Old Jan 11, 2012, 10:52 AM
fiego007 is offline
Find More Posts by fiego007
Joined Aug 2008
Quad or Hexa for AP
Hey
I am a bit confused. I see great videos of "heavy" quadros who carry big cameras and it all looks smooth. But most of the time its either a hexa or an octo. Why should I go for hexa or octo if I can achieve the same with a "heavy" quadro
fiego007 is offline Find More Posts by fiego007
Old Jan 12, 2012, 03:42 PM
signguy is offline
Find More Posts by signguy
signguy's Avatar
Swansea, Massachusetts
Joined Dec 2004
Originally Posted by fiego007 View Post
Hey
how much do you REALLY have to lift?? A hex or octo can have more, smaller motor/prop combos for the same lift as a heavy quad. the smaller motors will respond quicker to the flight controller making the hex/octo more stable.
if you're just lifting 10-12 oz build a quad, more than that maybe a hex is better..... just my opinion, 'm sure others will have different opinions
signguy is offline Find More Posts by signguy
Old Jan 12, 2012, 03:58 PM
fiego007 is offline
Joined Aug 2008
good point
in the end it should be a sony-nex5 and a decent frame
Old Jan 13, 2012, 04:21 AM
GliderGuideMan is offline
Find More Posts by GliderGuideMan
Kite flying SCRAPS member
GliderGuideMan's Avatar
Hampshire, UK
Joined Apr 2004
With a Nex 5 I would have thought you might want an element of redundancy. If a motor goes goes on a quad, well start saving your pennies for a new Nex 5, whereas on a hex you may be able to bring it down in some sort of controlled landing
GliderGuideMan is offline Find More Posts by GliderGuideMan
Old Jan 13, 2012, 12:25 PM
sparklet is offline
Find More Posts by sparklet
Cumbria in the U.K
Seconded.
He's right. If a motor or prop fails on a quad then it will turn into something resembling a flying manhole cover and plummet straight down. Usually after flipping upside down first !
With a fixed wing model you can usually glide back down. With a tricopter or quad there is nothing to stop it dropping straight out of the sky if a motor or prop goes bad.
sparklet is offline Find More Posts by sparklet
Old Jan 14, 2012, 10:12 AM
fiego007 is offline
Joined Aug 2008
that's the best reason to go for 6 or 8 rotors pfcourse
did not even think of thatone to be honest....
Wanted Looking for a quad or hexa RTF setup w/ Gimbal and Camera Mount (650 size) brianshell Aircraft - Electric - Multirotor (FS/W) 2 Jan 09, 2012 03:09 PM
Discussion Quad or Hexa or 2 Tri's? healthyfatboy Multirotor Talk 8 Nov 20, 2011 09:15 AM
Discussion Folding frame for AP - tri, quad, Hexa, Okto danielpetrescu Multirotor Talk 9 May 10, 2010 01:25 AM
Question Tri/hexa-copter or Quad/Octa-copter and Spartan AP2000i or Helicommand Arthur P. VTOLs 2 May 20, 2007 04:02 PM
