This thread is privately moderated by peterangus, who may elect to delete unwanted replies.
Old Jan 13, 2012, 11:39 AM
peterangus is offline
Find More Posts by peterangus
peterangus's Avatar
Blackpool, Great Britain (UK)
Joined Dec 2003
Overall propulsion efficiency deduced from test flight data
BLOG 006
The model was fitted with EagleTree logger V2. Parameters recorded were: altitude,,,,rpm,,,,battery volts and amps,,,,airspeed.
The flight was planned to incorporate a period of unpowered shallow glide, and a period of powered level flight, both at the same airspeed.
The efficiency calculation is based on the proposition that drag x airspeed is the same for the glide and for the level flight, and that it is equal to the power provided by gravity during the glide [=model weight times descent rate]
Overall propulsive efficiency worked out at about 20%.
Name: test graph.jpg
Description: Graph of flight data. date 18 Sept 2005.
Description:
Description: Test model
peterangus is offline Find More Posts by peterangus
Discussion how to test motor efficiency? Buzzkill2 Power Systems 21 Apr 23, 2014 12:06 PM
Discussion Photos, Test Flight/Test Flight, Photos? Mode One The Builders Workshop 15 Dec 19, 2011 10:16 AM
Discussion Camera Anti Vib Mount -test flight (Dampers from CD ) guyg Aerial Photography 1 Mar 12, 2011 04:30 PM
Discussion A Goldmine of Motor Test Data from Dr Kiwi hoppy Power Systems 9 Jun 03, 2007 04:33 PM
Thrust from RPM - Test stand data for APC E series propellors Dr Kiwi Power Systems 185 Dec 16, 2006 11:32 PM
