Old Jul 09, 2001, 10:55 PM
AirVenture is offline
Find More Posts by AirVenture
He wasn't always evil
AirVenture's Avatar
SW Wisconsin
Joined Jul 2001
Need help on buying new Battery!
Hey Everybody!
I'm getting rather sick of having one battery pack for my Megatech Merlin (7min flight times) and was thinking about getting maybe a couple more. Of course I could always get a new one from Megatech, but I'd like to see if its possible to get a better performance batt. The current battery only says that it is 8.4V on the lable, and has seven cells. I know I'll have to get a different charger but I was wondering what...if any...batterys can be used with megatech products. I'm not even sure the connectors and cells are standard size or not or even if the ESC can handle different batts (this is my first plane!). Well let me know if you need any more info to answer my question...I'll do my best.
Thanks again guys...I love this website!!!
-Brett (a newly aquired R/C addict)
PS...any flyers in the Wisconsin-Iowa-Illinois Tri-State area??
[This message has been edited by AirVenture (edited 07-09-2001).]
AirVenture is offline Find More Posts by AirVenture
Old Jul 09, 2001, 11:24 PM
KOMET 44 is online now
Find More Posts by KOMET 44
D.G.B.
KOMET 44's Avatar
Southington, Connecticut, United States
Joined Jun 2000
next easy thing to do is go up in cell count.i fly 8x2000 cells in my TWIN STAR while other people in my club use 7x1700 cells.thats the differnce between flying and just getting in the air and making a couple of 6min laps.What size are the cells you are useing?? sub "c". GOOD LUCK stefanP
KOMET 44 is online now Find More Posts by KOMET 44
Old Jul 10, 2001, 03:48 PM
AirVenture's Avatar
SW Wisconsin
Joined Jul 2001
I'm not sure on the cell type, but each cell measures one inch long by half an inch wide. Anybody know what cell this is??
-Thanks agian
-Brett
Old Jul 10, 2001, 04:08 PM
tic is offline
tic
Find More Posts by tic
tic
thunderscreech
tic's Avatar
United States, MI, Gaylord
Joined Dec 2000
I don't know what kind of cells you have, but if you get NiMH instead of Nicad.. you could double your flight times for around the same weight!
tic is offline Find More Posts by tic
Old Jul 10, 2001, 08:20 PM
hoppy is offline
Find More Posts by hoppy
Space Coast USA
hoppy's Avatar
Space Coast
Joined Oct 2000
Check this site for battery sizes. You can go with an equivalent size NiMH and one more in cell count.
hoppy
-Thanks agian
-Brett
hoppy is offline Find More Posts by hoppy
Old Jul 10, 2001, 08:48 PM
tripster is offline
Find More Posts by tripster
Ontario, Canada
Joined Sep 2000
This is what I can gather from their website.
Wingspan:
44 Inches (1117mm)
Wing Area:
465 Square Inches
Length:
30 Inches (762mm)
Weight: 15 oz. (420g)
Propeller: 12 x 8 (304 x 203mm)
Gear Ratio:
5.6:1
Functions:
Rudder, Elevator & Variable speed throttle
Part Number:
MTC9910
Definately a slow flyer. Cells are probably no bigger than 300ma. I believe GWS sells small ma packs for slowflyers. Also check out http://www.hobby-lobby.com/nicads.htm
They have a pretty good selection. I would also post your question in the slowflyers forum. Do a search there as well.
tripster is offline Find More Posts by tripster
Old Jul 10, 2001, 09:01 PM
Dr. Jet is offline
Find More Posts by Dr. Jet
H301 Libelle Pilot
Dr. Jet's Avatar
Oceanside, California
Joined Sep 2000
http://flydma.com/ Best batteries around. Steve will build any size, type, and configuration you need.
Dr. Jet is offline Find More Posts by Dr. Jet
Old Jul 10, 2001, 09:03 PM
AirVenture's Avatar
SW Wisconsin
Joined Jul 2001
Yeah tripster, everthing sounds right.
From Dr. Jet's website I found out that the batterys are 600mAh. Now the only question is if the connectors will work??????
It doesn't look like the connectors will work with my plane. It sounds like megatech uses a special electical system to make sure no aftermarket stuff can be added. Nothing looks compatable, even the charger won't do other batteries. I might just order some from Megatech. I think a new plane might come in the near future anyhow!
-Thanks for the great help! I'll see what the slowflyer forum has to say.
-Brett
[This message has been edited by AirVenture (edited 07-10-2001).]
Need help on mixing new and old Ni-Cds, balancing required? dispatch Batteries and Chargers 4 Nov 07, 2005 05:40 PM
Help! need help on my new ep m24 peekachew Micro Helis 0 May 16, 2005 10:44 AM
Need Help on choice of new model! DeuceTrinal Foamies (Kits) 13 Sep 23, 2003 03:27 PM
Need Help on choice of new model! DeuceTrinal Parkflyers 7 Sep 21, 2003 11:42 PM
Need help on buying - Eco 8 - Helo cmikecs Electric Heli Talk 6 Mar 28, 2003 07:14 PM
