Old Feb 24, 2012, 10:03 AM
A Rdnek is offline
Find More Posts by A Rdnek
Bruno, GOOD DOG
A Rdnek's Avatar
United States, IA, Grinnell
Joined Aug 2007
Originally Posted by jj604 View Post
Ron, just for info, the mix method works with the Spektrum (and HobbyKing Super Micro) bricks as well.
Note the small print however. Rudder trim stays on the original rudder channel. Had me fooled the first time when I was madly trying to trim out a turn tendency with the right hand trim and nothing happened.
That DX8 thread is a classic for the strongly opinionated and under-informed.
I had one guy on my ignore list and one day on the DX8 thread I had a whole scrollable screen with nothing but one line "This message is hidden because NAME is on your ignore list." messages. He must have posted about 30 opinions in a row!
It's what makes the forums fun but I have no idea how Andy Kunz puts up with most of it.
I have always used a aileron to rudder mix on all my 3 channel micros so I could use the rudder stick for ground handling on the gym floor. It was just a preference, not really needed.
I was just surprised to find that it was absolutely necessary to use the mix to make the AnyLink work, and there is nothing about needing it in the instructions.
I Have used mixes on most of my planes since it has became available, as a flying "aid". My first was a Futaba Super 7 around 1990. But I think this is the first system I have ever used that "REQUIRED" a mix to operate, even on a simple 3 channel aircraft, and there is not even a mention of it in the manual.
Oh well, the fun continues.
Andy must be a saint, I don't think I have seen anyone take the abuse he does and still comes back to help people. I sure hope he has not become the dead horse.
Thanks for the reply,
Ron
A Rdnek is offline Find More Posts by A Rdnek
Old Feb 24, 2012, 02:12 PM
cr8tive_leo is offline
Find More Posts by cr8tive_leo
cr8tive_leo's Avatar
Canada, ON, Cochrane District
Joined Oct 2011
Originally Posted by gulio View Post
Would you post the required mods to do this? I can't find a thread describing it. Hope it is something that I can do. I don't care about cost really. Two things that are important to me are to run on the existing radio's power and to use only the original power switch, Is this possible?
http://9xforums.com/forum/viewtopic.php?f=25&t=408
how to for 9x transmitters.
You keep your trainer port so you can Buddy box with it.
You keep the power switch, it turns on/off with transmitter power and you can still remove the anylink if you wish. It's about 15mins worth of work and you cannibalize only one servo lead for this project.
cr8tive_leo is offline Find More Posts by cr8tive_leo
Old Feb 24, 2012, 04:50 PM
jj604 is offline
Find More Posts by jj604
ancora imparo
jj604's Avatar
Melbourne, Australia
Joined Jul 2005
Ah, good point, thanks. I don't think I was very clear.
AFAIK you will require a mix whenever both conditions are met:
1) Channels cannot be re-assigned on the transmitter
AND
2) The mechanical function is locked to a particular channel (as on a brick where the servo is hard wired to a particular channel and cannot be changed).
The bricks are the only ones I have come across that cause this issue since the throttle and servos are hard wired to specific channels and you can't change them by swapping the plugs around.
One of my transmitters broadcasts throttle on 4 and rudder on 3 and another does it the other way round! It requires quite complex mixing with one to get throttle to work on a brick without the rudder stick affecting it.
John
Originally Posted by A Rdnek View Post
IBut I think this is the first system I have ever used that "REQUIRED" a mix to operate, even on a simple 3 channel aircraft, and there is not even a mention of it in the manual
jj604 is offline Find More Posts by jj604
Old Feb 24, 2012, 08:28 PM
Digital Don is offline
Find More Posts by Digital Don
Digital Don's Avatar
United States, IL, Manteno
Joined Dec 2006
Apparently my grey matter has slipped back into gear!
I was fiddling with mixes again last night and came up with the one shown below. I thought the second number would have to be negative since I want down elevator when the throttle is moved up. That is apparently not the case because this combination works.
I won't be able to try it until next Tuesday, and I'll probably have to adjust the values, but at least I know I'm on the right track.
I was starting to get worried. They say when you get old like me, the SECOND thing to go is the memory...
I can't remember the FIRST!
Don
Digital Don is offline Find More Posts by Digital Don
Old Feb 24, 2012, 08:40 PM
A Rdnek is offline
Bruno, GOOD DOG
A Rdnek's Avatar
Joined Aug 2007
I was fiddling with mixes again last night and found the one shown below. I thought the second number would have to be negative since I want down elevator when the throttle is moved up. That is apparently not the case because this combination works.
Don
Don: Did the info you got from the fellow over at the DX8 thread help any?
Ron
Old Feb 24, 2012, 08:45 PM
Joined Dec 2006
Hi Ron,
One guy did reply, but with general information. I had already come up with the settings in my post above by the time I read it though.
I'll find out next week how it actually works in flight, but the general idea is correct.
Don
Old Feb 26, 2012, 08:09 PM
Lucky Dog is offline
Find More Posts by Lucky Dog
Lucky Dog's Avatar
Joined Jun 2006
Has anyone tried their Anylink set-up with earlier generation Flyzone UMs? I was under the impression it was backwards compatible. However, a guy at Hobbytown USA told me some people that had tried were having range issues, so I decided to hold off. I've got a Dr1, two Albis and a Playmate and it would certainly be nice if it did.
Lucky Dog is offline Find More Posts by Lucky Dog
Old Feb 26, 2012, 08:48 PM
IAMAN is offline
Find More Posts by IAMAN
Madison Ms
Joined Aug 2002
Originally Posted by amitysanimal View Post
I want one of these for my Hitec Optic6 but the cable won't be available until mid march. How hard would it be to make one up? I have a din plug from an old Futaba radio but have no idea what wires would have to go where.
Did anyone ever give an answer for this? I'm in the same boat. Need someone to tell me how to make a cable for Optic 6 with round 6 pin DIN plug.
IAMAN is offline Find More Posts by IAMAN
Old Feb 26, 2012, 09:42 PM
coriolan is offline
Find More Posts by coriolan
"Unnecessary Necessity"
coriolan's Avatar
Canada
Joined Sep 2006
The DIN socket for Futaba/Hitec is explained here(Fig 3-01):
http://users.belgacom.net/TX2TX/tx2t...h/tx2txgb3.htm
Contact pin configuration viewed on female plug mating face :
1 = +V batteries (SWITCHED)
Shield = GROUND
2 = OUT
3 = IN
4 = +V (for some transmitters only). Connecting pin 4 and 5 to each other on some transmitters will stop the HF-transmission and thus the transmiiter will not send out any signal (this is the case for 9ZAP/9ZHP, probably also for the FF8/8UAP and FF7/7UAP, NOT for the Robbe/Futaba F16-FC16-FC18, for the FC28 I don't know)
6 = +5v on certain transmitters only (9ZAP/9ZHP, probably FF8/8UAP and FF7/7UAP) and is used by DSC-cable.
Having a jumper between pin 4&5 disable the RF section also on Hitec Optic6 & Eclipse7
http://static.rcgroups.net/forums/at...inkadaptor.jpg
coriolan is offline Find More Posts by coriolan
Old Feb 26, 2012, 09:48 PM
Eclipse_7 is offline
Find More Posts by Eclipse_7
Eclipse_7's Avatar
United States, TX, Houston
Joined Nov 2003
Same problem here, I bought a JR 9303 as a workaround till they stock a $3 part.
Eclipse_7 is offline Find More Posts by Eclipse_7
Old Feb 26, 2012, 10:39 PM
Joined Dec 2006
I remember reading only FlyZone micros that came with a "Tactic" transmitter will work with the AnyLInk. And, those with the older FXT-324 do not work at all.
Don
Old Feb 27, 2012, 12:14 AM
A Rdnek is offline
Bruno, GOOD DOG
A Rdnek's Avatar
Joined Aug 2007
I went and looked at those HobbyKing Super Micro bricks. Too bad they aren't Spektrum compatible. They seem to produce modules for other brands but no mention of Spektrum.
Ron
Old Feb 27, 2012, 02:36 AM
jj604 is offline
ancora imparo
jj604's Avatar
Joined Jul 2005
Sure they do.
The HK SuperMicro modules work with a Spektrum Tx by using a satellite receiver from one of the Spektrum or HK Orange Receivers (<$12 from HK). The satellite receiver (after binding to your transmitter) plugs into the front of the module and you add a flight pack battery. The Spektrum Tx sends the commands to the satellite receiver which routes them into the HobbyKing transmitter module for final transmission to the airborne unit. Bit messier but a neat way round the DSM2 compatibility problem and it means you need nothing attached to your transmitter which is nice. The satellite, battery and SuperMicro Tx module can be anywhere in radio range. It's all covered in the HobbyKing Super Micro thread here.
http://www.rcgroups.com/forums/showt...462072&page=44
Ron
Old Feb 27, 2012, 09:04 AM
A Rdnek is offline
Bruno, GOOD DOG
A Rdnek's Avatar
Joined Aug 2007
Sure they do.
OK, I think I follow that, I am off to that thread right now. THANKS
Ron
Old Mar 01, 2012, 09:05 AM
freechip is offline
Find More Posts by freechip
freechip's Avatar
Joined Aug 2008
Just got mine yesterday and order the DX8 cable and of course after ordering it I get point to this thread. LOL
Oh well.. The cable isn't costing me much.
freechip is offline Find More Posts by freechip
For Sale WTT: Tactic 2.4 Tx&Rx for a speckrum Tx superfastwrx Aircraft - General - Radio Equipment (FS/W) 2 Dec 11, 2011 03:19 PM
Sold Parkzone TX and Ember Fuse with Brick + Motor TF824 Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 1 Nov 06, 2011 05:15 PM
Sold New Tactic TTX404 2.4ghz 4ch tx & Tactic TR624 6ch rx HyperHelis Aircraft - General - Radio Equipment (FS/W) 0 Aug 21, 2011 08:11 AM
Sold Spektrum DX8 TX w/ manuals etc. new in box PatternFlyer Aircraft - General - Radio Equipment (FS/W) 2 Aug 15, 2011 10:41 PM
Sold Spektrum DX7 Air TX (charger/manual/ etc) new in box PatternFlyer Aircraft - General - Radio Equipment (FS/W) 3 Mar 10, 2011 09:37 AM
