Solo!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!
SOLO!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
I'm a pilot!!!!!!!!!!!!!!!!!!!! Had my first Solo flight today, as you can see its tradition for a new pilot to have his shirt tail cut out and to draw a picture on it about it. This Cessna build will have the tail number N52815, after the plane I solo'd in today! |
This is an upside down view, of the opposite side thats being sheeted. This gives an interseting view of the entire kit with all the formers and stringers. I'm not working on it till the end of the week, I need to get some more parts cut and get some more sheeting before I can really hit the sheeting at a full pace. I've discovered that making large sheeting sections looks better. I plan on joining pieces of wood to make one huge sheet to do the entire bottom of the plane.
If you are wondering what the blue tape is, its to remind me that this side gets sheeted over without a door. I'm bad about getting in the zone and doing wrong things on this plane. I've also been putting lots of work into prepping the fuse for the sheeting, this is not fun. You sand and sand without alot of visual progress. But the sheeting fits on the stringers alot better. |
Preview of the misc parts to finish the fuselage. I see alot of potential in this plane, so I'm secretly working to improve this kit and make it so that everything locks and tabs together to take some of the scratch building out of it. The largest pieces you see are parts to make the cowl plug. They outline the cowl then ill fill it with foam to make a plug.
Found this thread:
http://www.rcuniverse.com/forum/m_50..._1/key_/tm.htm It is a 182 but it pretty darn close. This makes me feel better because this plane is a BRICK compared to mine ![]() Look how much plywood is in that fuselage. It looks like its built as a box then the formers are added to the outside. This prob makes it easy to build but dang that got to be HEAVY! Theirs a guy in that thread that said his came out to 29 lbs and he said it flies great. So surely I can get mine down to about 25 lbs. Although his was covered and not glassed/painted. I'm curious to know what my "ARF" weight is because I've been told that 25lbs is the cut off for a 30cc on floats. And that DLE 30 for $300 is looking enticing from Chief aircraft! |
One of things I designed and had cut was the structure for the cowl plug. I'm making a plug so I can make more cowls in case of more builds and /or repair/damages. I will fill this structure with blocks of florist foam and sand down to the shape. This is the "Turbo Cowl" versus the naturally aspirated engine cowl. The turbo is longer and is more sleeker looking. It has blind nuts so I can bolt it on from inside the plane and the remove it later after the foam is sanded. It looks so crazy with the shape of the cowl on the front of the plane! I'm so used to seeing that blunt firewall! and look how huge this thing is. It swallows a DLE 30cc. Theirs 4" between the firewall and the motor stand offs so I might have to add a motor box on the firewall later.
So this is the heart of the plane. It contains the elevator servo (on its side) and the rudder servo (top). It is has blind nuts under the floor. It also contains the 20 oz. fuel tank. This "tower" is located underneath the CG. I incorporated many interlocking tabs to make it very strong and light. It also self aligns when it goes together.
I also was able to start to run the cables through the formers. I still need some misc. hardware to make this job easier. But I was able to run the elevator cables and get the rough holes cut in the formers. And the reward for my hard work tonight??? I was finally able to have some control actuation on this plane!!!!!! I'm so happy to actually see some mechanical parts in this thing. This pull/pull set up is very smooth the elevator is very tight with no slope. |
| Thread Tools | |
| Discussion Cessna Aircraft taking flack over building new Cessna 162 Skycatcher in China | Thomas B | Life, The Universe, and Politics | 5 | Jan 07, 2008 11:31 PM |
| what's difference between cessna 182 and cessna 172 | CWNG06301 | Scale Electric Planes | 27 | Sep 04, 2007 01:05 PM |
| Sold ParkZone Cessna 210 Parkzone Cessna Centurion RTF | ScaleBrad | Aircraft - Electric - Micro & Indoor Airplanes | 2 | Sep 04, 2007 07:23 AM |
| Discussion Cessna 172 and Cessna 182 Difference? | Riotz | Scale Electric Planes | 3 | Apr 17, 2007 10:26 AM |
| Cessna Citation and Cessna Conquest plans | Voyager E | Aircraft - Electric - Airplanes (FS/W) | 2 | Jul 31, 2001 06:58 PM |
