Old Feb 06, 2012, 01:42 AM
boiko is offline
Find More Posts by boiko
Home of A-10 - Farmingdale NY
boiko's Avatar
United States, NH, Londonderry
Joined Dec 2006
Love the plane, but it's that extra $45-65 in shipping costs...that give me second thoughts about buying one..
- Does anyone think there'll sell this plane through their US Warehouse(s) anytime soon?
- Is anyone else selling this plane?
-mike-
boiko is offline Find More Posts by boiko
Old Feb 06, 2012, 07:05 AM
STATUS is offline
Find More Posts by STATUS
STATUS TUNING
STATUS's Avatar
Australia, VIC, Melbourne
Joined Dec 2010
upgraded a few parts
got mine today, seemed a bit limited on throw so i made a few mods with gear i had laying around.
the horns are HK ball bearing units i got ages ago for something and i swapped out the HK servos for HS 225mg hitecs or hicrash depending on who you talk yoo :P
doubled the throw and can get the full movement if i make a few small mods to the elevator tube support.. the servo horn hits the support before reaching full travel.
After flying i may try a 15x6 and 14x7 apc prop on it.... maybe the rimfire 0.32 i have laying about too if im not happy.
hk horns, they have nice friction free movement. http://www.hobbyking.com/hobbyking/s...idProduct=4328
STATUS is offline Find More Posts by STATUS
Old Feb 06, 2012, 10:10 AM
RUBNorris is offline
Find More Posts by RUBNorris
New Beeeeee
RUBNorris's Avatar
United States, CA, Sacramento
Joined Apr 2011
Anyone know the specs on the motor yet? Can a bigger prop work? And any ideas how to make this bird a little lighter? Gonna be kool to see all the mods that can be done.
RUBNorris is offline Find More Posts by RUBNorris
Old Feb 06, 2012, 11:08 AM
rotorsup is offline
Find More Posts by rotorsup
Joined Feb 2010
Battery Choice
Score0905 and RUBNorris -
Ordered one yesterday based on your comments. Other that the weight concerns, it sounds like a great bird.
I didn't order any batteries yet (I'm in northern Illinois, so it may be a while before I can get any quality outdoor flying). I'm thinking of getting 2650mah packs just to keep the weight down. What kind of flight times are you getting? Does the 3300mah pack fit without any cutting or mods?
Thank you.
rotorsup is offline Find More Posts by rotorsup
Old Feb 06, 2012, 11:30 AM
knutb is offline
Find More Posts by knutb
Joined Nov 2008
I saw this plane flying on Saturday, and it seemed to fly quite well. It was the orange version, and it looked good in the air as well as on the ground. I might accidentally have pressed the "buy" button, when I happened to log in to HC yesterday...
knutb is offline Find More Posts by knutb
Old Feb 06, 2012, 03:21 PM
Score0985 is offline
Find More Posts by Score0985
United States, AZ, Maricopa
Joined Jan 2012
Thank you.
I was able to get my 3300 4s battery packs to fit by placing them on there sides.
Score0985 is offline Find More Posts by Score0985
Old Feb 06, 2012, 09:13 PM
New Beeeeee
RUBNorris's Avatar
Joined Apr 2011
Thank you.
If you can get batteries from the USA hobbyking Way faster (i get mine in 3days)
New Beeeeee
RUBNorris's Avatar
Joined Apr 2011
How was the weight? Did it handle the 3300 ok?
Old Feb 06, 2012, 11:46 PM
STATUS is offline
STATUS TUNING
STATUS's Avatar
Joined Dec 2010
Thank you.
mine is setup for 2500 and 2600 will let you know 2moro as i have some 3000 and 3300 to try too..
TESTED motor tonight.
std motor and prop 568 watts and 46A, std motor with 15x8 1007 watts 75 amps via E-Flite watt meter.
Old Feb 07, 2012, 08:14 AM
Joined Jan 2012
handle the 3300 well. pushed all the way against the front firewall and only had to add just a little bit of elevator trim. status does that servo arm extension on top of the hs225mg make the elevator control rod not rub on the rudder control arm, and where is the best place to get a servo arm extension like you have on your hs225mg?
Old Feb 07, 2012, 10:15 AM
New Beeeeee
RUBNorris's Avatar
Joined Apr 2011
15x8 looks like tons of stress maybe a 14x# less amps?
Thank you for the test numbers
Old Feb 07, 2012, 11:35 AM
rotorsup is offline
Joined Feb 2010
Batteries
I've been ordering batteries here:
http://www.hobbypartz.com/77p-sl2650-4s1p-30c-4444.html
I've had good luck with these batteries. May need to swap connectors though.
Currently free shipping with $50 order. Two batteries plus a few odds and ends (props?) gets you there.
Old Feb 07, 2012, 11:40 AM
rotorsup is offline
Joined Feb 2010
Question about electronic thingy
RUBNorris:
In your maiden video after connecting your battery to the speed controller, you plugged something into the balance port and it beeped several times. What was it?
Old Feb 07, 2012, 11:46 AM
boiko is offline
boiko's Avatar
Joined Dec 2006
Weight: HK 1400mm/55" Sbach 342 vs 3DHS 57" Extra 330 SC
There's been some talk about the weight...but as ChrisNYPilot mentioned, the 57" 3DHS 330 Extra SC is just 2" larger in wingspan..with a weight that comes in right around 4.5-5.5 lbs.
So we're in the same ballpark here:
http://www.3dhobbyshop.com/57-Extra-...w_p_15128.html
Bring the weight down (mods- motor mount, landing gear, etc..) to 5 lbs or slightly under and it will be even better.
PS - Stock on Red/Black version is now 0....Orange version is now: 10
-mike-
Old Feb 07, 2012, 11:54 AM
boiko is offline
boiko's Avatar
Joined Dec 2006
Yikes, that is some jump in Watts 568 to 1007 and Amps 46 to 75....would be great to know the thrust difference.
But I agree..15x8 sounds like too much prop. What esc were you running when you saw the 75A on your meter?
-mike-
New Product NEW Sbach 342 1400mm Balsa (ARF) HK Jaybee 3D Flying 199 Dec 22, 2014 02:36 PM
Discussion HobbyKing Sbach 342 1000mm ARF helivsFMX 3D Flying 3 May 11, 2014 11:33 AM
New Product Hobbyking Sbach 342 Trapviper 3D Flying 343 Sep 30, 2013 12:42 PM
Wanted Sbach 342 1400mm Balsa (ARF) shepster Aircraft - Electric - Airplanes (FS/W) 11 Dec 19, 2011 06:59 PM
New Product NEW!!!! Hobbyking 1000mm SBach 342 BALSA ARF Jaybee 3D Flying 7 Jun 04, 2011 01:02 AM
