Old Jan 14, 2012, 03:37 PM
village_idiot is offline
Find More Posts by village_idiot
Inciting Riots
village_idiot's Avatar
Joined Dec 2006
Tower has prices and so does Todd's, tower doesn't mention the free Anylink module with purchase of a plane, but Todd's does. I'm thinking about it.
village_idiot is offline Find More Posts by village_idiot
Old Jan 14, 2012, 05:12 PM
Chompers is offline
Find More Posts by Chompers
Figure 9 Expert
Chompers's Avatar
USA
Joined Feb 2007
This looks amazing. 1 the plane looks awesome. 2 its an actual EDF. 3 Did i mention that its an EDF?
Plus the anylink receiver removes the original barrier that has kept me in the Horizon Hobby camp since I've started RC, being locked in with a proprietary RC protocol. Although the idea behind anylink isn't anything new, I believe you've been able to purchase futuba modules for years, its perfect. I don't think i'll have a problem sticking a module to the back of my beloved Dx-7.
One question i do have, that i am unsure anyone can answer just yet, is will this system allow the use of separate model memories for each anylink aircraft?
Alright, now some money. I don't really need those textbooks for classes right?
Philip
Chompers is offline Find More Posts by Chompers
Old Jan 14, 2012, 05:37 PM
Inciting Riots
Joined Dec 2006
This is the first system that comes with trainer connections, there are a couple of systems that come as "universal" but this is the first (outside of Plantraco) that is designed to connect to the trainer for use and supplies the connections you need. It's a great idea for receiver ready models and is also a reason why I've avoided some of these types of planes. Only thing that bugs me is I just got an email back saying the Anylink does not work with surface transmitters, was thinking of the 3 channel surface receiver for a vehicle.
Also it is obvious you've been brainwashed by the Spektrum integrated radios where each model has a model match... This is a module, you can fly models on the wrong memory setting. This also means you can have as many receivers bound to the system and as many different model memories as you want, you can even have different model memories on different radios for the same model. It's very flexible just like the other module based systems, but the downside is you better make sure to check the controls to make sure you are on the correct memory before flying. Same as the old days on FM/PCM.
Old Jan 14, 2012, 06:37 PM
Chompers is offline
Figure 9 Expert
Chompers's Avatar
USA
Joined Feb 2007
That is all fine and dandy but i really do not care about model match or only one receiver per model memory. I am quite capable of checking which model I am using before i take to the air. I was simply inquiring as to weather the system allowed the user to use different memories for separate models. Seeing as this is a 'new' technology, there are things that have not been officially addressed by the manufacture.
I appreciate your input, but in the future you may want to change your posting style so you don't get dinged for personal attacks.
-Philip
dieter88 is offline
Find More Posts by dieter88
Hobbico Employee
Champaign, IL
Joined Sep 2006
AnyLink will talk to the 3-channel Tactic Rx that is used for surface models. The protocol is the same as that used for air.
One thing to note that probably created the confusion is this - you MUST have a trainer port for AnyLink to be used. I don't know of many surface radios that offer a trainer port.
-chris
dieter88 is offline Find More Posts by dieter88
Old Jan 14, 2012, 08:01 PM
Inciting Riots
Joined Dec 2006
Chompers,
You missed the point... the transmitter module doesn't care what model memory you have chosen, you could have a million different model memories with the same number of different models and in theory the same number of receivers. The RF system doesn't care what you do or have set in the radio. All it cares about is that you are sending it PPM pulses and sending them in the correct order (or telling it which pulse corresponds to which function). This is pretty much standard for all the "external" modules.
And I don't really appreciate the snotty response and veiled threat when I was trying to help you understand how these systems all work. Go ahead and report me, we'll let the mods sort it out.
Chris,
Thanks. I was thinking I would just grab the PPM from the regular module pins on my 3PKS surface radio. The three channel receiver might make a decent parkflyer receiver once the plastic is removed to make it lighter. It also has a DSC connection which is one of the specs. listed for Anylink. It would just make another use out of this system to help justify the cost. For airplanes I use a Microstar2000 based TX, would be easy to make a dedicated connection for the Anylink since it only needs three connections (power, ground, PPM).
Old Jan 14, 2012, 09:36 PM
Cheese5 is offline
Find More Posts by Cheese5
Cheese5's Avatar
United States, CA
Joined Jul 2010
How good is the tactic radio system? As solid as DSM2 or DSMx?
Cheese5 is offline Find More Posts by Cheese5
Old Jan 14, 2012, 10:07 PM
dieter88 is offline
Hobbico Employee
Champaign, IL
Joined Sep 2006
I don't know much more than it is a frequency-hopping system but I do know this; I have used numerous Tactic 2.4 radios is a wide variety of environments with great success. Big events like SEFF, JR Indoor, and E-Fest as well as in some surface stuff and I never had any trouble.
Old Jan 14, 2012, 11:03 PM
KCinNC is online now
Find More Posts by KCinNC
that's gonna leave a scar
United States, NC, Mooresville
Joined Aug 2007
i've actually have been looking for a micro edf !!! hate i gotta wait till March
KCinNC is online now Find More Posts by KCinNC
Old Jan 14, 2012, 11:10 PM
Razors edge 29 is online now
Find More Posts by Razors edge 29
QuAd FaNaTiC
Razors edge 29's Avatar
Canada
Joined Aug 2009
I hope these are priced well cause I definateky want one
Razors edge 29 is online now Find More Posts by Razors edge 29
Old Jan 14, 2012, 11:27 PM
MRGTX is offline
Find More Posts by MRGTX
MRGTX's Avatar
United States, CT
Joined Aug 2005
Coool. Looks awesome!
But ANOTHER F-86?
MRGTX is offline Find More Posts by MRGTX
Old Jan 15, 2012, 05:20 AM
ncsky is offline
Find More Posts by ncsky
Maggie is in charge
ncsky's Avatar
United States, NC, Raleigh
Joined Nov 2011
Everyone better get the money ready it says Late January availability
http://www3.towerhobbies.com/cgi-bin...?&I=LXBVVD&P=7
ncsky is offline Find More Posts by ncsky
Old Jan 15, 2012, 07:46 AM
flypaper 2 is offline
Find More Posts by flypaper 2
I use foam to hold my hotglue
flypaper 2's Avatar
Kingston, Canada
Joined Jun 2004
Don't know the big putdown with the HK Sabre if you've neve flown one. Same size. Throw their micro rcvr and a batt in and chuck it. Excellent little flier.
flypaper 2 is offline Find More Posts by flypaper 2
Old Jan 15, 2012, 11:00 AM
modfly is offline
Find More Posts by modfly
Doing it in the Lateral Axis
modfly's Avatar
USA, OH, Akron
Joined Dec 2006
Tower price of $139.00. No mention as to if the any link comes with it for that price at the tower site...this price is for the TX-r version.
I like that Tower now takes Paypal.
http://api.viglink.com/api/click?for...13266469084373
modfly is offline Find More Posts by modfly
Old Jan 15, 2012, 11:34 AM
PepeM is offline
Find More Posts by PepeM
Joined May 2011
Looks very nice and finally a micro edf from a reputable company. Extremely tempting offer.
PepeM is offline Find More Posts by PepeM
Build Log 8'' Micro Jet (L-39 Albatros, MiniDisc, 30mm EDF) Chris T Scratchbuilt Indoor and Micro Models 333 Nov 22, 2012 04:01 AM
Discussion Axon Micro F4 Phantom II 30mm/40mm EDF Jet metroidrc Micro EDF Jets and Power Systems 544 May 15, 2011 03:03 PM
Sold Axon F-4 fantom 30mm edf jet tc3wins Aircraft - Electric - Jets (FS/W) 1 Mar 21, 2010 09:27 AM
Sold 2DOGRC's Axon Micro 14" F4 Phantom EDF Jet and 30mm fan and motor rccrazee Aircraft - Electric - Jets (FS/W) 3 Feb 19, 2010 07:28 PM
