Old Sep 16, 2012, 08:56 AM
electricrc68 is offline
Find More Posts by electricrc68
The Sweet Aroma of Fuel
electricrc68's Avatar
United States, PA, Downingtown
Joined May 2011
Originally Posted by NitroCharged View Post
Not long. It's a small lipo and going to 3S sucks the juice.
Going back here, would you say the flight times are around 3-4 minutes?
electricrc68 is offline Find More Posts by electricrc68
Old Sep 16, 2012, 04:58 PM
NitroCharged is offline
Find More Posts by NitroCharged
Team30 Micro EDF
NitroCharged's Avatar
Adelaide, Australia
Joined Apr 2004
No, full throttle and you'd get around 2 minutes on the 180.
NitroCharged is offline Find More Posts by NitroCharged
Old Sep 16, 2012, 05:27 PM
Joined May 2011
Oh okay thanks. Guess im going to just use 2s in there.
Old Sep 17, 2012, 03:31 PM
super kupfer is offline
Find More Posts by super kupfer
Anything that gives me a High
super kupfer's Avatar
Canada, BC, Richmond
Joined Jan 2010
Question: two of my friends just purchased sabers, while flying they experienced signal interference but only on the throttle between themselves, they both fly JR, did anybody have/had this phenomenal happen to them?
super kupfer is offline Find More Posts by super kupfer
Old Sep 17, 2012, 03:47 PM
livonia bob is offline
Find More Posts by livonia bob
Heli collector
livonia bob's Avatar
United States, MI, Livonia
Joined Apr 2009
Must be a common problem as this is the third time I have read about it on three different threads.. In the past two minutes..
livonia bob is offline Find More Posts by livonia bob
Old Sep 17, 2012, 08:47 PM
3d astronaut is offline
Find More Posts by 3d astronaut
3d astronaut's Avatar
United States, MI, Kalamazoo
Joined Sep 2011
Were they using the "Anylink"???
3d astronaut is offline Find More Posts by 3d astronaut
Old Sep 22, 2012, 09:26 AM
Joined May 2011
Hey guys. Are the stock 2s 250mah 20c batteries that come with the F86 sabre good for the plane, or is there another 2s battery i should look into for the F86 which will give me more flight time and performance? (don't have the plane yet, just doing some research first).
Old Sep 22, 2012, 07:41 PM
Team30 Micro EDF
Adelaide, Australia
Joined Apr 2004
The 250's balance the jet out without having to add weight. The model was designed to carry them, so they are ideal to use. They give good flight time.
Others are using slightly larger lipo's like 300mah size but you have to make sure it's balanced. A small error in CG will upset tiny models a lot.
Old Sep 22, 2012, 07:49 PM
Heli collector
Joined Apr 2009
I have flown mine with Nano-Tech 300 and some 400's.. The extra weight makes doing scale like landings hard as it doesn't like to flare.. If you are flying without the wheels and landing on high grass then this isn't much of a problem..
But the 250's seem to be the perfect battery weigh wise..
Old Sep 22, 2012, 08:44 PM
pghosh is offline
Find More Posts by pghosh
Joined Apr 2012
Have flown Zippy 350s. About as big as you can get.
Also tried one of these noname batters. I like it. Maybe slightly smaller than the zippy but heavier than stock 250. Would say I get about 5-6 min flying time, maybe more without pushing it.
http://www.ebay.com/itm/Li-Po-Batter...311#vi-content
pghosh is offline Find More Posts by pghosh
Old Sep 22, 2012, 08:52 PM
pghosh is offline
Joined Apr 2012
Re: What to do with F-86 electronics & EDF?
Have a fairly well worn F-86 and was thinking of putting the and EDF into something else. Has anyone tried to build anything with the stock F-86 electronics?
This Techone Mini F-35 seems like it might be a good candidate. Has anyone tried?
http://www.44ghz.com/techone-mini-f35/#!prettyPhoto[ajax]/6/
Old Sep 22, 2012, 09:45 PM
Team30 Micro EDF
Adelaide, Australia
Joined Apr 2004
I tried it on a 27mm about 3 years ago.
Team30 Micro EDF F-35 with Turnigy 10mm inrunner (1 min 52 sec)
Old Sep 22, 2012, 09:53 PM
Razors edge 29 is offline
Find More Posts by Razors edge 29
QuAd FaNaTiC
Razors edge 29's Avatar
Canada
Joined Aug 2009
No Mylar
Staples didn't have anything
Only think I could find was at craft store and its like overhead clear sheet but too thick and heavy.
So
Will have to look elsewhere dagnabit
Razors edge 29 is offline Find More Posts by Razors edge 29
Old Sep 22, 2012, 11:47 PM
jcdfrd is offline
Find More Posts by jcdfrd
3DHOG
jcdfrd's Avatar
USA, CA, Aromas
Joined Sep 2010
I thought guys were adding a dime to the battery with the stock 250's to get better cg? I ordered some turnigy 1s 350 cells and made my own packs.....so 2s 350mah 20c and they came out 3 grams heavier than the stock 250 and it balances and fits perfect
jcdfrd is offline Find More Posts by jcdfrd
Old Sep 23, 2012, 12:07 AM
Team30 Micro EDF
Adelaide, Australia
Joined Apr 2004
No, it's the first batch of jets that came with a 200mah lipo that needed the dime under the lipo.
New Product Sabre Jet F86 30mm EDF by Great Planes..TX-Ready (TX-R)..or RTF Version 15'' WS modfly Micro Ready-to-Fly 151 Dec 20, 2012 08:20 PM
Sold Eflite F-86 Sabre BNF EDF Jet NEVER FLOWN ready to fly!!!! thutt3430 Aircraft - Electric - Jets (FS/W) 1 Apr 17, 2011 10:34 PM
