This thread is privately moderated by Raehm, who may elect to delete unwanted replies.
Old Jan 12, 2012, 03:36 PM
Raehm is offline
Find More Posts by Raehm
Raehm's Avatar
Charleston, SC
Joined Jul 2006
Flyzone Focke Wulf FW 190 build
The stock motor mount is probably inadequate for my G15 (power15 equivilant)
Raehm is offline Find More Posts by Raehm
Old Jan 12, 2012, 03:39 PM
Raehm is offline
Raehm's Avatar
Charleston, SC
Joined Jul 2006
Next, I need a method for centering the motor mount. For this, I just positioned the G15 with four foam cutouts of the same size as spacers.
Old Jan 12, 2012, 03:42 PM
Raehm is offline
Raehm's Avatar
Charleston, SC
Joined Jul 2006
So the finished, mounted motor looks like this. Pretty damn close to center.
Old Jan 12, 2012, 03:47 PM
Raehm is offline
Raehm's Avatar
Charleston, SC
Joined Jul 2006
Finding that the travel on the flaps was not the same, my solution was to add a longer arm. After several flights, these plastic-gear servos failed, and changed them out with metal gear servos.
I also found the leverage arms (inside the wings) where not securely mounted. That required cutting into the ventral wing panel to reseat these arms.
Also shown in the picture is a Turnigy servo speed reducer for the gear, which works quite well.
Old Jan 12, 2012, 03:50 PM
Raehm is offline
Raehm's Avatar
Charleston, SC
Joined Jul 2006
The rear stabilizer seemed way to flimsy, so I reinforced it with a carbon fiber rod and the elevator with reinforced packing tape.
Old Jan 12, 2012, 03:52 PM
Raehm is offline
Raehm's Avatar
Charleston, SC
Joined Jul 2006
I also found that I need to cut and also add some foam so that my 2200 30c battery would fit. The stock velcro works just fine. And, to facilitate easier power up, I added a six inch extension to the dean's connector from the ESC.
Old Jan 12, 2012, 03:55 PM
Raehm is offline
Raehm's Avatar
Charleston, SC
Joined Jul 2006
The rudder pivot point is weak, similar to the PZ Mustang. I reinforce it with packing tape.
Old Jul 06, 2012, 05:28 PM
Resparky is offline
Find More Posts by Resparky
Joined Jan 2012
Looks good! I need to do alot of these mods to my FW. What kv motor did you decide to go with? Do you know the kv of the stock motor?
Resparky is offline Find More Posts by Resparky
New Product Flyzone Focke-Wulf FW 190 dmak173 Electric Warbirds 712 Apr 16, 2016 06:27 PM
Article Flyzone Focke Wulf FW 190 RTF with Retracts Review Michael Heer Electric Warbirds 41 Jul 19, 2015 08:20 AM
