Old Jan 12, 2012, 03:44 AM
quadman is offline
Find More Posts by quadman
California
Joined Nov 2009
Why one of 6 Motor Delayed start???
Guys,
One motor on my Hex always delay in start and I have calibrated the throttle range many time it's the same. Then notice one funny thing, after 6 time arming the motor after plugging in the battery, it will spin up all together and every time all six motors will start together.
Then once I put it a fresh battery, it will require 6 time arming the motors, then it will all start together again.
I have soldiered the connections for that motor again, didn't help.
Anyone one have a remedy for this problem??
At the moment, my hexa have a oscillation and I am suspecting that delay start motor is causing the problem, as it have a slower RPM then other motors, the hexa is compensating for the slower motor.
quadman is offline Find More Posts by quadman
Old Jan 12, 2012, 04:15 AM
Sebbie is offline
Find More Posts by Sebbie
My Goshawk is awesome :)
Sebbie's Avatar
United Kingdom, Stevenage
Joined Sep 2010
what flight controller are you using and ESC's, this info may help us provide some detailed advice for you.
I would try and reset and recalibrate your ESC's, they are different and may need the freshold set higher to give you that uniformal start.
Have you tried the motor on a different esc to see if the fault follows th emotor or stays with the esc ?
i hope we can shed some light on it for you, it is frustrating i know.
Good luck
Sebbie is offline Find More Posts by Sebbie
Old Jan 12, 2012, 03:53 PM
quadman is offline
California
Joined Nov 2009
Thanks, I am using WooKong.
I already tried a different motor, no luck. Might buy another ESC to see what happen.
Old Jan 12, 2012, 08:35 PM
barok is offline
Find More Posts by barok
barok's Avatar
Joined Apr 2006
try this..it work on my quad, not sure bout hex..
go to your sub trim menu, increase or decrease that channel...as if your centering a servo..
barok is offline Find More Posts by barok
Old Jan 12, 2012, 08:41 PM
jesolins is offline
Find More Posts by jesolins
Tri-Quad-Hexa-Octo-copters!!
Joined Feb 2007
Hi,
Do you get the same delay when you swap a motor on that ESC? You symptoms indicate a problem with that motor ESC. Do they all stop at the same time, or does the one that starts last stop first?
Cheers,
Jim
Quadrocopter and Tricopter Mega Link Index
jesolins is offline Find More Posts by jesolins
Old Jan 12, 2012, 09:18 PM
Adidas4275 is offline
Find More Posts by Adidas4275
manual flying apologist
Adidas4275's Avatar
United States, CA, Fresno
Joined Mar 2011
Do you use a y cable to calibrate or do you connect throttle cables to the RX
Adidas4275 is offline Find More Posts by Adidas4275
Discussion Hexa--5 motor starts and one delayed--??? quadman Multirotor Talk 3 Apr 19, 2012 03:45 AM
Discussion why is one motor going faster then rest? zowex Multirotor Talk 9 Nov 09, 2011 05:43 PM
Discussion Hking 10 amp esc and turnigy 9g motor no start, why? nemoskull Power Systems 5 Jul 14, 2011 09:50 AM
Why is a hot Actro 40-4 much harder to start than a cold one nigel99 Electric Heli Talk 5 Aug 08, 2004 04:17 AM
