Old Jan 21, 2012, 02:22 PM
AndyKunz is online now
Find More Posts by AndyKunz
AndyKunz's Avatar
Illinois
Joined Sep 2001
Originally Posted by Pitstop000 View Post
Here you go Andy
Attachment 4549404
Got a bottom view like that?
I'm building again today. I'll be posting photos later.
Andy
AndyKunz is online now Find More Posts by AndyKunz
Site Sponsor
Old Jan 21, 2012, 05:58 PM
AndyKunz's Avatar
Illinois
Joined Sep 2001
The forward fuse is sheet. I attached it to the spruce frame built earlier. I didn't have any 3/16 or 1/4 triangle, so I used 3/16 square for the corner stock. Much of this will be sanded away when we get to rounding the nose off.
The fuselage formers are hard 3/32" balsa but the firewall is 1/16" ply, just like the rest of the micros I've been building. The wing ribs are hard 1/32" (they will be lightened a little later on).
Site Sponsor
Old Jan 21, 2012, 06:06 PM
AndyKunz's Avatar
Illinois
Joined Sep 2001
The top side is going to be done with stringers. To get a nice transition to the cowl hatch (which will be hollowed balsa block) there is a partial former that the stringers will be resting on.
The nose wheel mount is just a hard block again, as I showed in the Bridi trainer build thread a few weeks ago. The free castering is adequate for control on the ground. I had a time getting my full-size fingers into the micro T-20 nose to lock the setscrew, so this time I brought the hole through the firewall.
It sure is fun to build these little guys. I really encourage you all to try. Use the plans for something you already have, get a sheet of 1/32" balsa and pull the scrap box close and dig in!
Site Sponsor
Old Jan 21, 2012, 09:01 PM
AndyKunz's Avatar
Illinois
Joined Sep 2001
After cutting some lightening holes in the ribs, they were separated in preparation for building the wings. The blocks for the main gear are made from 1/4" sq hard balsa. I had to cut a notch in them using the razor saw to allow the wire to fit snugly inside.
It doesn't look like much, but these photos show how I spent most of my afternoon. These steps were done while the fuselage formers were installed. The next steps will be to finish joining the rear half, make a mount for the receiver brick, and make formers for gluing the stringers in.
Site Sponsor
Old Jan 28, 2012, 03:51 PM
AndyKunz's Avatar
Illinois
Joined Sep 2001
The left wing panel is framed up. I built it upside down on the plans. When doing this I had to make sure that I had the ribs oriented properly for the landing gear block, and had to angle the root rib properly.
While the wing was drying, I was able to join the tail of the fuselage. Be careful to use centering marks on the formers near the nose so that the tail is straight. The sides then have short cross-pieces inserted between them to round out the taper per the plans.
There was also time to start on the stab. These are built up, but if you notice the ribs are just 3/8" high rectangles right now. This make them much easier to build. The LE and TE are 3/16" sq lifted 3/32" above the plans, centering them on the LE and TE. I will sand the whole thing to an airfoil later on.
Site Sponsor
Old Jan 28, 2012, 05:19 PM
Mendo is offline
Find More Posts by Mendo
Mendo's Avatar
United States, CA, Ukiah
Joined Dec 2011
Looks Great Andy!
Mendo is offline Find More Posts by Mendo
Old Jan 28, 2012, 06:11 PM
R_G is online now
R_G
Find More Posts by R_G
R_G
UFO Driver
R_G's Avatar
United States, PA, Farrell
Joined May 2010
Very Nice! This is going to be neat little model!
Ralph
R_G is online now Find More Posts by R_G
Old Jan 28, 2012, 06:31 PM
AndyKunz's Avatar
Illinois
Joined Sep 2001
Thanks!
It's certainly the slowest micro build I've ever done.
Andy
Site Sponsor
Old Jan 28, 2012, 08:30 PM
AndyKunz's Avatar
Illinois
Joined Sep 2001
After building the second stab, I started on the fin. The plans show this as sheet, but I'm building it up to reduce weight.
The TE of the rudder is made by laminating a 1/64" ply strip between two sheets of 1/32 balsa. This makes the TE stronger to prevent damage and bowing when the covering is shrunk, but also provides a reference for sanding. I'll use the same technique for the elevators.
Site Sponsor
Old Feb 02, 2012, 09:41 PM
AndyKunz's Avatar
Illinois
Joined Sep 2001
The elevator halves are built-up too. The LE and root are 3/16", and the TE is the same construction as the rudder TE. We need a little beef here to handle the control horn and not twist. Also, the LE will be cut back on one side for hinging.
The fin LE is curved, so I cut that to shape and then rounded it and tapered the sides into it. The result, one the rudder is attached, will be a gentle diamond with 1/8" thick LE and 1/16" TE and 3/16" thick at the hinge.
I plan to use hinges on the centerline of the rudder, but I'm still debating whether to use covering hinges on the elevator or the same type as the fin. Anybody got suggestions?
Site Sponsor
Old Feb 03, 2012, 08:40 AM
bpink43 is offline
Find More Posts by bpink43
bpink43's Avatar
United States, MO, Springfield
Joined Dec 2009
Andy, I have used the regular CA hinges that I cut to very narrow strips in my micro tiporare build.....which i need to get working on again, but they seem to work ok. However, I think I would go with the covering hinges as even with the trimmed down CA hinges, the little ultra micro linear servos have a bit of strain to deflect my ailerons.
bpink43 is offline Find More Posts by bpink43
Old Feb 03, 2012, 05:19 PM
AndyKunz's Avatar
Illinois
Joined Sep 2001
CA is definitely a bad idea, I was thinking of using mylar like we have with the actuator-based RC systems. Thread hinges were gone by the time this came around.
Andy
Site Sponsor
Old Feb 11, 2012, 02:25 PM
AndyKunz's Avatar
Illinois
Joined Sep 2001
It's been a busy week, and none of it was for building airplanes. But that's behind me for a few days, so I got to do a little more.
The wing tips were cut from a soft block I had in the scrap bin. The are slightly oversize, glued on for finishing.
After sanding to an airfoil shape, the center line at the tip is marked for reference when carving and sanding. The sanded wingtips are ready to be hollowed out later.
Site Sponsor
Old Feb 11, 2012, 02:29 PM
AndyKunz's Avatar
Illinois
Joined Sep 2001
The stab tips get the same treatment, except that the ribs are sanded to an airfoil instead of serving as an airfoil reference.
The stab is finished while the elevator is attached. The elevator was already tapered in earlier steps, and serves to make sure we keep the shape proper. I have not angled the elevator LE yet because I wanted it square for this operation.
Got to get back to doing some building now.
Site Sponsor
Old Feb 11, 2012, 07:32 PM
AndyKunz's Avatar
Illinois
Joined Sep 2001
Changes!
Mounting the stabilizer on the fuselage would be a little difficult with the unsheeted stab and open frame construction. I changed the tail a bit by insetting balsa sheet into the spruce frame on the sides and bottom. Next I removed the root ribs from the stab and used them as patterns to set the incidence (0) on the new sheeted tail.
The solid root of the stab will be lightened. I only need about 1/8" for the covering to be attached well, and it doesn't need to be solid, but this makes it a little easier for construction.
Right now the wings are hanging up in front of the shop heater, drying the servo rails. Hopefully it doesn't take a week for me to work on this again!
Site Sponsor
Discussion Micro Shrike Build Thread (was Mystery Build Thread) AndyKunz Electric Plane Talk 101 Dec 05, 2013 09:50 AM
Build Log Another Build, Y4 . UFO wanna Be. now Crashed!!! tc3wins Multirotor Talk 10 Aug 28, 2013 04:00 PM
Discussion Micro Bridi Trainer Build Thread AndyKunz The Builders Workshop 40 Jan 14, 2012 04:43 PM
Discussion Micro UFO, need plans AndyKunz Classic Pattern Flying 10 Jan 09, 2012 12:15 AM
Question Skywalker 3 Build Advice and Eventual Build Thread! Ecibob FPV Talk 2 May 01, 2011 04:46 PM
