Old Dec 05, 2012, 03:52 AM
flyinglog is offline
Find More Posts by flyinglog
1234567
flyinglog's Avatar
Deutschland, Berlin
Joined Aug 2011
hello !
thanks for the pics of the USE !
and I wanted to say, the AP15 Yellowjacket is a good engine , you should just use another muffler with 5-6mm exhaust and a small prop , like 7x4 , then it will run like a moskito on speed.
Regards !
flyinglog is offline Find More Posts by flyinglog
Old Dec 05, 2012, 04:17 AM
locktite401 is offline
Find More Posts by locktite401
Joined Nov 2008
Originally Posted by flyinglog View Post
hello !
Regards !
Hobbyking in Hong Kong has the AP15 Yellowjacket on sale for about USD32.
Ray
locktite401 is offline Find More Posts by locktite401
Old Dec 05, 2012, 08:28 PM
old4570 is online now
Find More Posts by old4570
Australia, VIC
Joined Dec 2011
Yeah
Ray
Thats where mine came from ..
Now I want to see the AP09
old4570 is online now Find More Posts by old4570
Old Dec 05, 2012, 11:47 PM
pmackenzie is offline
Find More Posts by pmackenzie
I don't want to "Switch Now"
pmackenzie's Avatar
Toronto (Don Mills), Canada
Joined Dec 2002
HiModel has it in stock, also the .06
http://www.himodel.com/sort.php?sub1=BS&brand=4&page=2
Pat MacKenzie
pmackenzie is offline Find More Posts by pmackenzie
Old Dec 06, 2012, 03:09 AM
greggles47 is offline
Find More Posts by greggles47
Greggles47
greggles47's Avatar
Sydney OZ
Joined May 2007
I have a couple of the .09's One in original glow the other converted to diesel.
Both swing 7X4 props in Ukranian Combat wings and go like a cut cat.
greggles47 is offline Find More Posts by greggles47
Old Dec 06, 2012, 06:59 PM
1234567
flyinglog's Avatar
Deutschland, Berlin
Joined Aug 2011
my ap 09 does 30k with lifted exhaust and reso on a 5x3 apc.
the piston pin clip broke once at this speed , but i reworked it on a new P/L assembly, now its fine and steady.
Regards !
Old Dec 07, 2012, 01:11 AM
Joined Nov 2008
I was told quite a while ago now, that the AP 09 was a consumer version of the Chinese SY 09 c/l speed motor that was marketed during the mid 1990's
They sure look identical!
Ray
Old Dec 07, 2012, 03:39 AM
Greggles47
greggles47's Avatar
Sydney OZ
Joined May 2007
Ray
Right down to the funny finless head with the bolts sitting proud.
G
Old Dec 07, 2012, 04:01 AM
1234567
flyinglog's Avatar
Deutschland, Berlin
Joined Aug 2011
a shame that they machine off the exhaust stud on the AP. The threaded reso adapter for my engine is breaking off really often.
Regards
Old Dec 07, 2012, 04:44 AM
Greggles47
greggles47's Avatar
Sydney OZ
Joined May 2007
I'm not sure what revs they spin, but they give lively performance in the Combat wing. Taipan 7X4 props
Old Dec 07, 2012, 10:44 AM
aspeed is offline
Find More Posts by aspeed
Canada, ON, Cottam
Joined Jan 2012
My AP .09 was revving about 16,900 rpm with a MA 7-4 prop, no muffler and 10%. It could still need a bit of breaking in. 15,200 with muffler, and 16,100 with the hole opened up on the stinger to 6mm. I had to make a new stinger and redrill and tap the muffler. The stock stinger can be unscrewed to give about a 5mm hole. It is an m6 thread. I made mine 6mm because that is the size for F2D combat although chances are slim I will run with them. I would need to get a little better to keep up with Pat.
aspeed is offline Find More Posts by aspeed
Old Dec 07, 2012, 10:53 AM
aspeed is offline
Canada, ON, Cottam
Joined Jan 2012
Not sure if I posted pics here yet, but I made an adapter for a pipe, and a CL venturi and needle valve, more for the .15, but it would work on the .09 too.
Old Dec 11, 2012, 06:33 AM
Joined Nov 2008
I've spent a very wet Tuesday afternoon converting an almost unused Rossi C21 Buggy motor to use in control line. I bought it off ebay for about usd58 months ago.
It just needed a new sleeved spinner nut, a venturi and tangential NVA, and a DuBro 6.32 pressure nipple in the backplate. The tall head/cooling fins were cut off with a hacksaw and faced as shown. The prop driver and tapered collet were from another engine.
It has excellent compression, and while someone has run it, I'd guess that it wasn't for long.
The lugs are engraved with "GP Custom" and "GP #2", and there is some internal sculpturing of the crank web etc.
Anyone know who GP might be?
Old Dec 11, 2012, 06:54 AM
Joined Nov 2008
I found the picture below on ebay at:
http://www.ebay.com/itm/SY-2-5cc-15-...50962660245%26
It shows an SY-15 c/l Speed engine of the same vintage as the 09 shown above. Looks like a Rossi 15 clone.
The ebay ad confirms that SY is now called Sanye, the manufacturer of the AP engines and a lot of other brands..
Old Dec 12, 2012, 02:56 AM
Greggles47
greggles47's Avatar
Sydney OZ
Joined May 2007
Ray,
That Rossi 21 looks great mate. Can you squeeze it into one of your Classic B's. That could be a good way to use it.
Coincidentally, I got the RAL Micron off the shelf to convert today. There's still some work to do.
G
Discussion Control Line Team Racer plans and pictures perttime Control Line 324 May 22, 2016 03:59 AM
Sold McCoy RedHead .35 control line engine $20 shipped revkev Aircraft - Fuel - Engines and Accessories (FS/W) 2 Nov 07, 2011 11:39 PM
Sold OS-40-FPS, Control Line Engine "New" $80.00 Shipped! 1stGeppetto Aircraft - Fuel - Engines and Accessories (FS/W) 4 Oct 17, 2011 11:38 PM
Sold NEW in the box OS Max 46LA-S control line engine Diane@lazertoyz Aircraft - Fuel - Engines and Accessories (FS/W) 0 Jun 18, 2011 03:45 PM
For Sale o.s .19 control line engine i-fly-any-and- Aircraft - Fuel - Engines and Accessories (FS/W) 0 May 31, 2011 04:45 PM
