Old Jan 09, 2012, 12:05 AM
cpdude is offline
Find More Posts by cpdude
Designing something...
United States, CA, Cameron Park
Joined Jan 2004
Build Log
2.4 Meter Horten VII
Well I couldn't resist any longer now that my Horten IIIe has flown I've decided to start the actual--glue it together--build. This is going to be an alpha/prototype build since I'm using it to flush out the design and prove (hopefully) that it'll fly. I've already made a bunch of changes to the drawing and I'll probably make many more.
Anyway, I've glued a few pieces together. Please no comments on the big part in the center. I know it looks like it was carved from a 2 x 4. If you look at the comments on the drawings you'll see that this part has been redesigned. The changes just didn't make it into this build.
I'll try to post some of the specs (e.g. motors, batteries, wing area...etc) tomorrow when I'm awake.
Please let me know if you have any questions.
Enjoy!
Brian
cpdude is offline Find More Posts by cpdude
Old Jan 09, 2012, 09:40 AM
nmasters is offline
Find More Posts by nmasters
internet gadfly
nmasters's Avatar
Colorado
Joined Aug 2006
Subscribed
nmasters is offline Find More Posts by nmasters
Old Jan 09, 2012, 10:39 AM
cpdude is offline
Joined Jan 2004
Some specs
Here are some specs for the Ho VII...
Motors: Exceed RC Rocket 3520-1050KV (http://www.hobbypartz.com/86mc302-3520-1050kv.html)
Landing gear:
Mains - 25 - 46 100 Degree Rotating Electric Retracts (http://www.e-fliterc.com/Products/De...ProdID=EFLG320)
Nose gear taken from - 25 - 46 Tricycle Electric Retracts (http://www.e-fliterc.com/Products/De...ProdID=EFLG330)
Batteries:
two 4S ??mAh LiPo batteries. Whatever it takes to balance.
Joiner tubes:
two 7/8" x 36" (.049") from Tnt Landing gear (http://www.tntlandinggear.com/store/shop/wing_tubes.htm)
The wing area is ~10.8 sq. ft. At this point I'm thinking the prototype could come out in the 12lb range. That puts the wing loading in the 18oz/sq. ft. range.
The motors are rated for 1,300 watts. However, I'm only planing to put ~800 watts so that puts the power at ~133 watts/pound. If I need more power I can always add more prop or go to 5S If I feel like spending lots of money I can always switch to Hacker A40-10L V2s and run 8S batteries. Either way I can definitly increase power if necessary.
Thoughts?
Brian
Old Jan 09, 2012, 11:11 AM
birdofplay is online now
Find More Posts by birdofplay
Retired CAD guy
birdofplay's Avatar
United States, IN, Indianapolis
Joined Dec 2005
Sure, now the pressure is on me for the molds. :-)
Subscribed
Bob
birdofplay is online now Find More Posts by birdofplay
Old Jan 09, 2012, 11:28 AM
cpdude is offline
Joined Jan 2004
Subscribed
Bob
Hey Bob,
I'm sure she'll fly just fine without the canopy and motor intakes. Do you want me to send you a current picture showing the real build status? Then you'll be under some real pressure.
Brian
Old Jan 09, 2012, 11:42 AM
invertmast is offline
Find More Posts by invertmast
United States, FL, North Port
Joined Mar 2004
What about doing a thin fiberglass shell for the center section? Kind of like wings over the web horten wing? Would be a bit more expensive, but save some weight and building time
invertmast is offline Find More Posts by invertmast
Old Jan 09, 2012, 12:01 PM
Retired CAD guy
birdofplay's Avatar
Joined Dec 2005
Send pix :-)
Old Jan 09, 2012, 12:10 PM
cpdude is offline
Joined Jan 2004
Send pix :-)
I got pulled into a meeting. Soon...
Old Jan 09, 2012, 12:16 PM
cpdude is offline
Joined Jan 2004
Great idea! But I doubt that I'll have the time to do that anytime soon. If someone (you?) would like to step up and make and share a fiberglass shell then I will gladly provide all of the center section ribs and bulkheads for free. Remember this is an open source project.
Brian
Old Jan 09, 2012, 12:46 PM
Joined Mar 2004
Originally Posted by cpdude View Post
Great idea! But I doubt that I'll have the time tomdo that anytime soon. If someone (you?) would like to step up and make and share a fiberglass shell then I will gladly provide all of the center section ribs and bulkheads for free. Remember this is an open source project.
Brian
I could do that. If no one is in a huge rush i can wait till youhet the design finalized and then work from there. It will probably be better off to wait till the outer wing panels are done as well so the joint line will be the same
Old Jan 09, 2012, 12:52 PM
cpdude is offline
Joined Jan 2004
I'm definitely not in a rush. We should definitely talk when the time is right.
Brian
Old Jan 09, 2012, 12:54 PM
cpdude is offline
Joined Jan 2004
Link to the design/discussion thread
I forgot to post this earlier. At some point the two threads will get separated so here is the link to the design/discussion thread: http://www.rcgroups.com/forums/showthread.php?t=1546211
Enjoy!
Brian
Old Jan 09, 2012, 08:22 PM
Retired CAD guy
birdofplay's Avatar
Joined Dec 2005
Beautiful Pix !
You do great work.
Old Jan 09, 2012, 08:28 PM
fritzdecat is offline
Find More Posts by fritzdecat
Smoke me a Kipper
fritzdecat's Avatar
Cedar Grove North Carolina
Joined Oct 2006
excellent subd
fritzdecat is offline Find More Posts by fritzdecat
Build Log 4.1 meter (1/5 scale) Horten IIIe cpdude Scale Sailplanes 408 Mar 05, 2016 01:45 AM
Build Log 2 Meter Horten XII cpdude Flying Wings 350 Mar 04, 2013 08:46 AM
Discussion 2.4 Meter Horten VII cpdude Giant Electric Planes 164 Jan 09, 2012 12:08 AM
Alert A poll for the Horten VII build thread... cpdude Giant Electric Planes 2 Jan 06, 2012 08:33 PM
Sold ***Shark XL Strong 4.5 meter 2.4 safe RTF*** Just flyy Aircraft - Sailplanes (FS/W) 7 Sep 21, 2011 12:19 PM
