Old Oct 30, 2001, 09:58 AM
Hammer is offline
Find More Posts by Hammer
United States, NC, Harrisburg
Joined Mar 1999
Smart V-tail setup?
What type of horns are you using on the elevators?What servo?Pushrod?Is anyone flying it with rudder function?
Hammer is offline Find More Posts by Hammer
Old Oct 30, 2001, 03:30 PM
Dave Wenzlick / Slickraft is offline
Find More Posts by Dave Wenzlick / Slickraft
(Batteries not included.)
Dave Wenzlick / Slickraft's Avatar
Mesa AZ
Joined Jun 2001
Re: Smart V-tail setup?
1/8" Brass tube let into the LE of the elevator and epoxied. Curved/bent down inline with the pushrod coming out of the fuelage. Drill 1/16 hole for metal clevis in each brass tube.
HS-85 upside down way back in the fuselage until it almost hits the servo arm on the sides.
I used a single wire in a plastic tube until the very back of the fuse where it splits into the two clevises.
No rudder.
Dave Wenzlick
Mesa AZ
Dave Wenzlick / Slickraft is offline Find More Posts by Dave Wenzlick / Slickraft
Old Oct 30, 2001, 10:14 PM
NickW is offline
Find More Posts by NickW
Sailplane Nut
NickW's Avatar
Providence, RI
Joined Nov 2000
I had a similar problem with my Omega. The horns provided were useless. I actually copied someone elses design from the Smart I saw online that used brass tubing as mentioned above. I then learned that multiplex sells some cool horns for vtails that would also fit the bill. Check out www.multiplexrc.com for more info.
Nick
NickW is offline Find More Posts by NickW
V-Tail Setup Question Bill K. Parkflyers 12 Mar 21, 2003 07:29 PM
Smart V-tail - elevator or ruddervator Clay High Performance 3 Jan 20, 2003 12:39 AM
Smart V-tail setup Clay High Performance 7 Nov 27, 2002 12:13 AM
Question Eclipse TX with V-tail, setup? 10Thumbs Hand Launch 9 Sep 17, 2002 10:35 AM
Question Tiny V tail setup d12bn Parkflyers 3 Feb 10, 2002 11:11 AM
