Old Dec 06, 2012, 06:29 AM
iceaxe is online now
Find More Posts by iceaxe
iceaxe's Avatar
Joined Dec 2006
I used the 20-60 size and didn't use the bracket as it was slightly different but purely because I could make the existing one work would not have been hard to adapt the dubro but was easier to use the stock one
Ill take her out sat morn so can let you know but I like the set up much stronger than stock
iceaxe is online now Find More Posts by iceaxe
Old Dec 06, 2012, 09:16 AM
acesimmer is offline
Find More Posts by acesimmer
acesimmer's Avatar
United States, NV, Fernley
Joined Oct 2011
How many people feel that they would like a cowl? I'm going to be doing a composite version of this and could always knock out the cowl mold in a day. I could use mine for the plug. You can see my T28 cowl that I made here on my build thread.
http://www.rcgroups.com/forums/showt...1767143&page=6
acesimmer is offline Find More Posts by acesimmer
Old Dec 06, 2012, 11:06 AM
bushpilotx1 is offline
Find More Posts by bushpilotx1
WITCH HUNTER EXTRAORDINAIRE
USA, FL, Boca Raton
Joined Feb 2001
Now were talking ....... Ill take at least 1 or 2 THANKS FOR STEPPING UP TO THE PLATE..........
bushpilotx1 is offline Find More Posts by bushpilotx1
Old Dec 06, 2012, 02:41 PM
pasantia is offline
Find More Posts by pasantia
United States, IA, Fort Madison
Joined Jan 2009
replacing aileron servo
what would be the best way to remove aileron servo for repalcement?
pasantia is offline Find More Posts by pasantia
Old Dec 06, 2012, 02:46 PM
mrbump is online now
Find More Posts by mrbump
upside down and inside out
mrbump's Avatar
Switzerland, ZH, Winterthur
Joined May 2012
@pasantia: Use pliers and pull on the servo arm. Gentle jolt and they come out. You can always ask your dentist for help...
mrbump is online now Find More Posts by mrbump
Old Dec 06, 2012, 03:33 PM
iceaxe's Avatar
Joined Dec 2006
Ill put my name down for two
Old Dec 06, 2012, 06:27 PM
pullup! is offline
Find More Posts by pullup!
HellBentPuppet
pullup!'s Avatar
Co.
Joined Jan 2005
Looks real good! I'm in!
Got 3 more flights in today on the Sbach. Continue to up the aileron throws, and I will start to play with a little mixing.
Rattled the upper foam cover off the landing gear and decided I need to glue the tail feathers (main wings already done).
Very pleased with it so far.
pullup! is offline Find More Posts by pullup!
Old Dec 06, 2012, 09:24 PM
pasantia is offline
Joined Jan 2009
thank you
Old Dec 07, 2012, 01:22 PM
RCAV8T0R is offline
Find More Posts by RCAV8T0R
Feeding the RC Addiction
RCAV8T0R's Avatar
United States, CA, San Diego
Joined Apr 2011
Slowly But Surely...
Originally Posted by RCAV8T0R View Post
Can't seem to find an suitable replace anywhere so she's grounded until these hard-to-find & poorly designed parts come back in stock...
...making progress with this bird getting her flight ready again...
Good news is by chance I found a replacement prop adapter that lines up perfectly with motor hole pattern that I had lying around in the hangar...
Bad news is (I think) the spare prop adapter came from the now extinct Exceed Monster Motor series, meaning it's NLA from HobbyPartz...
It has the same hole pattern, the same shaft diameter but the shaft length is a bit shorter & it's not machined (drilled out) to accept the stock spinner cone fixing screw. For now, I'm going to use an aftermarket Great Planes 2-1/2", black plastic spinner that has the aluminum back plate until I can get a 2-3/4" one that HobbyKing has. Also, this new-found adapter spaces out the GP spinner back plate nicely, giving a 2mm - 3mm gap between the spinner & stock cowling at the tightest point. That was just dumb luck but I'll take it...
I had to take the motor & mount off since it started making a loud clicking noise when I spun it around by hand & I could feel the knock. I took it apart, filed down some high spots or "burrs" on the magnets & now the knocking stopped. Checked all the fasteners & thread-locked all the metal to metal connections during reassembly. While the motor was off I did notice that my Sbach has the Topfire 80A ESC installed. Seems it's hit or miss with either a 70A or 80A rating that's in there depending on when or where you purchased this ship...
It was a bear removing the cowling for the first time, though. Not only was it screwed on, it also had a thin bead of glue around it that really didn't want to let go. Thought I was going to either crush it badly or bust that foam into pieces pulling it off. Luckily, I coaxed it off without it sustaining any damage...
Just about got her back together. She's a little more worse for wear as I've been banging her around the hangar a lot lately so she's developed a good case of hangar rash. Hopefully, she'll be airworthy again for this weekend's trip to the flying field. Keep ya posted...
RCAV8T0R is offline Find More Posts by RCAV8T0R
Old Dec 07, 2012, 06:42 PM
USA, FL, Boca Raton
Joined Feb 2001
For those that will find the motor mounting screws loose, the way to fix it, is going to Home Depot and getting some 6/32 brass inserts , 4/40/ may be available. Predrilled with a smaller bit then just screw them into the ply firewall with a little epoxy, be sure to put some vaseline in the interior threads to avoid any problems with epoxy seeping to the interior. This will make a much more solid connection. You can add some EPDM or neoprene washers to lesser the vibration.
This way the motor wont get loose.
Regarding the cowl mounting points you can do the same and just use some small nylon screws, On some occacions I have used a small piece of a hardwood dowel inserted into to the foam with some Gorilla glue. and either use a brass insert or just a screw.
I am planing to change the tail wheel and this is the way I will be attaching the mounting screws to the frame.
Old Dec 08, 2012, 05:12 PM
ryanbe15 is offline
Find More Posts by ryanbe15
ryanbe15's Avatar
United States, MD, Bethesda
Joined Sep 2012
Went to fly today. Did some trimming with a 3s battery while the 4s's charged. Once the 4s's charged, pulled one off and plugged it into the ESC. POOOOOOOF. ESC went up in smoke. Good thing i purchased 2 Cascle 100 amp ESC's when they were on sale.
ryanbe15 is offline Find More Posts by ryanbe15
Old Dec 08, 2012, 07:19 PM
iceaxe's Avatar
Joined Dec 2006
Damn lucky
On the other hand I put the esc out of my first one into my fms corsair which has now had over 100 flights on it
My first sbach had all its electrics replaced with eflite esc motor and savox digital mg servos which I retired after 180 hard flights so I thought I'd test the stock electrics on my second one and so far after 18 hard flights all is perfect which is a surprise
The only additions toy new sbach are 14/7 prop and dubro tail wheel
Old Dec 08, 2012, 07:24 PM
pullup! is offline
HellBentPuppet
pullup!'s Avatar
Co.
Joined Jan 2005
Rough luck man!
At least it was on the ground!
How long did you have it plugged in on the bench?
Old Dec 08, 2012, 08:59 PM
RCAV8T0R is offline
RCAV8T0R's Avatar
Joined Apr 2011
Primed & Ready To Go...
Well, got her prepped for flying...again... Worked the "kinks" out of the motor, got the prop & spinner back on & she's purring like a kitten now!!! What a relief... Thought I was going to have to replace the motor but I don't think so anymore. Gone is that wicked vibration that felt like she was going to shake herself into pieces. No vibration at all throughout the throttle range. Very satisfied & I'm glad I kept after it since it's really paid off in the end...
Got some preflight shots of this long-standing shop fixture of a beast to show the Sbach fans here. She's now setup with a balanced EMP 14x7E prop, some type of aftermarket prop adapter that's all topped off with a Great Planes 2-1/2" spinner. Also did a much needed air cooling mod by tunneling from the front of the foam firewall into the battery bay using my one-of-a-kind, custom-made Rockstar Energy foam tunneling tool...
All that's left to do now is to head out to the field for some real time flight testing. Can't wait for tomorrow morning...
Old Dec 09, 2012, 05:07 PM
queadlunnrau is offline
Find More Posts by queadlunnrau
Luck is my skill
queadlunnrau's Avatar
United States, WA, Seattle
Joined Jun 2009
HOw much would they run?
queadlunnrau is offline Find More Posts by queadlunnrau
New Product NEW Sbach 342 1400mm Balsa (ARF) HK Jaybee 3D Flying 199 Dec 22, 2014 03:36 PM
Discussion HobbyKing Sbach 342 1000mm ARF helivsFMX 3D Flying 3 May 11, 2014 12:33 PM
New Product Hobbyking Sbach 342 Trapviper 3D Flying 343 Sep 30, 2013 01:42 PM
Wanted Sbach 342 1400mm Balsa (ARF) shepster Aircraft - Electric - Airplanes (FS/W) 11 Dec 19, 2011 07:59 PM
New Product NEW!!!! Hobbyking 1000mm SBach 342 BALSA ARF Jaybee 3D Flying 7 Jun 04, 2011 02:02 AM
