Old Feb 03, 2012, 06:52 PM
rimshotcopter is online now
Find More Posts by rimshotcopter
rimshotcopter's Avatar
Joined Aug 2009
Yeap, I was told, these motors are hard on bearings however, Boca has some ceramic bearings that may be the answer. We will cross that bridge later.
rimshotcopter is online now Find More Posts by rimshotcopter
Old Feb 03, 2012, 08:12 PM
Mike Williams is offline
Find More Posts by Mike Williams
Lower!
Mike Williams's Avatar
Cedar Mill, OR
Joined Oct 2005
Really looking forward to the results of your testing!
Mike Williams is offline Find More Posts by Mike Williams
Old Feb 03, 2012, 08:16 PM
Sid3ways is offline
Find More Posts by Sid3ways
DJI Supporter
Sid3ways's Avatar
Swanton, OH
Joined Jul 2007
Glad to see you received them, now let's get some results!
Sid3ways is offline Find More Posts by Sid3ways
Old Feb 04, 2012, 09:32 AM
Joined Aug 2009
I came to a decision, I will attempt to purchase some of the 16" Carbon Fiber blades or similar verse trying to adapt any of the standard props used now. May as well go for the gusto.
Old Feb 05, 2012, 11:20 AM
broadwing is offline
Find More Posts by broadwing
Joined Oct 2011
Mounting prop 15"
What do you think of this why of mounting a 15" prop??
broadwing is offline Find More Posts by broadwing
Old Feb 05, 2012, 11:40 AM
Joined Aug 2009
I think that is a great way of doing it. Question, where did you purchase your props?
Old Feb 05, 2012, 02:25 PM
Joined Oct 2011
rimshotcopter,
PM,
rgds
Koos
Old Feb 05, 2012, 02:53 PM
Joined Aug 2009
Thank you.
Old Feb 05, 2012, 03:10 PM
Sid3ways is offline
DJI Supporter
Sid3ways's Avatar
Swanton, OH
Joined Jul 2007
So do you have some props on the way then?
Old Feb 06, 2012, 10:40 AM
Bare is offline
Find More Posts by Bare
Canada
Joined Nov 2000
OK... what makes this thing attractive?
Beyond the larger moment arm provided by it's large diameter.
The windings certainly look to be as crappy as any I've yet seen
Bare is offline Find More Posts by Bare
Old Feb 06, 2012, 12:16 PM
rogue277 is offline
Find More Posts by rogue277
Joined Dec 2010
It's probably the lowest kv we know of in this size of motor. usually low kv motors are awfully big, but this one is a good size for a multirotor. Low kv lets you use direct drive on a large prop. It also drives required current down for a given power (while driving required voltage up). A larger prop has a higher g/W for a given thrust, as long as you have the right motor spinning it. With this we might be able to break a flight duration record.
rogue277 is offline Find More Posts by rogue277
Old Feb 07, 2012, 02:35 PM
milo12 is online now
Find More Posts by milo12
Joined Feb 2011
Where are 16 in carbon props sold?
What is the height of the motor from base to the top of the bell where the props mount?
milo12 is online now Find More Posts by milo12
Old Feb 07, 2012, 02:48 PM
Sid3ways is offline
DJI Supporter
Sid3ways's Avatar
Swanton, OH
Joined Jul 2007
http://flyduino.net/15-Handmade-Full...t-2-CW-2-CCW_1
Old Feb 07, 2012, 02:53 PM
Joined Aug 2009
Question number one, I have no answer to that, but for question number two, it is about 7MM from the base to the bell.
Old Feb 23, 2012, 05:11 PM
Joined Aug 2009
I did some basic testing today with one of the RCTimer 5010 motors in connection with a 16x6 wooden prop I purchased off of Ebay. The prop was purchased for this reason only and was never intended to be used on a flight copter. Well, I am less then happy with the results and extremely happy I did not purchase those very expensive Carbon Fiber props now being sold by RCTimer. For the life of me, unless the CF props are extremely efficient and the copter is abnormally light, I just do not see getting the extended flight times now being reported.
In this test (not the most accurate), the amperage was about 8 amps on a 3S battery. This yield about 15.8 ounces of thrust at about 1.5ms PWM. I like using 1.5ms because that is about mid-stick and where I like to have my copters hover at. So for the sake of conversation, lets use a typical quad, so that would be four times 8 amps or 32 amps to yield about four pounds of thrust. Using a 5000mah battery (Assuming we would run it completely dead), that would net a flight time of about 9.375 minutes. I just don't get it.
RCTimer 5010 with 16x6 Props (2 min 54 sec)
Sold EZ Flite 35 Amp Brushless Motor ESC 14.00 shipped mpotter187 Aircraft - Electric - Power Systems (FS/W) 3 Nov 03, 2011 12:58 PM
Sold CF2812-14 1534KV Outrunner Brushless Motor rcbuilder247365 Aircraft - Electric - Power Systems (FS/W) 2 Aug 07, 2011 02:32 AM
Sold bl-2208/14 1450kv brushless motor REDUCED nitrodude71 Aircraft - Electric - Power Systems (FS/W) 11 May 15, 2011 07:03 PM
FS: Used AXI 4120-14 Brushless Motor sonny89108 Aircraft - Electric - Airplanes (FS/W) 4 Nov 12, 2003 01:12 PM
FS - AXI 4120/14 Brushless motor Bill Germanson Aircraft - Electric - Airplanes (FS/W) 5 Jun 28, 2003 08:07 PM
