Old Jan 11, 2012, 08:45 PM
fooyukvoon is offline
Find More Posts by fooyukvoon
The Need4Speed
fooyukvoon's Avatar
Malaysia, Perak, Ipoh
Joined Aug 2008
Can different Brands of ESCs give different results on similar settings?
Hi everyone,
New to this section of RCGroups. I m having a bit of a confusing problem with a few of my ESCs. In a few of my setups, I noticed big differences in Watts with different ESCs. For example, in my latest setup...
Sapac 4000kv Outrunner, 4S, 2200mah 25C, Hobbyking SS 60A ESC - 533W peak
With a Turnigy 100A DLux ESC - 687W
Nothing changed other than the ESCs. The Turnigy is on auto detect mode.
The Hobbyking SS was tested thru all setting, just could not get the same figures as the Turnigy.
Can a Hobbywing Programming Card be used to program a HobbyKing SS Series ESC?
How do we reset the ESC to autodetect mode? (the online manual from HobbyKing does not show)
Lipo was fully recharged every test.
Thanks.
Foo
fooyukvoon is offline Find More Posts by fooyukvoon
Old Jan 12, 2012, 08:08 AM
hoppy is offline
Find More Posts by hoppy
Space Coast USA
hoppy's Avatar
Space Coast
Joined Oct 2000
I just plug it in and see what happens. Some do, some don't. I would doubt seriously if the SS will work with that. You can set the battery type and brake - that's all.
Different ESC's, different results? In my experience, yes. You can say the same thing.
hoppy is offline Find More Posts by hoppy
Old Jan 12, 2012, 12:53 PM
TTRotary is offline
Find More Posts by TTRotary
Rangers Lead the Way
Joined Mar 2010
They should theoretically give similar maximum output. However, differences in motor timing, throttle calibration / curve interaction with the TX, and size of wires / connectors could make a difference. I assume the 100A comes with bigger wires, which pass more current without heating up (which increases resistance).
Don't think the HW / Turnigy programming card will work with the SS controllers.
TTRotary is offline Find More Posts by TTRotary
Old Jan 12, 2012, 07:47 PM
mjsas is offline
Find More Posts by mjsas
Joined Nov 2007
While the basic circuits are pretty much the same for different ESCs, the software is a different story. When the ESC is set for 10 degrees of timing is it really 10 degrees? Does the ESC output the same waveforms that are shown in the text books? If you think so you have much more faith in programmers then I do. In any case there are other software problems such as interrupt latency that programmers have to work around that means what you get may not be what you think it is.
mjsas is offline Find More Posts by mjsas
Old Jan 12, 2012, 08:13 PM
The Need4Speed
fooyukvoon's Avatar
Joined Aug 2008
Latest test on a setup I plan to put into the Hobbyking X-83, the figures I get :-
Sapac 4000kv Outrunner, 2650mah 40C 3S, 64mm EDF, Same Tx,Rx
Turnigy Plush 60A - AutoSetting - 687W
HobbyKing Birdie 60A - 533W
Hobbyking SS 60A - 505W
All on the same Lipo pack (Fully Balanced Charged before each test)
Found out only possible to program the HobbyKing SS/Birdie ESCs with Tx/Rx.
I am suspecting the ESC software or FET.
Foo
Old Jan 12, 2012, 08:30 PM
cyclops2 is offline
Find More Posts by cyclops2
United States, NJ, Frenchtown
Joined Mar 2003
Yes
Because there are different designs, components, tolerances, electronic chips & various suppliers still using people to control the quality.
How can we build it cheaper ???
The most important goal of all long lived companies.
All those cause constant changes in a product. By accident or design.
Most ARE DOING the best that they can.
cyclops2 is offline Find More Posts by cyclops2
Old Jan 13, 2012, 04:49 AM
ApexAero is offline
Find More Posts by ApexAero
Aka: Tom Jenkins
ApexAero's Avatar
United States, FL, West Palm Beach
Joined Aug 2008
Foo, IMHO reading more watts doesn't necessarily mean more power. It most likely is the cheaper means of parts and assembly on the ESC(resistance). You have two ESC's that are close on the readings and one not. Try the thrust test on a scale nose down and see which one does the best. Performance and efficiency don't always go hand in hand.
ApexAero is offline Find More Posts by ApexAero
Old Jan 13, 2012, 05:55 AM
The Need4Speed
fooyukvoon's Avatar
Joined Aug 2008
Ok, will try to get thrust figures of all 3 ESCs n post my findings.
Foo
Old Jan 13, 2012, 07:28 PM
hoppy is offline
Space Coast USA
hoppy's Avatar
Space Coast
Joined Oct 2000
Simpler to just measure the rpm with a tach.
Same prop, more rpm, more thrust......and, more accurate.
Old Jan 13, 2012, 11:58 PM
Philipp is offline
Find More Posts by Philipp
Philipp's Avatar
Grand Prairie, Texas, USA
Joined Mar 2000
I will second Hoppy on the RPM measurement.
Easiest of all tests (Using same prop, of course)
Philipp is offline Find More Posts by Philipp
Old Jan 14, 2012, 07:00 PM
The Need4Speed
fooyukvoon's Avatar
Joined Aug 2008
Now that would b a big problem. Can't think of where to find or buy a tachometer here. Have to search Hobbyking for it.
Foo
Discussion Motors start at different throttle settings on Twinstar... is there anything I can do NeveSSL Beginner Training Area (Aircraft-Electric) 4 Aug 06, 2011 01:02 AM
Discussion 3 different motors, too similar to be different sgomes Power Systems 1 Jun 21, 2011 06:06 PM
Help! Can PCM receivers be mix with different transmitter brands va02rcb Radios 2 Mar 17, 2006 06:00 AM
24 cell charge rate on different brands of chargers? gpeden Batteries and Chargers 10 Feb 23, 2003 10:02 AM
