Old Jan 12, 2012, 08:01 PM
scorpion1 is offline
Find More Posts by scorpion1
I feel the need for speed!
scorpion1's Avatar
Southern U.S.
Joined Jun 2008
Coming along nicely!!! I'm a fan of BIG rudders and i like yours! Is that a 6 1/4" model?
scorpion1 is offline Find More Posts by scorpion1
Old Jan 12, 2012, 09:03 PM
bill34207 is offline
Find More Posts by bill34207
Redneck Injuneer
bill34207's Avatar
Bradenton, Florida
Joined Aug 2007
You made me have to go back to work so I could shoot another pic scorp. I have my rules about pages with no pictures.
It is the tall boy rudder. Not the one that came with the kit. The one that came with it is the tapered rudder like we both have on our 47" monos. I traded it for the square cut one that was on the Arapaho. Steve was out of the tapered rudder set for monos when I bought the one for the Arapaho and I wanted a square one for this one so it worked out well.
Anyways, bolted the motor into the mount so there could be a picture on this page.
bill34207 is offline Find More Posts by bill34207
Latest blog entry: Freewing F-5N Tiger 80 mm EDF
Old Jan 13, 2012, 06:28 PM
Redneck Injuneer
bill34207's Avatar
Bradenton, Florida
Joined Aug 2007
Crap
Ran into a little something that will slow me down this evening.
I was planning to get the motor mount bolted in but think maybe somebody over there in China might have started the New Year celebration a little bit early.
Rail spacing is spot on at the very rear where they lock into the transom but at the front where the motor will mount they come in about 1/2" too wide.
Looking at the spacing from rail to tunnel edge I'll only have to get the left (port) one loose and move it in. Time to get out the dremel and a cut off wheel.
Old Jan 13, 2012, 06:51 PM
scorpion1's Avatar
Southern U.S.
Joined Jun 2008
Just put a bushing on each side so you dont have to rip at all apart...........thats what i'd do.
Old Jan 13, 2012, 07:38 PM
Redneck Injuneer
bill34207's Avatar
Bradenton, Florida
Joined Aug 2007
Too late, it's already done except for tightening motor mount bolts and glassing it back in.
Wasn't too bad cutting it loose. I have a 90* head for my dremel that makes it easier to get into tight places with.
edit, now it's down to glassing the rail back in but that's not going to happen tonight.
Old Jan 14, 2012, 05:51 PM
Redneck Injuneer
bill34207's Avatar
Bradenton, Florida
Joined Aug 2007
I killed most of my day today working on my mean machine twin (changing the rudder & bracket) but still managed to get the rail glassed back in and stuffing tube installed.
Old Jan 15, 2012, 04:09 PM
Redneck Injuneer
bill34207's Avatar
Bradenton, Florida
Joined Aug 2007
It's been another day of not much accomplished on this one. Had to do laundry, go get groceries, etc. (the drawbacks to being a solo pilot)
Did get around to making up and glassing in the forward hatch hold downs and installed a lifting knob. While I was working with the resin added a layer of carbon fiber cloth to the inside of the hatch of my 47" mono too. After cracking the gelcoat on it last weekend when it barrel rolled and jumped from the water thought it would be a good idea.
Started adding some flotation down the sponsons of this one too. I'm thinking of maybe incorporating the battery compartment into the foam. Any thoughts?
Old Jan 15, 2012, 04:49 PM
osprey21 is offline
Find More Posts by osprey21
osprey21's Avatar
Palma Sola,Fla.
Joined Oct 2006
Didn't Hugh do something along that line with his (used to be Jim's) white cat?
PS... I have more of that foam if you need it.
osprey21 is offline Find More Posts by osprey21
Old Jan 15, 2012, 04:51 PM
scorpion1's Avatar
Southern U.S.
Joined Jun 2008
Thats what i did..............put the batts into the noodles.............i cut notches for the batts to fit. The noodles go all the way tot the transom.
Old Jan 15, 2012, 08:11 PM
Redneck Injuneer
bill34207's Avatar
Bradenton, Florida
Joined Aug 2007
Hugh's cat is what made me think about doing it. This one will pretty much finish off that last big piece of foam I got from you. Should be enough to finish it, but will take another chunk if it's laying around.
My biggest concern is that if it decides to do some aerobatics it might unlodge one or more of the packs and let them go bouncing around inside. I do like the idea of the extra flotation though.
Old Jan 18, 2012, 06:11 PM
Redneck Injuneer
bill34207's Avatar
Bradenton, Florida
Joined Aug 2007
I really haven't accomplished much the past couple of nights. Finished up the flotation foam installation Monday. Last night I finally put bullets on the esc, programmed it with the castle link and fired the motor up for it's 1st time since I bought it. Made a simple mount for the esc tonight and attached it.
Now I have to wait for the steering servo(s) to arrive. May use a single, may use two. Depends on how much luck Dave has with making me a double arm tiller for the speedmaster rudder.
Old Jan 18, 2012, 08:10 PM
scorpion1's Avatar
Southern U.S.
Joined Jun 2008
Lookin good my friend!!
I see a trend by the way.............First a 2028 in a 54"...............then a 47"................now a 41".................next up is a 34".............???? You're really juicing up smaller and smaller hulls with 8000+ watts!!!!!!!
Old Jan 18, 2012, 11:11 PM
ron1950 is online now
Find More Posts by ron1950
ron1950's Avatar
United States, MS, Brandon
Joined Jun 2011
scorp...bill has run out of room in the van for all his giant boats so he is down sizing lol
ron1950 is online now Find More Posts by ron1950
Old Jan 19, 2012, 05:19 AM
Redneck Injuneer
bill34207's Avatar
Bradenton, Florida
Joined Aug 2007
I noticed Diesel has posted an alert for the 34" EKOS. Hmmm (NOT)
Old Jan 19, 2012, 12:48 PM
rotorkilla is offline
Find More Posts by rotorkilla
rotorkilla's Avatar
Stoke-on-Trent, UK
Joined Nov 2010
Coming along nicely Bill, congrats
I was tempted by the ekos hull until i found they don't ship international, spoil sports
rotorkilla is offline Find More Posts by rotorkilla
Article G&C Hobby F-16 "Fighting Falcon" 64mm EDF from NitroPlanes Review Spackles94 Foamy EDFs 69 May 19, 2012 02:46 AM
Merry Christmas, FREE 13 Piece Precision Hobby Knife Set for postage and a promise. RacerPaul Non R/C Items (FS/W) 18 Dec 21, 2011 03:49 PM
Discussion 41" Falcon catamaran pcnewman Racing Boats - Internal Combustion 9 Jan 31, 2009 10:45 PM
Discussion 41" Falcon catamaran pcnewman Racing Boats - Electric 0 Jan 27, 2009 09:16 PM
