Old Nov 18, 2012, 07:39 PM
rayonnair is offline
Find More Posts by rayonnair
rayonnair's Avatar
Singapore, Singapore
Joined Jun 2012
I believe I have corona 939s in the ailerons, and a HK servo of some sort for the rudder/elevator. I need to check later when I get back home. I think I've posted them up before but for the life of me I can't find them on this thread. They're all digital MG servos. I also have a separate SBEC from HK.
I only got ~40ish flights on it before the motor crapped out so I don't know how they will hold up over time. That said I suspect I will total my plane before the servos reach their end of life.
rayonnair is offline Find More Posts by rayonnair
Old Nov 18, 2012, 07:47 PM
rayonnair's Avatar
Joined Jun 2012
Found it:
D26012MG servos. http://www.hobbyking.com/hobbyking/s...dProduct=10969.
+ point: servo horns that come with the SBach fit directly on these. Size of the servo is also identical.
Old Nov 18, 2012, 07:51 PM
ryanbe15 is offline
Find More Posts by ryanbe15
ryanbe15's Avatar
United States, MD, Bethesda
Joined Sep 2012
the HK Servo's in the rudder/elevator work just fine?
ryanbe15 is offline Find More Posts by ryanbe15
Old Nov 18, 2012, 08:07 PM
rayonnair's Avatar
Joined Jun 2012
They work fine for me. Ymmv ofc!
Old Nov 18, 2012, 08:15 PM
pasantia is offline
Find More Posts by pasantia
United States, IA, Fort Madison
Joined Jan 2009
how would you change the aileron servo with that long wire inside the wings?
pasantia is offline Find More Posts by pasantia
Old Nov 18, 2012, 10:03 PM
out of stock is offline
Find More Posts by out of stock
Speed only
out of stock's Avatar
United States, FL, Lehigh Acres
Joined Jan 2012
i think i'll stick to the stock motor. 14x7
upgrade esc.
2650 4c 40c
and i'm thinking twice about them servos. your right. i'm not doubting the towerpro's or Hd's. maybe i'll get the hd's for rudder?
ohh important, i'm not adding a bec. i'm supplying through a LiFe pack (1000mah) yeaa a bec is lighter but this will be fine for my type of flying. no super 3d. i actually would be interested in a bit more speed and mild aerobatics. this foamie has great potential i believe.
out of stock is offline Find More Posts by out of stock
Old Nov 18, 2012, 10:23 PM
pasantia is offline
Joined Jan 2009
Spinner for 14 -7?
What spinner to use if you change a 14-7 prop? Can you use the stock spinner?
Old Nov 18, 2012, 10:52 PM
Speed only
Joined Jan 2012
very good question. i'm picky about spinners. the could make or break the looks of sbach. The sbach (in my opinion) need that somewhat lengthy spinner.
i think just trimming the stock spinner would work.
Old Nov 18, 2012, 11:14 PM
rayonnair's Avatar
Joined Jun 2012
Spinner: trim it with a dremel and file. The bigger problem is if your motor bites it because the spinner is a specific fit for the motor.
Aileron servos: cut the wires on the old servos. Cut wires on new servos. Splice them together and solder. Electrical tape to cover. Entire process happens with the long aileron servo wire still in.
Old Nov 18, 2012, 11:29 PM
hendrnk is offline
Find More Posts by hendrnk
An Aussie in Chicago
Joined Apr 2012
That's what I did, but I used heat shrink instead of tape.
hendrnk is offline Find More Posts by hendrnk
Old Nov 18, 2012, 11:31 PM
Speed only
Joined Jan 2012
haha my buddy is doing that cutting/splicing/soldering job on a pusher glider hes got. theres no issue doing that. its fine.
wait a sec, is this what everyone is doing when upgrading the aileron servos? is it like a "no other option" type of deal?
Old Nov 19, 2012, 12:24 AM
pullup! is offline
Find More Posts by pullup!
HellBentPuppet
pullup!'s Avatar
Co.
Joined Jan 2005
You can use servo extensions if you don't want to solder, that is the route I'm going.
pullup! is offline Find More Posts by pullup!
Old Nov 19, 2012, 03:46 AM
wigsw001 is offline
Find More Posts by wigsw001
Scott
Australia, SA, Two Wells
Joined Feb 2012
Yeah servo extension is the easiest way to go. Just tape the extension to the end plug of the stock servo to pull it though the wing otherwise you'll have a very hard task getting it through without damaging the wing.
wigsw001 is offline Find More Posts by wigsw001
Old Nov 19, 2012, 08:40 AM
Speed only
Joined Jan 2012
Good deal. Extensions it is.
Old Nov 19, 2012, 09:28 AM
pasantia is offline
Joined Jan 2009
how long extension cord? thanks
New Product NEW Sbach 342 1400mm Balsa (ARF) HK Jaybee 3D Flying 199 Dec 22, 2014 02:36 PM
Discussion HobbyKing Sbach 342 1000mm ARF helivsFMX 3D Flying 3 May 11, 2014 11:33 AM
New Product Hobbyking Sbach 342 Trapviper 3D Flying 343 Sep 30, 2013 12:42 PM
Wanted Sbach 342 1400mm Balsa (ARF) shepster Aircraft - Electric - Airplanes (FS/W) 11 Dec 19, 2011 06:59 PM
New Product NEW!!!! Hobbyking 1000mm SBach 342 BALSA ARF Jaybee 3D Flying 7 Jun 04, 2011 01:02 AM
