Espritmodel.com Heli Air
Old Jan 16, 2012, 09:33 AM
jtlsf5's Avatar
United States, CA, Folsom
Joined Jul 2007
Originally Posted by Glauco View Post
I gave up trying to explain to JT I wasn't abusing the Nats lines and winches, just that the wings bent a lot on launch.
But this one belongs to our own Chris Lee and it is all his fault
G
Yikes, how did I get sucked into this one? However its true, gotta keep you leadfoots on your toes and aware of what you're doing. You guys don't have to fix the mess left behind...
JT
jtlsf5 is online now Find More Posts by jtlsf5
Old Feb 27, 2012, 02:36 PM
Joined Jul 2002
Repair update
Here is an update on the repair. As suggested by Dr. Drela I installed two carbon laminates, 15 cm long each, and tested the center panel with 150 lbs concentrated at the center.
Must say it was really scary to keep adding all that weight and watching the wing flex to an extreme. So much flex that at my first try the center touched the table so I had to prop the tips up even more.
The attached video shows only unloading the wing but you have an idea of the flex.
I was also pleased with the result of vacuum bagging a new piece of skin. Other than the color that didn't match 100% the original, the end result was fairly smooth, maybe you can see it at the pictures.
Chris has not flown the plane yet after the repair so there may be more to come.
Spar Test (1 min 45 sec)
Glauco is offline Find More Posts by Glauco
Old Feb 27, 2012, 03:20 PM
Detail Freak
target's Avatar
Harbor City, CA
Joined Oct 2003
Great job!
I have a question about the CP spar before I start on my wing project-
Someone stated that you could make your own CP spar with the 5* dihedral preformed in the center, so that the .007" pieces would not be necessary to shore up the bend in the stock straight spar caps.
My question is: What material should I use for this, and what layup schedule??
I have 4.1oz Uni-carbon (80/20 carbon/glass) in stock, but am not at all opposed to buying some other material if its better in some small way (pure uni-carbon?).
Is peel-ply a good idea to rid the home-grown spar cap of excess epoxy, and give some texture for bonding??
Thanks in advance,
Target
target is offline Find More Posts by target
Latest blog entry: Stork 4 Pro X-tail from...
Old Feb 27, 2012, 03:29 PM
LSF - IV
Hostage-46's Avatar
Joined Jan 2003
Really nice work...
Hostage-46 is offline Find More Posts by Hostage-46
Old Feb 28, 2012, 12:01 PM
Pitch - Roll - Y'all
St. Louis
Joined Oct 2001
Here is an update on the repair. . . .
http://www.youtube.com/watch?v=wii8bXjlYhU
Hey Glauco, there are only a fixed number of "flexes" in any wing and you're using them up unnecessarily on the workbench. Now Chris has two fewer pings in the quiver.
Brian Molloy is offline Find More Posts by Brian Molloy
Question why did the last one crash, what did you learn post mortem. xrx1113 Electric Plane Talk 63 Jan 12, 2012 12:26 PM
Discussion Why do bricks fail so often? helinut2 Micro Helis 13 Sep 19, 2011 12:13 PM
Discussion why dont we build the spar first? flexsphincter Sailplane Talk 14 May 09, 2011 04:12 AM
Discussion Why did Lipo's fail? DLC Batteries and Chargers 4 Jul 30, 2009 11:00 AM
Why did my GWS A-10 come with a carbon spar? Darn Servo ! Electric Ducted Fan Jet Talk 0 Jul 01, 2003 11:26 AM
