Old Aug 23, 2012, 05:00 PM
joselu is offline
Find More Posts by joselu
crack Spain
joselu's Avatar
Spain, Madrid, M
Joined Jun 2012
this photo is from nš150 post
http://static.rcgroups.net/forums/at...2014.55.00.jpg
i think i have same problem with the position motor(maybe more to right)
I ask is, is normal position or is a fail of hk
Tomorrow will put photos here
thanks and sorry for my english, jeje
joselu is offline Find More Posts by joselu
Old Aug 23, 2012, 05:46 PM
hendrnk is offline
Find More Posts by hendrnk
An Aussie in Chicago
Joined Apr 2012
This is normal and needed.
hendrnk is offline Find More Posts by hendrnk
Old Aug 24, 2012, 01:23 AM
kmdunnster is offline
Find More Posts by kmdunnster
Unregistered User
kmdunnster's Avatar
Long Beach, CA
Joined Mar 2010
Yellow Sbach?
Hey joselu,
I checked out your'e pic of the motor, and yes, right and down is what you want
What's up with the what looked like a yellow paint job?
Kevin
kmdunnster is offline Find More Posts by kmdunnster
Old Aug 24, 2012, 08:55 AM
joselu is offline
crack Spain
joselu's Avatar
Spain, Madrid, M
Joined Jun 2012
solucionated
Old Aug 24, 2012, 11:40 AM
queadlunnrau is offline
Find More Posts by queadlunnrau
Luck is my skill
queadlunnrau's Avatar
United States, WA, Seattle
Joined Jun 2009
The two people above answered your post answered your question,
yes this is normal.
queadlunnrau is offline Find More Posts by queadlunnrau
Old Aug 24, 2012, 12:47 PM
joselu is offline
crack Spain
joselu's Avatar
Spain, Madrid, M
Joined Jun 2012
solucionated
Old Aug 24, 2012, 01:28 PM
alex_007 is offline
Find More Posts by alex_007
alex_007's Avatar
France, Pays de la Loire, Nantes
Joined Sep 2010
someone see some error?
the horns are not attached ^^ i only see that, otherwise good assembly
Please, my question is still current. (post #1107) It's about an non-original spinner
__________________________________________________ _________
alex_007 is offline Find More Posts by alex_007
Old Aug 24, 2012, 01:43 PM
hendrnk is offline
Joined Apr 2012
Old Aug 24, 2012, 08:34 PM
J3 guy is offline
Find More Posts by J3 guy
Broken Arrow, Okla
Joined Oct 2010
Since the motor shaft is soft on these, I am using another nut on the shaft. I snug up the first one, then tighten the second nut to it.
Working sofar.
J3 guy is offline Find More Posts by J3 guy
Old Aug 24, 2012, 11:30 PM
Unregistered User
kmdunnster's Avatar
Long Beach, CA
Joined Mar 2010
The spinner is attached to the backplate with cap screws. There are lock nuts set in the backplate of the spinner. That's what keeps the spinner and backplate together.
Kev
Old Aug 24, 2012, 11:43 PM
Eastcoast78 is online now
Find More Posts by Eastcoast78
Dixie Normious
Eastcoast78's Avatar
Can A da....Ehh!!
Joined May 2010
I noticed in your pic a few pages ago, in "red" Alex! are you using the Prop washer. that goes between the Nut and the Prop?
Haven't flown the Sbach now in weeks, may take her for a few spins the weekend!
Eastcoast78 is online now Find More Posts by Eastcoast78
Old Aug 25, 2012, 05:43 AM
alex_007 is offline
alex_007's Avatar
Joined Sep 2010
Originally Posted by Eastcoast78 View Post
Are you using the Prop washer. that goes between the Nut and the Prop?
Yeah, yes! Thanks for your help, you, J3 guy and kmdunnster Good flight to you!
Old Aug 25, 2012, 06:42 AM
joselu is offline
crack Spain
joselu's Avatar
Spain, Madrid, M
Joined Jun 2012
thanks you
Old Aug 25, 2012, 08:55 AM
hendrnk is offline
Joined Apr 2012
You just need to bend the piece of metal that holds the rear wheel down to give clearance to the rudder. I also made another piece of Aluminium the same size under the first piece to give it more strength. Acts like a leaf spring on a truck. Works better.
Old Aug 25, 2012, 11:10 AM
joselu is offline
crack Spain
joselu's Avatar
Spain, Madrid, M
Joined Jun 2012
fuuu, broken a one piece metal
thans you
New Product NEW Sbach 342 1400mm Balsa (ARF) HK Jaybee 3D Flying 199 Dec 22, 2014 03:36 PM
Discussion HobbyKing Sbach 342 1000mm ARF helivsFMX 3D Flying 3 May 11, 2014 12:33 PM
New Product Hobbyking Sbach 342 Trapviper 3D Flying 343 Sep 30, 2013 01:42 PM
Wanted Sbach 342 1400mm Balsa (ARF) shepster Aircraft - Electric - Airplanes (FS/W) 11 Dec 19, 2011 07:59 PM
New Product NEW!!!! Hobbyking 1000mm SBach 342 BALSA ARF Jaybee 3D Flying 7 Jun 04, 2011 02:02 AM
