Old Oct 08, 2012, 08:20 AM
joselu is offline
Find More Posts by joselu
crack Spain
joselu's Avatar
Spain, Madrid, M
Joined Jun 2012
I bought for aileron
You think is good?torque is 2,2
http://www.hobbyking.com/hobbyking/s...dProduct=22929
joselu is offline Find More Posts by joselu
Old Oct 09, 2012, 10:49 PM
acesimmer is online now
Find More Posts by acesimmer
acesimmer's Avatar
United States, NV, Fernley
Joined Oct 2011
I just tried 5s 4000 40c packs in mine with stock motor and esc. Esc temp was 92 deg f all day and max in flight current peeked at 54 amps. Measured with hitec telemetry. To be honest it was not much better than 4s 3300. I flew full aero routine for 6.5 mins and used 54 percent of battery. So longer flight time with a bit more vertical.
acesimmer is online now Find More Posts by acesimmer
Old Oct 10, 2012, 06:47 AM
wigsw001 is offline
Find More Posts by wigsw001
Scott
Australia, SA, Two Wells
Joined Feb 2012
How come you get such a low amp draw with the 5s on the stock set-up? Mine on the stock setup on 4s draws 63amps.
Update. Just tested on 5s and my stock motor and esc pull 85amps at WOT with a zippy 5s 3000mah 40c. Acesimmer did you just not go full throttle with the 5s in flight?
wigsw001 is offline Find More Posts by wigsw001
Old Oct 12, 2012, 11:11 PM
acesimmer's Avatar
Joined Oct 2011
I did go full in a vertical climb to 650 ft. Then a shallow dive touching 98 mph. Info was in flight real time telemetry to my aurora 9. Maybe I should do a static with my watt meter? I cannot remember which amp sensor I installed so maybe getting a false reading. I'm at the Vegas ace in the hole flyin so do not have the other sensor with me to check. Other than a bit more vertical I'm not sure it's worth switching to 5S.
Old Oct 13, 2012, 06:48 PM
wigsw001 is offline
Scott
Joined Feb 2012
Yeah mine was a static test with the hobbyking watt meter. I'd want to change out the esc if I was using 5s. I wonder how many amps the stock motor can take? I imagine 85amps would be pushing the limits though.
Old Oct 13, 2012, 07:24 PM
acesimmer's Avatar
Joined Oct 2011
Sheeeet....... So here I am at the Vegas aces event flying my routines with the sbach and my flanker. Big smile on my face thinking 5 S and only low fifties for amps. Well I got off my lazy butt and put my watt meter on this morning. Yikes!!!! Im pulling 84 amps .... Guess I had the low current sensor installed not the 200 amp unit.
I wondered why when running 5S static at full the motor would chirp at max power. So back to 4 S til I get the bigger esc installed. Having the wrong sensor was giving me 52 a on 4 s and 54 a on 5 s. so the telemetry sensor was maxing out even for the 4s and not giving me full range. No more trusting gadgets until fully checked out. I could and should have had a burn up with the flights I was putting in. Full power to 600 ft then high speed dive! Wondered why my butt was sore it must have been that horse shoe?
Old Oct 13, 2012, 10:11 PM
rayonnair is online now
Find More Posts by rayonnair
rayonnair's Avatar
Singapore, Singapore
Joined Jun 2012
Well the magnets fell out of my motor too. Landed it ok, all in one piece, but now my motor is toast. I figure I have 2 options:
(1) get a 6S power system and run 2x2200mah packs in series. I have lots if 2200 3S packs, downside is weight and amp draw for batteries.
(2) glue the magnets back in. No idea how to do that or what glue to use.
Any help, guys?
rayonnair is online now Find More Posts by rayonnair
Old Oct 14, 2012, 12:23 AM
iceaxe is offline
Find More Posts by iceaxe
iceaxe's Avatar
Joined Dec 2006
I used both 5 min epoxy and medium CA neither an issue just make sure they are seated properly it happened a couple of times on the stock sbach motor and used to happen from time to time on the old fms motors
iceaxe is offline Find More Posts by iceaxe
Old Oct 14, 2012, 09:34 AM
rayonnair's Avatar
Joined Jun 2012
Doesn't CA degrade on heat?
Anyway, thanks iceaxe, will try the epoxy
Old Oct 14, 2012, 09:47 AM
G James is offline
Find More Posts by G James
Fly Like You Stole It
G James's Avatar
Australia, WA, Byford
Joined Oct 2009
Thread lock works on smaller motors, no reason why it wont work on bigger ones
G James is offline Find More Posts by G James
Old Oct 15, 2012, 05:38 AM
wigsw001 is offline
Scott
Joined Feb 2012
Nearly lost the sbach today due to loosing rx signal. Coming down in a steep dive lost all control and couldn't pull up. Got closer and closer to the ground and finally got control back about 10m from the deck. Needless to say I landed pretty quickly after that.
I was extremely lucky in the end to save her. Thinking back I must have lost signal momentarily earlier in the flight but at the time I thought it must have been a wind gust.
I was using my spectrum dx6i and and orange 6ch with orange satellite rx. I've had problems in the past losing signal with the 6ch orange rx but thought the addition of a satellite would tidy that up. How wrong I was, I've heard that the 7ch fail safe orange rx is much better quality but who knows. I think I might just take the official spectrum rx out of one of my other less important models and use that and replace it with the 7ch orange rx.
All I can say though is I'm one lucky guy.
Old Oct 15, 2012, 07:31 PM
kmdunnster is offline
Find More Posts by kmdunnster
Unregistered User
kmdunnster's Avatar
Long Beach, CA
Joined Mar 2010
Headless Sbach
Hey guys,
Well, after about 75+ flights and had my first major mishap. Was practicing knife edge passes. Lower and lower each time to see how big my Huevos are and cart wheeled. When I got to the airplane, I noticed that the Pilot figure's head was gone. I found it about 30ft away. Not much damage other than the motor mount, pulled the aileron hinges, and a couple other little cosmetic things . Didn't even break the prop.
Kevin
kmdunnster is offline Find More Posts by kmdunnster
Old Oct 15, 2012, 07:59 PM
rayonnair's Avatar
Joined Jun 2012
Och kmdunnster. Well at least it seems mostly OK! I wonder how it decapitated and fell out of the canopy, can't see a big hole just a big crack?
Do remember to power on test the servos to see if they stripped too. My last crash it appeared that all servos were OK, but if you powered them on and tried to put a bit of pressure on the control surfaces they skipped everywhere.
Old Oct 20, 2012, 11:22 PM
iceaxe is offline
iceaxe's Avatar
Joined Dec 2006
After 187 flights and 24 1/2 hrs I rolled inverted on take off a gust of wind hit her and I pulled instead of pushed and punched straight in lolName: ImageUploadedByTapatalk1350793125.700765.jpg
Description:
Actually wasn't too worried as I pushed her hard for most of her life and was looking at gettin a new airframe just last week as the old one was looking stressed and thankfully my power 46 and savox servos all survived and a new one is on its way and should be here in a week
Old Oct 21, 2012, 04:11 PM
builder bob is offline
Find More Posts by builder bob
builder bob's Avatar
United States, MA
Joined Oct 2011
hope that doesn't happen to your next one. How hard is this plane to fly? i can fly an overpowered Avistar and an Ultimate 20-300 that i scratch built and has near full 3d capability. the ultimate is really easy to fly and could be used as a trainer and i don't know how to fly 3d. is the Sbach to hard for me to fly?
builder bob is offline Find More Posts by builder bob
New Product NEW Sbach 342 1400mm Balsa (ARF) HK Jaybee 3D Flying 199 Dec 22, 2014 02:36 PM
Discussion HobbyKing Sbach 342 1000mm ARF helivsFMX 3D Flying 3 May 11, 2014 11:33 AM
New Product Hobbyking Sbach 342 Trapviper 3D Flying 343 Sep 30, 2013 12:42 PM
Wanted Sbach 342 1400mm Balsa (ARF) shepster Aircraft - Electric - Airplanes (FS/W) 11 Dec 19, 2011 06:59 PM
New Product NEW!!!! Hobbyking 1000mm SBach 342 BALSA ARF Jaybee 3D Flying 7 Jun 04, 2011 01:02 AM
