Old Jun 28, 2012, 02:09 PM
fallingdown is offline
Find More Posts by fallingdown
United States, OR, Portland
Joined Apr 2011
Originally Posted by rimshotcopter View Post
P.S. One of the biggest issue for me with this motor is, the shift diameter. It is only 3.17mm with a small retainer clip on the back. A motor with a longer bell, the magnetic force will keep the motor from coming apart, not true with these motors. it is very easy for the bell to come off if that clip should come free. Also the gyroscopic forces created by the large spinning prop will play havoc on the small shaft and bearings.
Yeah, that doesn't sound very good. Seems like mounting it upside down so the prop is pushing would be safer. I think I'll stick with the NX-4006... And hope that rc-timer comes out with another low kv motor like this that solves all the problems. I really like the bolt on threaded shaft adapters.
fallingdown is offline Find More Posts by fallingdown
Old Jul 02, 2012, 09:46 AM
ThePara is offline
Find More Posts by ThePara
Multicopter Nut
ThePara's Avatar
Romania, Bucharest
Joined Dec 2011
Originally Posted by fallingdown View Post
Neat looking quad! Got any video of it... from it?
Search for "Parathe13" on youtube.
ThePara is offline Find More Posts by ThePara
Old Jul 02, 2012, 12:49 PM
flyhigh300 is offline
Find More Posts by flyhigh300
United States, TX, El Paso
Joined Nov 2010
... hmm guys had plan to use some 30amp esc.. but I just noticed they are 2-4S rated..
What are you guys doing for ESC .. 5S or 6S .?
flyhigh300 is offline Find More Posts by flyhigh300
Old Jul 02, 2012, 01:02 PM
Dialfonzo is offline
Find More Posts by Dialfonzo
DiaLFonZo - UAV/Drone
Dialfonzo's Avatar
Canada, QC
Joined Oct 2007
Doh...!!!
Luis you did post before.. LOL
Dialfonzo is offline Find More Posts by Dialfonzo
Old Jul 02, 2012, 01:41 PM
rimshotcopter is offline
Find More Posts by rimshotcopter
rimshotcopter's Avatar
Joined Aug 2009
I am using 4S and never planned on going any higher. If I am not get the thrust required with a 4S battery, Abandon this project is in the mix.
Edited: Motors are rated Battery: 2-6Li-Po
rimshotcopter is offline Find More Posts by rimshotcopter
Old Jul 02, 2012, 01:59 PM
Joined Nov 2010
yeah ..
I plan to test at 4S .. with 14in props.. first..
One thing I find is I get less flying time that what most post.
I'm at about 3400ft above sea level.. maybe more..
wanted the frame to be setup up to have that option for bigger batteries..
Old Aug 12, 2012, 07:21 AM
Boogie3D is offline
Find More Posts by Boogie3D
United States, FL, Daytona Beach
Joined Sep 2005
Originally Posted by milo12 View Post
My MT4008-600 easily swings 16 inch props on 3S and 4S. I have run APC 16, the same carbon props shown above and the German carbon props by Flyduino which seem to be no longer sold.
What is the mounting bolt pattern and bolt sizes for the 5010 motor?
As I am looking for the best props for my MT4008-600 those carbon props maybe the key to success. Could you show us how did you mount those props? Right now I am running APC 14x4,7 on an octocopter on 3s. AUW is about 3300g and I am only getting 7 min flights on 5000mAh. Which props would be the best (I can upgrade to 4s)? Or should I just try to look for better and more efficient motors (maybe this 5010?)?
Boogie3D is offline Find More Posts by Boogie3D
Old Aug 12, 2012, 07:30 AM
renatoa is online now
Find More Posts by renatoa
Romania, Dolj, Craiova
Joined Sep 2007
According to the simulator, your 7 minutes are right.
15"@3s will raise a bit over 8 minutes, 14"@4s to more than 9 minutes.
renatoa is online now Find More Posts by renatoa
Old Aug 12, 2012, 07:38 AM
Joined Aug 2009
Question please, can you rerun this simulation using six motors verse eight? Not sure of the weight differences between the two configurations.
Old Aug 12, 2012, 09:19 AM
Joined Sep 2007
The octo will hover at about 51% throttle, for the hexa you must raise it at 68%, for same weight. Or decrease weight a bit under 3kg.
You can play yourself, just load the page below...
http://ecalc.ch/xcoptercalc_e.htm?ec...h=4.7&blades=2
then go to motor type, switch to custom and change kv to 600. That's because his model is not in the simulator database, and this is the closest.
PS: Yes, I trust this simulator, matched everything I flown so far within the claimed 15% estimation. For hover time and Amps drawn at least.
Depending on area where you are, the page can open in imperial units, and you should switch back to metric and change weight to 3300 grams manually.
Old Aug 12, 2012, 09:24 AM
Joined Aug 2009
Thank you.
Old Aug 12, 2012, 12:06 PM
Joined Aug 2009
This is a very useful and handy tool, is there any possibility of making it into a stand-alone program or application for a smart phone or PDA?
Old Aug 12, 2012, 01:15 PM
Joined Sep 2007
Yes, code behind is known, you need a programmer
Person, not device
Old Aug 12, 2012, 01:19 PM
Joined Aug 2009
Person, not device
Hmmm, I do not own a Smart Phone but a PDA and you know, Java runs on just about every platform out there today.
Make it open source and I am sure there will be many to answer the call.
Old Aug 12, 2012, 01:51 PM
EddieWeeks is offline
Find More Posts by EddieWeeks
EddieWeeks's Avatar
Baton Rouge, LA, USA
Joined Dec 2001
EddieWeeks is offline Find More Posts by EddieWeeks
Sold EZ Flite 35 Amp Brushless Motor ESC 14.00 shipped mpotter187 Aircraft - Electric - Power Systems (FS/W) 3 Nov 03, 2011 12:58 PM
Sold CF2812-14 1534KV Outrunner Brushless Motor rcbuilder247365 Aircraft - Electric - Power Systems (FS/W) 2 Aug 07, 2011 02:32 AM
Sold bl-2208/14 1450kv brushless motor REDUCED nitrodude71 Aircraft - Electric - Power Systems (FS/W) 11 May 15, 2011 07:03 PM
FS: Used AXI 4120-14 Brushless Motor sonny89108 Aircraft - Electric - Airplanes (FS/W) 4 Nov 12, 2003 01:12 PM
FS - AXI 4120/14 Brushless motor Bill Germanson Aircraft - Electric - Airplanes (FS/W) 5 Jun 28, 2003 08:07 PM
