Old Aug 25, 2012, 03:18 PM
J3 guy is offline
Find More Posts by J3 guy
Broken Arrow, Okla
Joined Oct 2010
You will find that the thin Tailwheel pushrods wil disconnect with the flex of the assembly.
I am using push/pull cables now, but still oversteers.
Have the DuBro replacement, just need to install it.
J3 guy is offline Find More Posts by J3 guy
Old Aug 25, 2012, 08:16 PM
kmdunnster is offline
Find More Posts by kmdunnster
Unregistered User
kmdunnster's Avatar
Long Beach, CA
Joined Mar 2010
Tailwheel
Like I posted before, the field where I fly is grass, with lots of bumps and clumps of crabgrass, gopher holes, etc... The stock tailwheel assembly came off around the 10th flight. I think on takeoff(not sure), so I used the DuBro #957 Tailwheel Assembly. It says it's meant for ".90-1.20 sized aircraft." Works like a charm and plows around with no problems like a 4x4.
Kevin
kmdunnster is offline Find More Posts by kmdunnster
Old Aug 26, 2012, 08:26 AM
joselu is offline
Find More Posts by joselu
crack Spain
joselu's Avatar
Spain, Madrid, M
Joined Jun 2012
how I can know the Cg?
joselu is offline Find More Posts by joselu
Old Aug 26, 2012, 09:30 AM
Unregistered User
kmdunnster's Avatar
Long Beach, CA
Joined Mar 2010
The balance point for CG is 120mm from the leading edge of the wing near the root.
Kevin
Old Aug 30, 2012, 06:54 AM
joselu is offline
crack Spain
joselu's Avatar
Spain, Madrid, M
Joined Jun 2012
with the serie motor and with prop 14*7, you can tell me this plane is posibly slow fly?or is dangerous¡¡
Old Aug 30, 2012, 02:51 PM
alex_007 is offline
Find More Posts by alex_007
alex_007's Avatar
France, Pays de la Loire, Nantes
Joined Sep 2010
I'd say yes but I have still not flown with it, so this is to be confirmed. This plane can do anything!
alex_007 is offline Find More Posts by alex_007
Old Aug 30, 2012, 06:49 PM
J3 guy is offline
Broken Arrow, Okla
Joined Oct 2010
Installed the DuBro Tailwheel assembly as shown above, found that the larger servoe mounting screws work for mounting it.
Drilled a hole in the mount to match the blind points on the fuse.
Turning radius is a little wide using the outer holes on the DuBro, will adjust.
Much improvement from the stock unit.
Old Aug 30, 2012, 11:46 PM
Eastcoast78 is offline
Find More Posts by Eastcoast78
Dixie Normious
Eastcoast78's Avatar
Can A da....Ehh!!
Joined May 2010
wellfly fine with a 14x7. Heres mine with a nice turnigy wooden 14x8
best fin prop!!
Hobby King 55'' EPO Sbach (5 min 37 sec)
Sbach Maiden Hobbyking 1400mm (4 min 58 sec)
Eastcoast78 is offline Find More Posts by Eastcoast78
Old Sep 01, 2012, 03:08 AM
joselu is offline
crack Spain
joselu's Avatar
Spain, Madrid, M
Joined Jun 2012
In some videos I see the landing and approach is very slowly
1º.-aileron as flaps?¿edit:sorry I saw in you first video 3,29",but flaperon to airbrake is up no down, no?
In second video min 4,00, the plane is slow, but is with flaperons ,up or down?and you have a mix with elevator?
In the simulator , real flight (I cant do it)
nice video east, the firt is very good, is great for know that I will buy in my sbach
2º.-the last question, the servos always configured 100%, but in dual rate for 3d configured 120%?
3ºwhich is the difference with prop wood?more power or speed?¡
A lot of question, sorry, jeje
Old Sep 01, 2012, 08:24 AM
joselu is offline
crack Spain
joselu's Avatar
Spain, Madrid, M
Joined Jun 2012
Kevin
I think the picture is wrong, why?
120mm=12cm
12cm is more far that I can to see the picture
I think the correct is 1,2cm, no?
Old Sep 01, 2012, 11:20 PM
J3 guy is offline
Broken Arrow, Okla
Joined Oct 2010
The picture is showing 120mm, which is correct and it works, but the drawing is not to scale.
Old Sep 06, 2012, 09:04 PM
rayonnair is offline
Find More Posts by rayonnair
rayonnair's Avatar
Singapore, Singapore
Joined Jun 2012
Hi guys!
Just got this kit and have a couple of questions.
1. I did something stupid and forgot about the plywood pieces for the rudder assembly. Then... Because I felt the rudder was weak, I epoxied the entire assembly on. How dumb of me. So, should I take the effort to undo this error and put the ply pieces on?
2. Is anyone else having trouble getting the elevator to move freely due to binding within the push rods? How did you guys fix it?
3. Anyone modded their kit to have the rudder and elevator servos at the back and not within the fuse?
4. With the turnigy nano tech 3300mah 4s batteries, it is fairly nose heavy at the 120mm cg mark. I could move almost 1-2 cm forward. Anyone tried flying like this?
rayonnair is offline Find More Posts by rayonnair
Old Sep 06, 2012, 10:25 PM
iceaxe is offline
Find More Posts by iceaxe
iceaxe's Avatar
Joined Dec 2006
On the rudder I would fix it if you are going to do aerobatics with her and as for servos I have my elev and Rudd servos in the standard spot but upgraded to full size savox mg for more precise control and never had any binding so can't help you there
As for lipo pos I have tried many different sizes and find I like the weight as far back as possible
iceaxe is offline Find More Posts by iceaxe
Old Sep 07, 2012, 02:21 AM
rayonnair's Avatar
Joined Jun 2012
Thanks iceaxe. I will probably upgrade those servos and redo the rudder then. And fiddle around with battery position.
Old Sep 07, 2012, 05:02 AM
iceaxe is offline
iceaxe's Avatar
Joined Dec 2006
Another friend who has the sbach used the stock elev and rudder servos as his aileron servos and he seems to have had a good run doing that
I stuck with savox on the aileron
As for cog mine is farther back than 120 closer to 130 I think can't remember as she has had 164 flights but almost harriers in for a sweet 3 point landing
Does anyone use flaperons for harriers I'm considering it after reading a model airplane news article about what to do if your model has wing rock just not sure how to set it up in my dx8 want to try it on my fliteworx edge 540 also as it suffers from wing rock
New Product NEW Sbach 342 1400mm Balsa (ARF) HK Jaybee 3D Flying 199 Dec 22, 2014 02:36 PM
Discussion HobbyKing Sbach 342 1000mm ARF helivsFMX 3D Flying 3 May 11, 2014 11:33 AM
New Product Hobbyking Sbach 342 Trapviper 3D Flying 343 Sep 30, 2013 12:42 PM
Wanted Sbach 342 1400mm Balsa (ARF) shepster Aircraft - Electric - Airplanes (FS/W) 11 Dec 19, 2011 06:59 PM
New Product NEW!!!! Hobbyking 1000mm SBach 342 BALSA ARF Jaybee 3D Flying 7 Jun 04, 2011 01:02 AM
