Old Aug 16, 2012, 07:14 AM
iceaxe is offline
Find More Posts by iceaxe
iceaxe's Avatar
Joined Dec 2006
Description:
Description:
Description:
Description:
Description:
Here's all my current models and times
iceaxe is offline Find More Posts by iceaxe
Old Aug 16, 2012, 10:44 AM
queadlunnrau is offline
Find More Posts by queadlunnrau
Luck is my skill
queadlunnrau's Avatar
United States, WA, Seattle
Joined Jun 2009
Do you work?
Seriously where do you find the time for all that flying?!!!
Man I wanna retire and have a flight log with that many hours of flying.
queadlunnrau is offline Find More Posts by queadlunnrau
Old Aug 16, 2012, 02:51 PM
acesimmer is offline
Find More Posts by acesimmer
acesimmer's Avatar
United States, NV, Fernley
Joined Oct 2011
Cool as Sh&^& Just downloaded to my iPhone. Saves keeping a paper logbook. I just got a second iPad to use with my Hitec telemetry system when out in the field. This logbook rounds out the toys. Thanks for the info.....
acesimmer is offline Find More Posts by acesimmer
Old Aug 16, 2012, 02:59 PM
iceaxe is offline
iceaxe's Avatar
Joined Dec 2006
It's epic and on quiet nights it's cool going back over and reading some of the comments I put in
I fly every sat sun morn and afternoon for a couple hours and try to get out once or twice after work during the week but then my flyin fields is 7 min from my house
Old Aug 16, 2012, 07:42 PM
acesimmer's Avatar
Joined Oct 2011
About the same has me. My field is 3 miles from the house and a real paved runway over 4000 ft.
Old Aug 18, 2012, 06:35 AM
iceaxe is offline
iceaxe's Avatar
Joined Dec 2006
Damn if I had that much room to play in I'd have a turbine and be divorced
Old Aug 19, 2012, 01:48 PM
acesimmer's Avatar
Joined Oct 2011
Dump the wife and get the turbine!!!
Old Aug 19, 2012, 02:58 PM
hendrnk is offline
Find More Posts by hendrnk
An Aussie in Chicago
Joined Apr 2012
If she really loved you she would understand your need for a turbine...
hendrnk is offline Find More Posts by hendrnk
Old Aug 19, 2012, 08:21 PM
Luck is my skill
Joined Jun 2009
Just tell her it's something that vibrates and she can sit on it anytime she wants.
Old Aug 21, 2012, 08:39 PM
kmdunnster is offline
Find More Posts by kmdunnster
Unregistered User
kmdunnster's Avatar
Long Beach, CA
Joined Mar 2010
Elevator sticky
Hey Guys,
Has anybody had problems with the elevator being "sticky?" Mine tends not to center that well. Cut a little foam away, or replace the hinges?
Any ideas.
Kevin
kmdunnster is offline Find More Posts by kmdunnster
Old Aug 21, 2012, 08:56 PM
hendrnk is offline
Joined Apr 2012
Originally Posted by kmdunnster View Post
Hey Guys,
Any ideas.
Kevin
Had a lot of trouble with the Rudder sticking but not the elevator. It worked itself loose after sometime as well, also installed a better servo which seemed to help as well.
Old Aug 22, 2012, 01:13 PM
alex_007 is offline
Find More Posts by alex_007
alex_007's Avatar
France, Pays de la Loire, Nantes
Joined Sep 2010
Originally Posted by alex_007 View Post
Yeah you're right. I've asked HK for know if there is shaft spacers with this product. I'm waiting the answer. Edit: there are no shaft spacers with it.
What the diameter of the hole shaft on your 2-3/4" DuBro spinner?
Please answer.!
And i've an other question about it:
When you fix it, or other same spinner, on your shaft motor, the only thing that is holding it, it's the bolt isn't it? (here in red)
this is not a bit light for the flight?
Click to zoom.
alex_007 is offline Find More Posts by alex_007
Old Aug 23, 2012, 01:40 PM
joselu is offline
Find More Posts by joselu
crack Spain
joselu's Avatar
Spain, Madrid, M
Joined Jun 2012
to see if I understand my English is very bad lol
I received this plane todaymotor base which screws next to the wooden base is not completely straight, this makes the engine is a little to the right
Has anyone had this same design flaw?
I put two washers on both bolts right to the engine is as straight as possible, would be nice?
The last question less important:the pilot no included?
joselu is offline Find More Posts by joselu
Old Aug 23, 2012, 02:22 PM
DEWorley is offline
Find More Posts by DEWorley
Joined Feb 2002
joselu,
the motor pointing to the right is called 'right thrust" & i believe most r/c planes have that built in & also some 'down thrust'.
i didn't get a pilot figure with mine, i just printed out a picture of a pilot, printed out a mirror image of the pilot, glued both to a piece of foam board & trimmed the foam board to fit. and glued that in the cockpit.
DEWorley is offline Find More Posts by DEWorley
Old Aug 23, 2012, 02:58 PM
hendrnk is offline
Joined Apr 2012
I would put the motor back the way it came...otherwise it will be a B_tch to fly. You could glue the firewall on the foam as it will get loose after a few flights while your in there.
New Product NEW Sbach 342 1400mm Balsa (ARF) HK Jaybee 3D Flying 199 Dec 22, 2014 02:36 PM
Discussion HobbyKing Sbach 342 1000mm ARF helivsFMX 3D Flying 3 May 11, 2014 11:33 AM
New Product Hobbyking Sbach 342 Trapviper 3D Flying 343 Sep 30, 2013 12:42 PM
Wanted Sbach 342 1400mm Balsa (ARF) shepster Aircraft - Electric - Airplanes (FS/W) 11 Dec 19, 2011 06:59 PM
New Product NEW!!!! Hobbyking 1000mm SBach 342 BALSA ARF Jaybee 3D Flying 7 Jun 04, 2011 01:02 AM
