Australia, VIC
Joined Dec 2011
An old British Girl
A very old girl from a bye gone era ..
Im the second owner , the original owner bought the engine from England and actually flew Class A with it .. When I got it , it was some what worn , but back then I had some ED parts engines , and I was able to re-build it internally , I had enough parts to fix two other engines as well for other people .. This one still needs some running in , and is a very good sample of the breed . |
Actually Ray, I'm sure the piston man & liner man were very close. PL fit was & still is very nice.
The problem for me is the rear induction system, either I have assembled it incorrectly (not an impossibility) or it just plain doesn't work the way it should. I haven't really invested the time in getting it sorted, as I have too many other motors that work the way I want them to. And after all I'd rather fly than tinker with stuff I don't know much about. Regards G |
Australia, VIC
Joined Dec 2011
Ok
There are two ways the disc can go ..
The right way . and the wrong way .. Just remove the venturi , and check when the disc opens .. Should open some time after Bottom Dead Centre ... just rotate the engine in the direction it runs , and see if its opening 40 to 50 deg after BDC .. If its not , the disc has been aligned the wrong way or incorrectly ... If you rock the engine around BDC , the disc should follow precisely , if it stops for any reason the pin that engages the disc , may not be seated in the little hole that its supposed to drive the disc ... Getting old !!! , also , what size is the venturi , they came with two , 4.5mm and 6mm , even the 4.5mm was a little too large to run suction , if you want to run it , you might want a 3mm or 3.5mm venturi made .. |
Now that's interesting. Mine is somewhat like yours with the missing exhaust stacks although mine still has the raised part front and rear. I've been told the exhausts had been cut off (apparently quite common back then) but for the life of me I can't figure out how they could have been cut off and still retain the same surface finish as the rest of the crankcase, especially how the upper part of the crankcase has been rounded with no machining marks whatsoever.
Mine is actually a mix of 2 engines. The original was a Mk1 that had sat in a box for who-knows-how-many-years (the box is marked as MARK III Series 2 but the photo shows a Mark I) and, as you can see from a photo below, it didn't look all that great . However I remembered I had an old crankcase in a drawer somewhere which is what's now on the engine and I believe is a Mark II. That crankcase went under in the '74 Ipswich flood and was given to me. After a bit of a wash it came up perfect, as were the original bearings which I left in there during the cleaning (ultrasonic). Unfortunately I had to use the original backplate which is terribly corroded but still useable but the engine itself feels silky smooth with lovely compression. If I ever get some diesel fuel I'll give it a run.
Australia, VIC
Joined Dec 2011
Glow
I never thought much of the plain bearing glow Taipans till I came to this one , actually runs well ..
I had a few when younger and they were dogs , so was a little surprised when this one actually ran well [ and produced some power ] |
My Tyro is in the Stiletto. One of my favourite motors. Powerful, easy starting just a lovely thing. Regards G |
I had a "Gold top" Taipan that I converted to diesel in the mid 70's, to use in FAI team race. My brother and I used it to come in second at the 1976(?) Bunbury nationals against Bugls and Rossis etc. We set fastest time in the heats and only lost the final due to a line tangle / prang. ![]() Sorry, no fotos, I loaned it to a friend years ago. I hope he still has it, I must look him up..... |
Australia, VIC
Joined Dec 2011
Wow
Would love to hear more about that converted Gold Top Steve , sounds like a very interesting tale .. [ Love engine talk ]
Another motor , Enya 15D MK1 , single ball race ... Never saw one break , but apparently could break the crank , I think Robbin Heirn ran one in Vintage Class A before everyone went CS Oliver [ replica ] Never ran this MK1 , but I did run a MK2 , and will dig it out and post a picture next ... [ This one is still internally in good condition ] |
Back when Rossi's cost a packet, and Bugls must have been made of gold, it was a somewhat agricultural solution for an always broke farm boy. A new engine could be bought for about $20~25 bucks in the control line (no RC carby or muffler) version. A new piston and liner was less than $10 bucks from memory, and the local bush hobby shop had them in stock. The big plus was we were never scared to practice with the motor and wear it out, where as the Bugl owners only bought theirs out for the state champs or nationals. |
Australia, VIC
Joined Dec 2011
Wow
When it got harder to start at the pit stops, it was time for a rebuild.It was easy to tune for a solid run, and had no real vices that I recall. When I first built it, I put it in a profile Goodyear model and it didn't work at all. Just as it would come on song, it would straight away overheat and sag bigtime. I thought it was the rear exhaust overheating the rear of the motor. I still went ahead and built a team racer, with plenty of cooling to the rear of the engine. It was a different motor entirely then, and ran beautifully. As I have no pics atm, here is a drawing to explain the mods a bit better. |
Australia, VIC
Joined Dec 2011
Thank you
I understand what you did , and its brilliant .. [ Just love it ] I purchased some ZOM glow motors way back , and they ran like DOG's [ not Greyhounds ] but like Corgi's .. Airborne mag gave them a rave , so I purchased 3 , they were awful .. Never could get them to work as glow motors .. So when I had my old Qualos(?) Lathe I converted one to diesel , to see if it would run as such , and to my surprise , actually ran reasonably well . No power house , but well enough to pull a model around on a 8x4 with some vigour .. I still have 2 in parts so if I ever get another lathe , they will be moded to diesel . |
Australia, VIC
Joined Dec 2011
Enya 15D MK2
The Enya 15D MK2 , what a sweet motor , once you got it started and warmed up , till then it was a bit of a beast ... [ Thank goodness for the CS Oliver replicas ]
This one got modified by accident : ( )A friend had a MK2 as well , but with a broken crank , so he asked me to make him a new one , which I did , but his rod was badly worn , so I tried to bush it and the big end blew apart when trying to press fit the bush .. The rod alloy was turning into white powder on the inside [ Crystallized ??? ] anyway's , it was easier to give him my con rod , and make myself a new one .. Unfortunately some where along the way I stuffed up , and made the rod 1mm or so too long , lowering the exhaust timing way much .. I was too lazy to make a new rod , so raised the exhaust port and moded the by pass to make it more to my liking .. I gained some 2000RPM from this folly on the ground ... ![]() So that's more or less how I accidentally modified my Enya 15D MK2 ... Added picture of DIY rod |
| Thread Tools | |
| Discussion Control Line Team Racer plans and pictures | perttime | Control Line | 257 | Today 12:45 AM |
| Sold McCoy RedHead .35 control line engine $20 shipped | revkev | Aircraft - Fuel - Engines and Accessories (FS/W) | 2 | Nov 07, 2011 11:39 PM |
| Sold OS-40-FPS, Control Line Engine "New" $80.00 Shipped! | 1stGeppetto | Aircraft - Fuel - Engines and Accessories (FS/W) | 4 | Oct 17, 2011 11:38 PM |
| Sold NEW in the box OS Max 46LA-S control line engine | Diane@lazertoyz | Aircraft - Fuel - Engines and Accessories (FS/W) | 0 | Jun 18, 2011 03:45 PM |
| For Sale o.s .19 control line engine | i-fly-any-and- | Aircraft - Fuel - Engines and Accessories (FS/W) | 0 | May 31, 2011 04:45 PM |
