Old Jan 20, 2012, 10:27 PM
bill34207 is online now
Find More Posts by bill34207
Redneck Injuneer
bill34207's Avatar
Bradenton, Florida
Joined Aug 2007
Yeah I'm up past my bedtime so this will probably be full of typos.
Thank goodness I don't have to be up early in the morning.
Steering servos arrived today so I've been "busy" ever since getting home from work. Got one in and that's all it's going to get for now. Another one on the opposite side will come after there's a tiller arm to attach it to. One should be sufficient as long as the long push rod doesn't start flexing on me.
Ran the plumbing for the motor too. Used a mixture of the tygon line and aluminum tube. Kinda looks cleaner and the aluminum should flow water better too. (not to mention that I didn't have enough tygon to do full length lines on hand either)
bill34207 is online now Find More Posts by bill34207
Latest blog entry: Freewing F-5N Tiger 80 mm EDF
Old Jan 20, 2012, 11:06 PM
scorpion1 is offline
Find More Posts by scorpion1
I feel the need for speed!
scorpion1's Avatar
Southern U.S.
Joined Jun 2008
Looks good.........................i did the aluminum cooling line deal to Vader a bit back as well, does look clean, plus straight tubes allow better flow.........
scorpion1 is offline Find More Posts by scorpion1
Old Jan 21, 2012, 12:13 PM
Redneck Injuneer
bill34207's Avatar
Bradenton, Florida
Joined Aug 2007
I just might get this one wet tomorrow. Had to use one piece of silicon tubing to hook up the esc but the plumbing is finished. (until I can get some more tygon).
Still to do is shorten the wires on both the motor and battery to esc connections. I loaded it up with batteries to be sure and can cut the battery leads back to where the electrical tape closest to the bullets is wrapped around them.
Checked the cg while it was loaded and it's 1/8" shy of the 35% mark I was shooting for. Guess that would make it around 33-34% haven't done the math yet.
edit: stuck a few decals on it so it wouldn't be totally naked when it shows up at Ackerman tomorrow.
Old Jan 21, 2012, 06:16 PM
scorpion1's Avatar
Southern U.S.
Joined Jun 2008
Looks great Bill...............in your eagerness to get it wet, do yourself a big favor and double check everything! Trying to get it thrown together for a run tomorrow can lead to disaster if its all not right.
Bolts all tight
Cooling lines routed correctly
Cooling lines on well and secured by zip ties
etc...................
I like shortening all my wires as well...............saves amps!!
Old Jan 21, 2012, 06:43 PM
Redneck Injuneer
bill34207's Avatar
Bradenton, Florida
Joined Aug 2007
Yeah, this was a pretty quick build. The thread is showing 10 days old tonight. I think that may be a new record for me.
I did check all the bolts & nuts before installing the steering servo and cooling lines last night. (easier to get to that way).
Cooling lines are routed the right way (in on the low side out on the high) but didn't put zip ties on them. None of my other boats have them either. That tygon fits so tight it's almost impossible to pull back off by hand once the spit used for getting them on evaporates.
I'm not going to be pushing it hard tomorrow. Starting with a X455/2 and only going to run 9s 2p. It's mostly just to get it wet and check handling at a moderate speed. I'll probably just do a couple of laps and bring it in to check for leaks and temps before finishing off the packs.
Old Jan 21, 2012, 06:53 PM
osprey21 is offline
Find More Posts by osprey21
osprey21's Avatar
Palma Sola,Fla.
Joined Oct 2006
"In memory of Goldfinger, there is now Thunderball"
osprey21 is offline Find More Posts by osprey21
Old Jan 21, 2012, 06:56 PM
scorpion1's Avatar
Southern U.S.
Joined Jun 2008
I only use zip ties on the thru hull connections myself...............i know what you mean about the tygon being extremely hard to get off..........i usually have to cut a slit to loosen 'em up and then nip off the last 1/4" when re-fitting. I use tygon in all my boats as well.
That could be considered semi-mild for an intitial setup. I think a cat will want 10s though when ready for full race mode..........i bet the 455 is about what it will like on 10s................we'll see. Get some vid!!!!! (and gps.........58mph)
Old Jan 21, 2012, 07:29 PM
rotorkilla is offline
Find More Posts by rotorkilla
rotorkilla's Avatar
Stoke-on-Trent, UK
Joined Nov 2010
Very nice Bill and super fast
I'll look forward to seeing the vid on this one, but like Scorp said i'd double check everything.
Better safe than sorry
rotorkilla is offline Find More Posts by rotorkilla
Old Jan 21, 2012, 07:58 PM
Redneck Injuneer
bill34207's Avatar
Bradenton, Florida
Joined Aug 2007
I'd rather look at "Domino"
Old Jan 22, 2012, 04:17 PM
osprey21 is offline
osprey21's Avatar
Palma Sola,Fla.
Joined Oct 2006
I must say Bill, she ran quite well for her first "wetting", so, I give you... Domino Derval.
Old Jan 22, 2012, 04:24 PM
scorpion1's Avatar
Southern U.S.
Joined Jun 2008
I guess Bill's vid is "cooking"..............
Old Jan 22, 2012, 05:16 PM
Redneck Injuneer
bill34207's Avatar
Bradenton, Florida
Joined Aug 2007
Yep. I ran during "intermission" and haven't quite gotten to that one yet.
Anticipation......
Old Jan 22, 2012, 05:31 PM
Redneck Injuneer
bill34207's Avatar
Bradenton, Florida
Joined Aug 2007
While waiting here's a few stills of it in the daylight.
Old Jan 22, 2012, 05:36 PM
rotorkilla's Avatar
Stoke-on-Trent, UK
Joined Nov 2010
Old Jan 22, 2012, 05:53 PM
scorpion1's Avatar
Southern U.S.
Joined Jun 2008
Article G&C Hobby F-16 "Fighting Falcon" 64mm EDF from NitroPlanes Review Spackles94 Foamy EDFs 69 May 19, 2012 02:46 AM
Merry Christmas, FREE 13 Piece Precision Hobby Knife Set for postage and a promise. RacerPaul Non R/C Items (FS/W) 18 Dec 21, 2011 03:49 PM
Discussion 41" Falcon catamaran pcnewman Racing Boats - Internal Combustion 9 Jan 31, 2009 10:45 PM
Discussion 41" Falcon catamaran pcnewman Racing Boats - Electric 0 Jan 27, 2009 09:16 PM
