Old Jan 11, 2012, 02:00 AM
oren_ben_nun is offline
Find More Posts by oren_ben_nun
Joined Aug 2011
I need recommendations for Brushless Motor & esc for my ArduPilotMega 2.0
I ordered the ArduPilotMega 2.0
I need recommendations for Brushless Motor & esc to my Quadcopter
My budget for this electronics about $ 100
Need to adjust for the 3-cell batteries
Second question
Is this frame in this way is supported by the board and if so is it recommended the sense of stability and performance
http://www.goodluckbuy.com/fiber-gla...lticopter.html
Is this OK?
I found these ESC:
http://www.goodluckbuy.com/30a-brush...er-4-pack.html
These engines:
http://www.goodluckbuy.com/xxd-a2212...er-4-pack.html
oren_ben_nun is offline Find More Posts by oren_ben_nun
Old Jan 11, 2012, 03:36 AM
kinderkram is offline
Find More Posts by kinderkram
OS Sponsor
kinderkram's Avatar
Germany, NRW, Dusseldorf
Joined Jun 2010
Yes, you can use this frame since the motor mounts form a standard quad. Can't tell about the durability and stiffness of this item - but the parts where the arms are mounted on the center plates look a bit short. If the center plate isn't stiff enough I'm afraid you can bend the arms up & down.
Other than that you can't go wrong at that price scale.
The other links are dead btw. You could use these Hobbywing ESCs:
http://www.goodluckbuy.com/hobbywing...er-4-pack.html
and these motors (which look like Suppo motors):
10" props would do a good job. If you're a beginner in this hobby you should also order spare parts - especially some sets of props...
kinderkram is offline Find More Posts by kinderkram
Old Jan 11, 2012, 06:15 AM
flitelab is offline
Find More Posts by flitelab
flitelab's Avatar
Canada, NS, Halifax
Joined Feb 2010
Agree with kinderkram, that setup should be fine. Suppo motors are decent quality for budget motors and Hobbywinf ESCs are the most common.
The frame should be decent enough, just be prepared for possible missing bits and pieces and no instructions. I got the X525 frame from GLB and it was basically a bunch of loose parts thrown in a box, got it together ok but some wrong sized bolts and pieces. GLB is a bit of the luck of the draw on what you get at times.
flitelab is offline Find More Posts by flitelab
Site Sponsor
Old Jan 11, 2012, 06:17 AM
flitelab is offline
flitelab's Avatar
Canada, NS, Halifax
Joined Feb 2010
This is a good overview of what GLB can be like, matches my experience exactly. I still order from them but don't expect a high end experience.
Unpacking a composite multirotor frame from GoodLuckBuy.com (7 min 5 sec)
Site Sponsor
Old Jan 11, 2012, 08:38 AM
zerosight is offline
Find More Posts by zerosight
Deutschland
Joined Nov 2011
I received today a similar hexa-frame from GLB. If the material of your centerplates is the same, it should be stiff enough in combination with those motors. The quality meets the price, especially according to the accuracy of the drilled holes of the arms.
But as a beginner, the lifetime of those arms aren't long enough to worry ;-)
(check your local dealer for some spare aluminium tubes, you might need them sooner or later)
zerosight is offline Find More Posts by zerosight
Old Jan 12, 2012, 09:51 AM
Joined Aug 2011
thanks
props 10 *4.5 ?
Old Jan 12, 2012, 10:11 AM
OS Sponsor
kinderkram's Avatar
Joined Jun 2010
Originally Posted by oren_ben_nun View Post
thanks
props 10 *4.5 ?
Yep, i.e. these:
http://www.goodluckbuy.com/gemfan-10...r-2-pairs.html
Do yourself a favour and order more than you think you'll ever need!
Trust me - you will need spares sooner or later.
Old Jan 12, 2012, 10:43 AM
Deutschland
Joined Nov 2011
I would give 9" or 8" props a try. 1000 kV with 52g motors on 3s with 12 a peak could heat them up to much on 10". (http://flyduino.net/Propellers)
Discussion Your recommendations (motor/esc/lipo) for this 22" super vee??? nordwest Racing Boats - Electric 1 Dec 23, 2011 01:50 AM
Discussion Need help on a motor/esc combo for my trainer. superfastwrx Power Systems 3 Sep 27, 2011 12:47 PM
Discussion bought 60 size NTM motor need ESC recommendations WBFlyer FPV Talk 8 Jun 28, 2011 04:30 PM
Wanted I am in need of a brushless motor and esc for my Trex 450 SE have stuff to trade dravengary Aircraft - Electric - Power Systems (FS/W) 5 Feb 16, 2009 03:25 PM
Need brushless motor recommendations for Hobby People Wild Wing surfimp Flying Wings 5 Sep 11, 2005 10:32 AM
