Old Sep 24, 2012, 05:44 PM
eltreato is offline
Find More Posts by eltreato
"Unappreciative tosser"
eltreato's Avatar
Canada, BC, Vancouver
Joined Oct 2011
There we go, River Raid. If you squint the jet even looks like an F-86.
Kupfer, you must either have the best Vancouver secret spot ever, or live in the Valley somewhere to be able to run a Phazer at those speeds. Where do you fly that thing?
eltreato is offline Find More Posts by eltreato
Old Sep 24, 2012, 07:44 PM
super kupfer is offline
Find More Posts by super kupfer
Anything that gives me a High
super kupfer's Avatar
Canada, BC, Richmond
Joined Jan 2010
I actually live in Richmond (suburb of Vancouver), and yes I do have a secret spot in Richmond down around 8th. Road on a hay field (Owner just had it cut).
But Im a member of Ridge Flyers Club and I fly there regularly but I wouldnt fly the Phazer over there in this configuration.
super kupfer is offline Find More Posts by super kupfer
Old Sep 25, 2012, 10:28 PM
BadLemon is offline
Find More Posts by BadLemon
Just having fun before I die!
BadLemon's Avatar
DeKalb,IL
Joined Dec 2008
I remember River Raid you couldn't leave the river or you crashed into to ground..
BadLemon is offline Find More Posts by BadLemon
Old Sep 27, 2012, 07:57 PM
barmonkey is offline
Find More Posts by barmonkey
WHAT THE...
barmonkey's Avatar
Evansville, Indiana
Joined Jan 2005
Had the re-maiden of my squishy nose Sabre today...all went well...three batteries without mishap! It is a bit fast for my primary flying area although it is possible to get some full throttle fly-byes. I spent some time flying as slow as possible to learn the stall characteristics...and was flying comfortably below half throttle.
This makes me wonder about my failed maiden. I now think that instead of a stall, I experienced a radio black-out. What lead me to the conclusion is while setting up my Nieuport it quit responding. I jiggled the Easy-Link plug and it began to function properly. I will definitely recheck the plug BEFORE EVERY FLIGHT!
I also wanted to mention that I am flying without landing gear and have two dimes crammed in the void just ahead of the battery. The plane flew great...and I didn't even need to adjust the trims.
barmonkey is offline Find More Posts by barmonkey
Old Sep 27, 2012, 08:23 PM
3d astronaut is offline
Find More Posts by 3d astronaut
3d astronaut's Avatar
United States, MI, Kalamazoo
Joined Sep 2011
Guys does anyone have a spare wing/tail set? Theres a nice gentleman looking for one in the want ads.
3d astronaut is offline Find More Posts by 3d astronaut
Old Sep 28, 2012, 07:43 PM
GBLynden is offline
Find More Posts by GBLynden
I am GBLynden
GBLynden's Avatar
United States, WA, Lynden
Joined Mar 2011
So I was just looking at Tower Hobbies and I don't see how to get the Anylink System free, though the jet is much cheaper now.
Does anyone have a code or anything to share?
GB
GBLynden is offline Find More Posts by GBLynden
Old Sep 29, 2012, 04:55 PM
Mike20 is offline
Find More Posts by Mike20
Mike20's Avatar
Joined Sep 2012
It should say it at the top I just ordered mine as well and I didn't see it until I looked at the top of the page. Try adding t to your cart and then go into your cart and it should have the plane and then the any link underneath for 0.00.
Mike20 is offline Find More Posts by Mike20
Old Sep 29, 2012, 04:58 PM
Mike20 is offline
Mike20's Avatar
Joined Sep 2012
Has anyone put an orange Rx (I think it's an r415) in there sabre with a 3s battery? Does the orange Rx just pnp? I really don't want to hassle with the any link system and I rather just use my dx6i.
Old Sep 29, 2012, 06:30 PM
NitroCharged is offline
Find More Posts by NitroCharged
Team30 Micro EDF
NitroCharged's Avatar
Adelaide, Australia
Joined Apr 2004
I replaced my stock rxer with a stripped down AR6100 and soldered the leads directly to the board to save weight.
NitroCharged is offline Find More Posts by NitroCharged
Old Sep 29, 2012, 07:34 PM
Mike20 is offline
Mike20's Avatar
Joined Sep 2012
Great videos by the way Nitro. So you mean the battery leads right? And what do you mean by stripped down?
Old Sep 29, 2012, 08:08 PM
Team30 Micro EDF
Adelaide, Australia
Joined Apr 2004
I removed all the extra things not needed on the rxer. I soldered every servo lead on - cut the plugs and soldered the wire to the board.
Old Sep 29, 2012, 09:34 PM
Mike20 is offline
Mike20's Avatar
Joined Sep 2012
Oh ok I don't think I'm able to solder things that small. I can see taking the case off but are the servo wires able to plug into the board without being in the way if I left the plugs on and just plugged them in the normal way?
Old Sep 30, 2012, 05:05 AM
GBLynden is offline
I am GBLynden
GBLynden's Avatar
Joined Mar 2011
Thank you!
Old Sep 30, 2012, 11:24 PM
trroadster is offline
Find More Posts by trroadster
trroadster's Avatar
Canada, AB, Edmonton
Joined Oct 2006
ANybody know what the esc to rx connector is and where I can get some? I want to run two F-86 fans in a scratch built and need to build a y adaptor.
trroadster is offline Find More Posts by trroadster
Old Sep 30, 2012, 11:59 PM
giuseppi is offline
Find More Posts by giuseppi
CV-15 VB-16
giuseppi's Avatar
USA, TX, Friendswood
Joined Jul 2007
Check post #76 of this thread.
g
giuseppi is offline Find More Posts by giuseppi
New Product Sabre Jet F86 30mm EDF by Great Planes..TX-Ready (TX-R)..or RTF Version 15'' WS modfly Micro Ready-to-Fly 151 Dec 20, 2012 08:20 PM
Sold Eflite F-86 Sabre BNF EDF Jet NEVER FLOWN ready to fly!!!! thutt3430 Aircraft - Electric - Jets (FS/W) 1 Apr 17, 2011 10:34 PM
