Old Jan 11, 2012, 08:22 PM
spencer6891 is offline
Find More Posts by spencer6891
spencer6891's Avatar
NC
Joined Aug 2004
Cool
GWS Tiger Moth 400 on floats! (vid)
Here's a video of my TM 400's first amphibious adventure, taken last Sunday evening in perfect 65 degree North Carolina weather.
http://youtu.be/rVBbbCrIovk?hd=1
spencer6891 is offline Find More Posts by spencer6891
Old Jan 11, 2012, 11:16 PM
twn Chen is offline
Find More Posts by twn Chen
Taiwan, 北市
Joined Dec 2010
Hi Spencer,
A nice video and float TM400, you might be interested in reading this thread though friends over there were talking about the float E-starter. http://www.rcgroups.com/forums/showthread.php?t=527252
Chen
twn Chen is offline Find More Posts by twn Chen
Old Jan 12, 2012, 01:49 PM
warhead_71 is offline
Find More Posts by warhead_71
Always Ready!
warhead_71's Avatar
Chicago, IL
Joined Dec 2006
Looks great Spencer. My TM400 is getting a little long in the tooth but still a great flyer and easy to toss in the trunk. You might want to add a ventral fin on the tail so the tail doesn't "sag" as much when you roll/turn. I just toothpicked mine to the plane so it can be removed again if I want to convert back to wheels.
warhead_71 is offline Find More Posts by warhead_71
Old Jan 12, 2012, 03:47 PM
NC
Joined Aug 2004
Thanks for the tip, warhead. I actually need to add a water rudder as well. The plane is pretty much unsteerable without it.
Your moth looks GREAT! I'd love to do flying wires on my next one.
Old Jan 12, 2012, 04:34 PM
Always Ready!
warhead_71's Avatar
Chicago, IL
Joined Dec 2006
I don't use a water rudder to taxi. You just need to learn to "blip" the throttle in short blasts to push air over the rudder. By doing short blasts, it will turn the plane without much forward movement, so you can turn it really tightly, even in crosswinds. Once you get turned in the right direction, throttle up quickly to get on step and you should have plenty of air on the rudder for steering. It's sort of like starting a "stick" car in 2nd gear... you have to slip the clutch a little to get the car rolling before you can fully drop it into gear.
RE: "I'd love to do flying wires on my next one. "
Go to Micheal's and get the silver elastic stringing (for beaded necklaces)... it looks just the part and comes in silver, gold, or black). My TM has lasted me 2 years and barring mechanical failure (knock on wood) it should last me a couple more... it's just so easy and relaxing to fly that I doubt I'll need a replacement soon. I only wish they'd start making them from EPO.
Old Jan 12, 2012, 08:52 PM
twn Chen is offline
Taiwan, 北市
Joined Dec 2010
TM400 EPO kit is available at http://www.caliberhobby.com/EPO_kits.html
Probably you could find it out from other sources, too.
EPO foam is tougher but heavier than the EPS one. Some flyers hate to have the extra weight on it.
Chen
Old Jan 13, 2012, 11:09 PM
NC
Joined Aug 2004
Wow, thanks for all the advice. Curious, is your moth EPS or the EPO version? It looks smoother than mine. I'm debating whether to fiberglass my next one (EPS) or go to EPO for a smoother finish less prone to hangar rash.
Wanted GWS Tiger Moth 400 tarheal63 Aircraft - Electric - Airplanes (FS/W) 6 Nov 10, 2011 04:30 PM
For Sale 36" Newly Built Spad XIII & GWS Tiger Moth 400 (both receiver ready) LPU mtdoramike Aircraft - Electric - Airplanes (FS/W) 0 Apr 23, 2011 09:30 AM
Video GWS TM400 Tiger Moth on floats : Chicago, Lake Michigan warhead_71 Electric Plane Talk 9 Oct 28, 2009 09:54 PM
GWS Tiger Moth on floats Pat Daily Parkflyers 28 Dec 22, 2008 09:58 AM
GWS Tiger Moth 400 on GWS Floats ???? David A Ramsey Parkflyers 24 Oct 20, 2004 01:56 AM
