Old Jan 13, 2012, 03:30 PM
modfly is offline
Find More Posts by modfly
Doing it in the Lateral Axis
modfly's Avatar
USA, OH, Akron
Joined Dec 2006
New Product
Sabre Jet F86 30mm EDF by Great Planes..TX-Ready (TX-R)..or RTF Version 15'' WS
This looks interesting..http://www.greatplanes.com/airplanes/gpma1771.html
This looks like a must have! I think you may be able to use a DX-6 with a module thats available. I hope so because I have 2 DX-6 TX and would like to get some more use of them.
This looks like a game changer plane to me.
11,500kV brushless inrunner motor
30 mm HyperFlow™ ducted fan unit
6A brushless ESC
4-channel 2.4GHz SLT™ micro receiver
(3) digital ultra-micro servos
7.4V LiPo flight battery
Balancing DC LiPo battery charger
The F-86 Sabre arrives fully assembled and ready for flight. A battery and charger are included — and everything else is installed.
GPMA1771
Wingspan: 15 in (381 mm)
Wing Area: 53.1 in² (3.4 dm²)
Weight: 2.35 oz (67 g)
Wing Loading: 6.4 oz/ft² (20 g/dm²)
Length: 14.4 in (366 mm)
Requires: AnyLink and compatible 4-channel transmitter or Tactic™ 2.4GHz radio with SLT™
All Tx-R models include:
Powerful motor and ESC
2.4GHz receiver with SLT
Servos
LiPo flight battery and charger
This plane will also be available as a RTF!
Click VIDEO in this link...
http://www.tx-ready.com/txr-airplanes.html#sabreanchor
modfly is offline Find More Posts by modfly
Old Jan 13, 2012, 03:38 PM
electricrc68 is offline
Find More Posts by electricrc68
The Sweet Aroma of Fuel
electricrc68's Avatar
United States, PA, Downingtown
Joined May 2011
whoa. when is it supposed to be available?
electricrc68 is offline Find More Posts by electricrc68
Old Jan 13, 2012, 04:09 PM
joshuajcrouch is offline
Find More Posts by joshuajcrouch
United States, OR, Eugene
Joined Feb 2011
That looks like a fun plane...
joshuajcrouch is offline Find More Posts by joshuajcrouch
Old Jan 13, 2012, 04:51 PM
modfly is offline
modfly's Avatar
USA, OH, Akron
Joined Dec 2006
Looks like this will be available in March. Gives me some time to come up with some money as I will defiantly be getting one of these.
Only mod that I will do is steering nose wheel. I did it to the original UM Cessna and will do the same to this as well.
Here is the UM Cessna steering nose wheel mod video from a few years back
steering mod cessna (0 min 24 sec)
I still have the Cessna and have never had a problem with it despite numerous flights and ROG action. Here is a video of it in the Hanger under going taxi tests
cessna floor test (0 min 24 sec)
Old Jan 13, 2012, 04:53 PM
nitro_star is offline
Find More Posts by nitro_star
Weekend Hacker
Australia, QLD, Brisbane
Joined Sep 2009
i wonder if the beast batt's will be enough for this? i know rc-connectors.com have a adaptor so it could be on the cards. looks like a nice lil plane, vids dont show to much though.
nitro_star is offline Find More Posts by nitro_star
Old Jan 13, 2012, 05:26 PM
Joined May 2011
modfly- nice modification to that cessna! in march you say? hmm...thats the month of my birthday....too bad i don't have enough experience for this plane yet though.
Old Jan 13, 2012, 05:46 PM
modfly is offline
modfly's Avatar
USA, OH, Akron
Joined Dec 2006
I would think it would be along the lines of difficulty like the UM Mustang or Sukhoi. It does have Rudder, Ailerons, elevator, throttle so 4 channel experience is a must. UM 4 channel experience would be a big + as well. There really is no Hobby Grade UM EDF planes that I know of so this will be the first! Its a break through model and is the most exciting 4 ch UM plane to come out yet IMO.
Of course I really like EDF planes.. check this video of a Starmax FA\18 EDF plane that I fly at the mall...
StarMax F/A-18 (4 min 27 sec)
Old Jan 13, 2012, 05:59 PM
Weekend Hacker
Joined Sep 2009
what about the 35mm edf's from hobbyking? Are they not hobby grade?
Old Jan 13, 2012, 06:39 PM
modfly is offline
modfly's Avatar
USA, OH, Akron
Joined Dec 2006
Well, they are not 30mm and they are not BNF or TX ready. They would be HG (after you install all the HG components!) I think they made a mistake when they made them from EPO foam which is heavy and has (bumpy texture or big bead texture). I don't think EPO foam and UM scale planes are a good combination. The HK planes look interesting but are basically ARF and you must supply the rx, lipo, balance charger, assembly, setup time which includes CG balancing, lipo, RX mount and placement etc! Also the 2 HK 35mm planes I saw are twins and I don't like twin EDF for a couple of reasons..battery life and weight being the major problem then couple that with heavy EPO foam...
If the HK planes came BNF or TX-R and had a little smaller Fan then yea they would be in the same class but I can't help but think there is a reason they are at HK. Generally, HK planes are not high end or high Q planes but are a cheaper alternative in most cases but like I said the HK planes are 35mm and that is just not the same. A few years ago there were few members in the 30mm EDF club..35mm is not allowed in that club and is a different category as far as I can tell.
In the FA\18 Video I posted, The plane has a single EDF fan and motor even though the real plane has twin engines. Trust me when I say you do not want a twin EDF plane and especially a UM twin EDF! They require a very high Q lipo with a high "C" rating. The added weight of the extra engine and ESC, larger lipo, wiring offsets any real power gain in most cases. When it comes to EDF, even a few gram can affect performance and flight time. EPO foam in a EDF? Forget about it!
Looks to me like Electrifly considererd all these factors with the F85 Sabre. Should be a decent performer. And its all setup and ready to go with matched componats and a radio system that can work with most any 2.4ghz TX out there including the DX-6!
TX-R
Spektrum® DX6/6i, Dx7...These are some of the TX that are compatible with the Sabre rx.( a plug in module is required) Plugs into the trainer port of most TX. List price is around $25 for the module.
Old Jan 13, 2012, 07:48 PM
Joined May 2011
Of course I really like EDF planes.. check this video of a Starmax FA\18 EDF plane that I fly at the mall...http://www.youtube.com/watch?v=lFr2D...VR6au43SIog3-v
cool flying! my only 4 channel experience so far is the t-28 so im going to hold off for a little.
Old Jan 13, 2012, 08:14 PM
Cheese5 is offline
Find More Posts by Cheese5
Cheese5's Avatar
United States, CA
Joined Jul 2010
Looking forward to this one.
Cheese5 is offline Find More Posts by Cheese5
Old Jan 13, 2012, 08:15 PM
Machy2k is offline
Find More Posts by Machy2k
Machy2k's Avatar
Ft Lauderdale, FL.
Joined Jan 2007
That Sabre jet by Great Planes is very cool, when do get to hear the price and the price for the Anylink??
Machy2k is offline Find More Posts by Machy2k
Old Jan 13, 2012, 08:47 PM
D Johnson is offline
Find More Posts by D Johnson
Just some guy
D Johnson's Avatar
Joined Aug 2006
Anylink is free with the purchase of the model. List price is $24.95
D Johnson is offline Find More Posts by D Johnson
Old Jan 13, 2012, 08:48 PM
pattypilot is offline
Find More Posts by pattypilot
No dear, That isn't New!
pattypilot's Avatar
United States, IL, Urbana
Joined Nov 2006
Now that is one neat little bird! and a true EDF!!! Wow. I especially like this gizmo, “anylink”? Now I can fly my DR 1 and my new F86 with my full size Transmitter! Now were talking.
Jim
pattypilot is offline Find More Posts by pattypilot
Old Jan 14, 2012, 01:16 AM
eltreato is offline
Find More Posts by eltreato
"Unappreciative tosser"
eltreato's Avatar
Canada, BC, Vancouver
Joined Oct 2011
This thing looks great! I love the Tx-R idea too, I'll be watching this one.
eltreato is offline Find More Posts by eltreato
Build Log 8'' Micro Jet (L-39 Albatros, MiniDisc, 30mm EDF) Chris T Scratchbuilt Indoor and Micro Models 333 Nov 22, 2012 04:01 AM
Discussion Axon Micro F4 Phantom II 30mm/40mm EDF Jet metroidrc Micro EDF Jets and Power Systems 544 May 15, 2011 03:03 PM
Sold Axon F-4 fantom 30mm edf jet tc3wins Aircraft - Electric - Jets (FS/W) 1 Mar 21, 2010 09:27 AM
Sold 2DOGRC's Axon Micro 14" F4 Phantom EDF Jet and 30mm fan and motor rccrazee Aircraft - Electric - Jets (FS/W) 3 Feb 19, 2010 07:28 PM
