Old Jan 12, 2012, 10:48 PM
Australia, NSW, Sydney
Joined Jul 2011
Non AR Drone Batteries on AR Drone charger?
Hi!
I have an AR Drone, and want some more batteries. I saw flitetests' video, but I need to know if a 1300 mah turnigy pack will charge through the balance cord ion the AR Drone 1000 mah charger?
nuketown is offline Find More Posts by nuketown
Old Jan 13, 2012, 09:07 AM
Frankenstein recycled packs
rampman's Avatar
USA, AZ, Gilbert
Joined Jan 2006
We are too old and too lazy to look up all of your items. Post pictures of your charger and the battery you want to buy. We actually know that pack but give us all info up front and you will get a more accurate response.
Rick
rampman is offline Find More Posts by rampman
Latest blog entry: mean well S-210-12 power supply
Old Jan 13, 2012, 03:24 PM
Joined Jul 2011
Left AR Drone Charger
Middle AR Drone Battery
Right 1300 Turnigy Battery
The AR Drone charger uses the JST balance plug to charge the AR Drone battery - I presume it will charge a turnigy pack with its JST?
Old Jan 13, 2012, 05:18 PM
rampman's Avatar
USA, AZ, Gilbert
Joined Jan 2006
nuke, thanks for the pics. You assume correctly, it will charge it just fine. You will need to change your discharge connector to what will be your standard from now on. The one on the Drone battery is not a very good connector over a long period of time.
Rick
Old Jan 15, 2012, 07:35 PM
Formerly Maddux99
PlaneCraz3d's Avatar
United States, KY, Calvert City
Joined Jun 2010
I am using that exact same pack from HK on my AR Drone as well. I use EC3 connectors on all of my packs, so I built an adapter from the "AR" connector to EC3 and put EC3 connector on the AR Battery. I use this adapter so no "mods" were necessary to the Drone itself (thus keeping my warranty intact as Parrot frowns on using aftermarket batteries). I will post pics of the Batteries and adapter if I can figure out how as I have never posted any before.
PlaneCraz3d is offline Find More Posts by PlaneCraz3d
Old Jan 15, 2012, 08:13 PM
Formerly Maddux99
Joined Jun 2010
Here are the pics of my AR adapter and batteries both stock and Turnigy. I just cut the stock plug off of the battery and soldered on EC3's. Be very careful when cutting the stock plug off as the wire isn't very long and you will only get one chance. Plus I'm sure you already know but do not cut both battery wires at the same time, things will get exciting quickly!
Discussion MacGyver RC Mod for the AR Drone Chadfish Multirotor Talk 3 Jun 09, 2012 07:18 PM
For Sale Parrot AR Drone jdemw Aircraft - Electric - Multirotor (FS/W) 2 Oct 24, 2011 11:34 AM
Discussion Parrot ar drone on ebay c2zinn Multirotor Talk 0 Jul 23, 2011 09:08 PM
Discussion New AR Drone (i-drone) light mod bungle68 Multirotor Talk 3 Apr 13, 2011 05:30 PM
Discussion Joystiq Article - Hands-on: Parrot AR.Drone flitelab Multirotor Talk 7 Jun 25, 2010 05:24 PM
