Tyler83
Old Feb 21, 2013, 04:11 PM
eltreato is offline
Find More Posts by eltreato
"Unappreciative tosser"
eltreato's Avatar
Canada, BC, Vancouver
Joined Oct 2011
You could try rc-connectors.com. If you can't find what you're looking for send them an email, they're good at getting back to you and can usually build to suit.
eltreato is offline Find More Posts by eltreato
Old Feb 21, 2013, 04:39 PM
BadLemon's Avatar
DeKalb,IL
Joined Dec 2008
commonsenserc.com
Old Feb 21, 2013, 04:57 PM
mckolit is offline
Find More Posts by mckolit
mckolit's Avatar
Southern California
Joined Apr 2007
epbuddy and progressiverc are two good places also.
mckolit is offline Find More Posts by mckolit
Old Feb 21, 2013, 07:12 PM
BadLemon's Avatar
DeKalb,IL
Joined Dec 2008
Bob
Your thrust diverter mod, did you loose any performance from it?
Old Feb 23, 2013, 07:19 PM
dgarbern is offline
Find More Posts by dgarbern
dgarbern's Avatar
North Wales, PA, USA
Joined Jan 2001
Hope this video is clear enough to show the degree of pitch control allowed by the mod I posted in #2179. Series of pull ups to vertical followed by quick pitch down to level or nose down. I would have liked to go slower but had to keep the speed up due to the steady wind. Good example at the 0:59 mark.
P1010137 MOV (2 min 23 sec)
dgarbern is offline Find More Posts by dgarbern
Old Mar 02, 2013, 12:33 PM
JonB is offline
Find More Posts by JonB
Gladstone, NJ. USA
Joined May 2000
Has anyone used the 6-Channel AS3X Sport Receiver
Hi Guy:
Has anyone adapted the 6-Channel AS3X Sport Receiver to the Eflite F86 Saber
Sincerely, Jon B in New Jersey
JonB is offline Find More Posts by JonB
Old Mar 02, 2013, 02:15 PM
Kevin Greene is offline
Find More Posts by Kevin Greene
United States, TN, Jackson
Joined Mar 2007
I've got a NIB Sabre and have experienced a little of the soft elevator at slow speeds with my two previous ones...I think on this newest one I'll glue on some Depron elevator extensions to get more elevator authority at slower speeds...
I have a 90mm NitroPlanes Sabre that has the same issue of running out of elevator at slow speeds---It's kind of unnerving when you have the stick buried all of the way back and you pray you have enough for the flare---The "fix" for the plane running out of elevator is to make extensions for the elevators...This has worked like a charm!!!
Here is a link to the 90mm Sabre thread to the page that shows what one modeller accomplished...The pics are on post #846..Read my post #845 for a description of my 90mm Sabre landings...
http://www.rcgroups.com/forums/showt...t=sabr&page=57
This method used on post #846 would be too heavy for this micro but you get the idea...A simple piece of Depron glued to the trailing edge as an extension would work fine....Work backward through the thread to read how this mod really helped this plane...
Kevin
Kevin Greene is offline Find More Posts by Kevin Greene
Old Mar 03, 2013, 06:49 AM
CorvetteC5 is offline
Find More Posts by CorvetteC5
CorvetteC5's Avatar
Kokomo, Indiana
Joined Jun 2008
Very interesting extension to the elevator. I have been thinking of this change, also, but wanted a few more flights on the GP F-86 before deciding to do it or not.
The example linked, had very little additional elevator. Any thoughts Kevin, on how much additional elevator depth would be correct for the micro F86: 3mm, 5mm, 7mm? Following the example, I might just construct the pieces out of clear plastic blister pack material and either tape or glue a single layer in place.
CorvetteC5 is offline Find More Posts by CorvetteC5
Old Mar 03, 2013, 08:00 AM
Joined Dec 2000
Bob
No not at all and the elevator maintains authority at slows speeds through touchdown too.
Old Mar 03, 2013, 05:00 PM
fairplane is online now
Find More Posts by fairplane
fairplane's Avatar
Canada, SK, Prince Albert
Joined Aug 2006
So would this mod make the elevator extensions unnecessary? So the diverter is placed with about 1/16th" of downthrust? Is this correct?
Simple effective mod
fairplane is online now Find More Posts by fairplane
New Product Sabre Jet F86 30mm EDF by Great Planes..TX-Ready (TX-R)..or RTF Version 15'' WS modfly Micro Ready-to-Fly 151 Dec 20, 2012 09:20 PM
Sold Eflite F-86 Sabre BNF EDF Jet NEVER FLOWN ready to fly!!!! thutt3430 Aircraft - Electric - Jets (FS/W) 1 Apr 17, 2011 11:34 PM
