By the way freechip, don't use that Velcro that is supplied with the AnyLink. That stuff is so strong and tight I think I could pick up my pick-up with it.
Use something else you have around that is much more user friendly. You WILL want to take the AnyLink off when not using it. Ron |
Thanks, ya has for the velcro, my LHS buddy showed me how strong it was. LOL not going to be using it for this application.
Got it hooked up to my DX6i for now. Can't wait to start ordering some of those anylink planes. |
Latest blog entry: Get Help by posting your SPM File
Madison Wisconsin
Joined Feb 2007
Wonderfull Idea
Wes |
USA - NC
Mine arrived last week. I am trying to make it work with a JR 11X. The elevator and rudder work fine but there is no response from the throttle. I've tried all the switches and slides. Nothing on the transmitter activates the throttle. I am not good with programming. Any help is appreciated.
Lance |
Make sure you are arming the throttle. Go to full the motor should beep or spin for a split sec. Then go back to idle and it should beep or spin twice and hen be armed. If you don't do this you will not get any throttle response.
Latest blog entry: WATTS over Owatonna
United States, FL, Orange Park
Joined Oct 2006
Hitec Optima
I've had the Super Cub for a week or so,it came w/interlink. I ordered the TACM0004 adapter from Tower. It arrived couple days ago,and is nothing more than two servo connectors, I assume one plugs into the data port on my transmitter. Any way nothing happens, no led lite no response whatsoever. I ordered two receivers at same time from Tower but are back ordered. I have read everything I can find to no avail, anyone solve this problem? BL
I should probably read the rest of this thread b4 posting this but.....I have a DX5e tx and an old JR400 sport tx. The anylink does not work on the 5 without the right cable which my LHS does not have. But the old 400tx lights up the anylink just fine. The Problem..the sticks are completely reversed! Throttle and rudder are on the right stickwith ailerons and elevator on the left stick. I understand from the online info that you can changed modes with the throttle stick, but that's not possible if the throttle is assigned to a sprung elevator stick. This is on the new F86 edf jet from GP. I have had this thing since they first came out and have not been able to fly it. I was thinking about purchasing a rtf hobbico plane just to fly it with the cheap TX. Or at least change modes. Any one else have this problem?
Even with the channel mapping not set for JR I was still able to change the mapping settings with my 9303. I just followed the directions and used the throttle on my TX to enter the programming mode.
Did you just use the elevator to change the settings, or did you try the throttle as well? |
I tried both! The throttle was non responsive. I was able to arm he esc by holding down the elevator gymbal but as soon as it was armed the esc kicked on and i had to hold it (spring loaded) in the off position while unplugging the battery. So how should I accomplish this? Perhaps i should get someone who has a tx that works first. I'm just not ready to buy a computer TX just yet.
Okay, I just read the instructions again. Programming the Anylink has nothing to do with your throttle. Its based on rudder input. I think all major brands map rudder to channel 4. This is most likely why Tactic chose the rudder for the programming process. If your JR400 has the rudder channel mapped to 4 you can program the Anylink with it.
| Thread Tools | |
| For Sale WTT: Tactic 2.4 Tx&Rx for a speckrum Tx | superfastwrx | Aircraft - General - Radio Equipment (FS/W) | 2 | Dec 11, 2011 03:19 PM |
| Sold Parkzone TX and Ember Fuse with Brick + Motor | TF824 | Aircraft - Electric - Micro & Indoor Airplanes | 1 | Nov 06, 2011 05:15 PM |
| Sold New Tactic TTX404 2.4ghz 4ch tx & Tactic TR624 6ch rx | HyperHelis | Aircraft - General - Radio Equipment (FS/W) | 0 | Aug 21, 2011 08:11 AM |
| Sold Spektrum DX8 TX w/ manuals etc. new in box | PatternFlyer | Aircraft - General - Radio Equipment (FS/W) | 2 | Aug 15, 2011 10:41 PM |
| Sold Spektrum DX7 Air TX (charger/manual/ etc) new in box | PatternFlyer | Aircraft - General - Radio Equipment (FS/W) | 3 | Mar 10, 2011 09:37 AM |
