Old Jan 29, 2013, 05:22 AM
iceaxe is offline
Find More Posts by iceaxe
iceaxe's Avatar
Joined Dec 2006
My original sbach that had 180 flights was stripped before maiden and had eflight power 46 motor savox mg digital servos all round eflight 80 amp esc but was in hind site to heavy
iceaxe is offline Find More Posts by iceaxe
Old Feb 01, 2013, 09:41 PM
wigsw001 is offline
Find More Posts by wigsw001
Scott
Australia, SA, Two Wells
Joined Feb 2012
Hi guys put a new motor in the sbach after a crash in which I bent the motor shaft. I'll ordered a new shaft which will hopefully fit from hobby king but I wanted to be able to run on 5s sometimes too.
The new motor is this http://www.hobbyking.com/hobbyking/s...dProduct=19621
I'm running it in a 14x8 prop but it only draws 55amps on 4s so I'm going to try a 15x8 prop as I think it's a bit slower than the stock motor with this set up.
However I have a couple of problems. I still have the stock esc in there and when in the air (4s) if I go from low throttle to full throttle very quickly the motor squeals and jerks. If I raise the throttle slowly or in a normal manner it is fine to run on full throttle. Also I've only ground tested it but on 5s the motor squeals as I get close to 3/4-full throttle even when the throttle is eased on.
Are these issues the stock esc not coping with the different motor or not being able to supply enough power?
wigsw001 is offline Find More Posts by wigsw001
Old Feb 02, 2013, 09:36 PM
iceaxe is offline
iceaxe's Avatar
Joined Dec 2006
As for the esc with the motor you need to change the timing in the esc
Old Feb 08, 2013, 08:43 PM
Bravo47 is offline
Find More Posts by Bravo47
Australia
Joined Jun 2010
I had a close call today when the rudder servo got the jitters. She floated in nicely though for an emergency landing. So it looks like I will be changing out the stock RUD and ELEV servo's. I might leave the AILE servo's in place for now.
Mick
Bravo47 is offline Find More Posts by Bravo47
Old Feb 17, 2013, 01:22 PM
Bozso777 is offline
Find More Posts by Bozso777
Joined Jul 2011
Big Discount $10
Turnigy nano-tech 3300mah 4S 35~70C Lipo Pack (NL Warehouse) Save US$: 10.33
Bozso777 is offline Find More Posts by Bozso777
Old Feb 17, 2013, 07:31 PM
Fired Up is offline
Find More Posts by Fired Up
Joined Apr 2012
Have Them
Originally Posted by Bozso777 View Post
I have two of them,they both swelled up on me also the amps drop fast.My flying buddys also had problems with them.I have other nano-techs,this 3300,4s 35-70 is not a good one.
Fired Up is offline Find More Posts by Fired Up
Old Feb 17, 2013, 09:30 PM
ncflyer79 is offline
Find More Posts by ncflyer79
ncflyer79's Avatar
United States, NC, Marion
Joined Jun 2011
Guys I saw this thread and was wondering if this is the same sbach that pw-rc has made by FMS
ncflyer79 is offline Find More Posts by ncflyer79
Old Feb 18, 2013, 05:36 AM
iceaxe is offline
iceaxe's Avatar
Joined Dec 2006
No this model is made by star max I believe
The fms sbach is slightly smaller
Old Feb 19, 2013, 05:12 AM
iceaxe is offline
iceaxe's Avatar
Joined Dec 2006
A mate got some shots of mine flying the other day this is my second sbach which after 40 flights is stock other than a better prop and a scale Robert tail wheel setup
My first was a complete rebuild with eflight motor and esc Savox servos all round and honestly I'm really impressed with the stick setup
Description: Name: ImageUploadedByTapatalk1361272343.142879.jpg
Description: Name: ImageUploadedByTapatalk1361272352.871251.jpg
Description: Name: ImageUploadedByTapatalk1361272364.642019.jpg
Description: Name: ImageUploadedByTapatalk1361272374.475354.jpg
Description:
Old Feb 19, 2013, 08:59 AM
pullup! is offline
Find More Posts by pullup!
HellBentPuppet
pullup!'s Avatar
Co.
Joined Jan 2005
Great photos iceaxe! This Sbach sure is a great flyer.
Mines been grounded almost 2 weeks due to snow. I might have to move.
pullup! is offline Find More Posts by pullup!
Old Feb 19, 2013, 10:32 AM
RCAV8T0R is offline
Find More Posts by RCAV8T0R
Feeding the RC Addiction
RCAV8T0R's Avatar
United States, CA, San Diego
Joined Apr 2011
Those Sbach Action Shots...
My first was a complete rebuild with eflight motor and esc Slavic servos all round and honestly I'm really impressed with the stick setup
Attachment 5549774Attachment 5549775Attachment 5549776Attachment 5549777Attachment 5549778
...tell the story of this big foamie... She is a nimble ship that seems to fly "lighter" than the all up flying weight would lead you to believe. Of course, the proof is in the pudding & flying is believing......
Nice shots you got there, iceaxe. Looks like you were having fun with her & that's what this hobby is all about...
RCAV8T0R is offline Find More Posts by RCAV8T0R
Old Feb 25, 2013, 04:14 AM
wigsw001 is offline
Scott
Joined Feb 2012
Anyone looking for a replacement motor shaft for the stock motor this one is a good fit from hobbyking.
http://www.hobbyking.com/hobbyking/s...dProduct=20530
However you also need a new 5mm collar as the old collar won't fit the new shaft. As the stock shaft steps down at the end to I think 3mm but the replacement doesn't.
http://www.hobbyking.com/hobbyking/s...idProduct=8412.
However you actually may need shorter grub screws on the collar as the ones provided stick out from the collar and can rub on the stock motor mount screws.
Old Feb 25, 2013, 05:18 AM
xmorphx is offline
Find More Posts by xmorphx
United Kingdom, England, Milton Keynes
Joined Jun 2012
Plane looks awesome. Would this be ok for someone wanting to learn 3d?
xmorphx is offline Find More Posts by xmorphx
Old Feb 25, 2013, 12:17 PM
pullup! is offline
HellBentPuppet
pullup!'s Avatar
Co.
Joined Jan 2005
Its a great sport/acro airframe, I wouldn't really say its a hang on the prop 3D plane. It does great flat spins, knife edges, tumbles ect. It is an excellent flyer, capable of high and low speed maneuvers and is very stable.
Its one of my favorites in the hangar right now.
Old Feb 25, 2013, 04:13 PM
RCAV8T0R is offline
RCAV8T0R's Avatar
Joined Apr 2011
Second the Motion...
...meeting adjourned...next......
Hey pullup,
+1 on those comments. I "broke" mine out yesterday for a couple 6 minute flights & she flew so nice & gracefully. She can be so tame on low rates but then bump them up with a flick of the switch & she'll snap so quickly, almost like a plane 1/2 her size.........
By far "thee" most neutral flying ship when inverted that I have in the hangar. I was just about ready to take the Sbach up for a "spin" when one of my flying buddies started giving me some grief about never flying this ship (always in the rig, but not out in the pits) So I took off, got her airborne, got her straight & level parallel to the runway, flipped her over then took my hands of the sticks & she just stayed there. Completely locked in, perfectly level with no pitch or roll of any kind. Needless to say he was quite impressed with this big foamie saying that all of his ships need some kind of elevator input while flying inverted... Such a great acrobat & an all around well-balanced flyer.....
Did have a failure after landing after the second flight so I couldn't enjoy her as much as I'd hoped. Stock tail wheel decided to snap off at the fuse connection...so guess what pullup? I resurrected the Dynam Peaks 42 once again... I yanked the tail wheel off that dead soul's rudder & stuck it on the Sbach....... Never know when those scavenged parts from those old ships will come in handy...... Tell you what though, she'll be coming out of hiding muy pronto for more airtime ASAP!!!
New Product NEW Sbach 342 1400mm Balsa (ARF) HK Jaybee 3D Flying 199 Dec 22, 2014 02:36 PM
Discussion HobbyKing Sbach 342 1000mm ARF helivsFMX 3D Flying 3 May 11, 2014 11:33 AM
New Product Hobbyking Sbach 342 Trapviper 3D Flying 343 Sep 30, 2013 12:42 PM
Wanted Sbach 342 1400mm Balsa (ARF) shepster Aircraft - Electric - Airplanes (FS/W) 11 Dec 19, 2011 06:59 PM
New Product NEW!!!! Hobbyking 1000mm SBach 342 BALSA ARF Jaybee 3D Flying 7 Jun 04, 2011 01:02 AM
