Old Jan 09, 2012, 02:58 PM
RdsG is offline
Find More Posts by RdsG
RdsG's Avatar
Hungary
Joined Jul 2009
Free flight '30 min.' PC fan hovercraft
I saw numerous videos of simple PC fan hovercrafts, but only a few used a skirt. PC fans are not the best choice for hovercrafts, but it made me more curious. So here is my version:
PC fan hovercraft ground clearance test (0 min 27 sec)
It's able to glide over 1-2 cm high obstacles.
Gabriel
RdsG is offline Find More Posts by RdsG
Old Jan 19, 2012, 10:26 PM
7oneWo1f is offline
Find More Posts by 7oneWo1f
AMF Years
7oneWo1f's Avatar
Joined Nov 2011
Thanks for posting that is cool.
7oneWo1f is offline Find More Posts by 7oneWo1f
Old Jan 20, 2012, 06:24 PM
RdsG is offline
RdsG's Avatar
Hungary
Joined Jul 2009
Thanks!
I just finished my round the pole model. It's powered by 12V 10W cooling fan (140 CFM). Its skirt is "C" type in front and on the sides, "bag" type on the rear.
Round the pole hovercraft model (1 min 27 sec)
Gabriel
Edit: photos, drawings: http://s241.photobucket.com/albums/f...br/hovercraft/
Old Jan 26, 2012, 01:43 AM View Post
Danny Crawford
A moderator felt this post violated the following rule: Off Topic Advertisement. Show it to me anyway.
Old Jan 27, 2012, 04:37 PM
RdsG is offline
RdsG's Avatar
Hungary
Joined Jul 2009
Round wall/cell skirt hovercraft model test:
The air gap in the front is smaller (~2 mm) than the rear air gap (~4mm), so the difference of the air spillage propels the model. Skirt is made of leatherette.
Round the pole hovercraft model wall skirt test (1 min 15 sec)
Gabriel
Old Jan 31, 2012, 12:44 AM
Kai Wren is offline
Find More Posts by Kai Wren
Joined Jan 2011
My first model was a radio shack brushed motor running off a 9 volt battery with a hand carved balsa propeller mounted in a piece of foam.
I just got the Hobby King Hoverjet and I'm a little disappointed. Not because it doesn't work well, just that it's terrain handling capabilities are just so limited. I like hovercraft because they can go from water to land and cover semi rough terrain. The Hoverjet was built for speed on perfectly flat ground.
My next one will have an extremely high skirt with a squirrel cage life fan and probably 2 low KV counter rotating propellers.
Kai Wren is offline Find More Posts by Kai Wren
Old Jan 31, 2012, 10:26 AM
RdsG is offline
RdsG's Avatar
Hungary
Joined Jul 2009
I think you should make a skirt for your Hoverjet. It's a great opportunity to experiment with different type of skirts. Only a few mm high skirt will dramatically increase its terrain handling capabilities, but you can make a really high skirt...
Gabriel
Old Feb 05, 2012, 10:16 AM
RdsG is offline
RdsG's Avatar
Hungary
Joined Jul 2009
Terraplane
Experiment with Terraplane-like hovercraft.
Propulsion provided by enlarged air gap at the rear.
Terraplane Hovercraft round the pole test (1 min 59 sec)
Gabriel
Data Free Pilatus plans: PC-12, PC-21, etc joe_crash Foamies (Scratchbuilt) 2 Nov 08, 2011 04:34 PM
Discussion 30 min vs 5 min epoxy? silentsoar The Builders Workshop 12 Aug 19, 2011 07:58 AM
Sold 2 Graupner Fan Free flight Kits NEW in Box Diane@lazertoyz Aircraft - General - Miscellaneous (FS/W) 0 May 10, 2011 01:05 PM
Discussion Something for long flight times 20-30 min? picasso Electric Plane Talk 32 Jan 04, 2006 02:26 PM
30 min epoxy hardens a lot quicker than 30 min! arukum17 The Builders Workshop 4 Oct 23, 2005 09:58 AM
