Old Aug 13, 2012, 08:18 AM
Rocketman1092 is online now
Find More Posts by Rocketman1092
Purdue Engineering
Rocketman1092's Avatar
United States, CA, San Diego
Joined Jan 2005
Hi Larry,
The fuselage of the Super Sky Surfer looks larger to me, so the pod would likely need to be re-designed. This is something I would be interested in doing if this airplane becomes popular for FPV, but I can't say when or if that will happen. Perhaps you could post a couple sketches of the canopy area when your plane arrives? That would help me determine whether I could simply up-scale the existing design, which wouldn't require as much work as starting from scratch.
Eric
Rocketman1092 is online now Find More Posts by Rocketman1092
Old Aug 13, 2012, 09:42 PM
BlueMax555 is offline
Find More Posts by BlueMax555
United States, OR, Grants Pass
Joined Aug 2012
Super SkySurfer size
Hello Eric
Thanks for a quick reply on my question. When I get my plane(Super SkySurfer) I will make measurements and let you know what they are,maybe same size, but probably is bigger then the regular SkySurfer. I really like your design and will pay what ever you need to build me one for the Super skysurfer!
Will probably be a week to ten days before I receive the plane and will let you know the dimensions of the cockpit area.
Thanks and have a excellent week
Larry
BlueMax555 is offline Find More Posts by BlueMax555
Old Aug 13, 2012, 10:20 PM
powerstroke01 is offline
Find More Posts by powerstroke01
powerstroke01's Avatar
USA, CA, Ahwahnee
Joined Sep 2004
bixler 2?
powerstroke01 is offline Find More Posts by powerstroke01
Old Aug 13, 2012, 10:29 PM
Purdue Engineering
Joined Jan 2005
I believe the pod might fit the Bixler 2 as-is, since the fuselage and canopy area seem largely unchanged. However, the fact that it's offered only in pre-assembled form may cause issues. If anyone decides to try the pod with a Bixler 2, I'd appreciate feedback.
Old Aug 14, 2012, 02:56 AM
FirstPersonView is offline
Find More Posts by FirstPersonView
Australia, VIC, Melbourne
Joined Aug 2012
Cool, think it'll fit on an AXN?
FirstPersonView is offline Find More Posts by FirstPersonView
Reply With Quote  (Disabled)
Old Aug 14, 2012, 07:56 AM
Purdue Engineering
Joined Jan 2005
Not likely, since the AXN's canopy area is quite different.
Old Aug 15, 2012, 12:12 PM
HockeyMac721 is offline
Find More Posts by HockeyMac721
Joined Dec 2010
Super Sky Surfer
Another idea on the SSF pod. If it does happen to be bigger, could you build a dock into the plane that allows the original pods to drop in? Or would a new design make more sense?
HockeyMac721 is offline Find More Posts by HockeyMac721
Old Aug 15, 2012, 12:22 PM
Purdue Engineering
Joined Jan 2005
A dock would work, but then the battery tray would be the same size. I'd probably scale up the pod to fit the Super Sky Surfer, and might even use 3/16" wood.
Old Aug 15, 2012, 05:13 PM
USA, CA, Ahwahnee
Joined Sep 2004
Im tossing around the idea of trying it out. Ive got a B2 on the way... And it will be used for fpv....
Old Aug 15, 2012, 05:15 PM
USA, CA, Ahwahnee
Joined Sep 2004
id love to have something for my axn... But i think itd be a challenge.
Old Sep 01, 2012, 09:20 PM
Purdue Engineering
Joined Jan 2005
Anyone with a pod got their airplane built and flying yet? It'd be great to see some pictures!
Old Sep 01, 2012, 10:10 PM
nakelp86 is offline
Find More Posts by nakelp86
Nakelp
nakelp86's Avatar
United States, NJ, Union
Joined Sep 2004
Its coming soon, I stumbled on my electronics for a while but hope to maiden it sometime next week, if all goes well I mean LOL
nakelp86 is offline Find More Posts by nakelp86
Old Oct 01, 2012, 05:13 PM
kokopropelli is offline
Find More Posts by kokopropelli
Crash....Fix......repeat.
kokopropelli's Avatar
United States, UT, Eagle Mountain
Joined Jan 2012
Has anyone put an Eagle Tree system on the pod? OSD pro, elogger, gps and guardian? Just trying to get an idea of where people have located the componenets. I'm about to install mine and now that I'm ready to put everything in I'm torn as to where I should put it. I've done the elevator and rudder servo mod and moved them to the rear of the fuse, so the CG is naturally favoring the rear. Any thoughts?
kokopropelli is offline Find More Posts by kokopropelli
Old Oct 01, 2012, 05:19 PM
Purdue Engineering
Joined Jan 2005
geminiryan,
Your build looks great so far! I have an Eagle Tree system mounted in my original pod, just check the images in post #1 to see where I chose to place everything. Let me know if the photos aren't clear enough.
Eric
Old Oct 01, 2012, 05:25 PM
idletime is offline
Find More Posts by idletime
idletime's Avatar
Canada, ON, Toronto
Joined Apr 2011
Just glued mine up and abit disappointed (alot actually) that the tray is not wide enough (or alternatively, tall enough) for any of my 3S 5000 (zippy) or 4S 5800 (zippy) batteries.
The only ones that fit on the tray are the 2200 (both 3S/4S), which I use anyway. For $40, this Pod / tray would have been killer (function and value) if it was either a tad wider or taller to fit a larger battery to allow duration flying.
- There is space inside the fuselarge. Maybe previous owners can get a discount on Version 2.
idletime is offline Find More Posts by idletime
For Sale Multiplex Easy Star / Sky Surfer / Bixler Adjustable Aluminum Motor Mount sotog Aircraft - Electric - Power Systems (FS/W) 0 Jan 07, 2012 11:02 AM
For Sale Multiplex Easy Star / Sky Surfer / Bixler Adjustable Aluminum Motor Mount sotog Aircraft - Electric - Power Systems (FS/W) 6 Jan 05, 2012 05:44 PM
For Sale Multiplex Easy Star / Sky Surfer / Bixler Adjustable Aluminum Motor Mount sotog Aircraft - Electric - Power Systems (FS/W) 8 Dec 11, 2011 05:29 PM
Sold 1800kv Motor/prop for Sky Surfer / Bixler / Easy Star tdab Aircraft - Electric - Power Systems (FS/W) 1 Nov 01, 2011 04:46 PM
