Old Jan 13, 2012, 11:33 AM
Joined Nov 2011
Quadcopter won't start
Hi everyone,
I just finished assembling my first quadcopter, using the hobbyking control board (2.1).
I tested every motor by itself to check if they all span in the right way, then I plugged everything into the board, the battery to the ESCs, and all ESCs sang at the same time that little melody who gave me hope that everything was going to work, but when I increase the throttle nothing happens
What did I do wrong?
ninijnab is offline Find More Posts by ninijnab
Old Jan 13, 2012, 11:41 AM
BlackCat_'s Avatar
United States, WI, Wausau
Joined Sep 2011
Did you arm the board? (Rudder stick right, throttle at minimum for a couple of seconds.)
BlackCat_ is offline Find More Posts by BlackCat_
Mmmmmmm!
WiseDuck's Avatar
Kingdom of Sweden, Dalarna County, Sater
Joined Oct 2011
You probably have to arm the board. Throttle down, full rudder to the right.
EDIT: Darn, beat me to it.
WiseDuck is offline Find More Posts by WiseDuck
Old Jan 13, 2012, 11:42 AM
United Kingdom
Joined Nov 2008
*Most* copter software requires it to be armed.
Did you try arming it ?
<edit> beaten to it
Originally Posted by ninijnab View Post
Hi everyone,
Mike Barton is offline Find More Posts by Mike Barton
Old Jan 13, 2012, 11:45 AM
Joined Nov 2011
I tried but nothing happens...
I have a mode 1 controller (throttle and ailerons on right stick), maybe I'm doing it wrong ?
When I plug the battery the LED flashes once and then shuts off...
Old Jan 13, 2012, 12:08 PM
Mmmmmmm!
WiseDuck's Avatar
Joined Oct 2011
Maybe you've reversed the throttle. Also, make sure the end points are set to 100%. Also, you could try to trim the throttle down a bit just in case you're not in the "arm zone". Not sure what else to say at this point.
Old Jan 13, 2012, 02:54 PM
Joined Nov 2011
Well I "cleared" the model on my Tx ans now it works ! it was probably a trim or EPA setting...
Thanks !
Old Jan 13, 2012, 02:59 PM
KAMAX-T's Avatar
Powell TN
try choking it.....lol
KAMAX-T is offline Find More Posts by KAMAX-T
Discussion my board won't start the motor windfou Hoverfly Technologies 8 Dec 03, 2011 11:32 PM
Discussion Pershing won't start up. PhilaKnight RC Tanks 0 Nov 08, 2011 08:47 AM
Discussion Motor Won't Start With Prop Attached mcav8tr Power Systems 17 Aug 19, 2011 06:46 PM
Discussion Out runner won't start... clicks and shakes MiddleMarc Electric Plane Talk 3 Jun 23, 2011 01:00 PM
Help! Align T-rex 450 SE V2: Why won't you start?! dylantorquerol Mini Helis 2 Apr 19, 2011 11:24 PM
