Old Jan 09, 2012, 12:31 AM
Iceman320 is offline
Find More Posts by Iceman320
Joined Jun 2011
bought a kk black board and need some help
so i bought a kk black multicopter control board and it came with the programming cord and two cables that plug into my rx, but the one rx cable has one plug at the one end and three plugs at the other end so where does this cable plug into? this will be my first multicopter build so any help you guys can give my would be great. also do i have to program the board before i can fly my multicopter or is it already programmed? thanks in advance for the help.
Iceman320 is offline Find More Posts by Iceman320
Old Jan 09, 2012, 12:53 AM
ScooterInVegas is offline
Find More Posts by ScooterInVegas
Village Idiot!
ScooterInVegas's Avatar
United States, NV, Las Vegas
Joined Apr 2011
Where/Who did you buy it from?
The one plug goes on the signal pins only. The other one has all three to uses the power/ground/signal. Once the KK board has those three things (say on throttle), it ONLY need the "signal" on the other channels to work. (pitch/roll/yaw)
Does that make sense? If not, just let me know. Scott
ScooterInVegas is offline Find More Posts by ScooterInVegas
Old Jan 09, 2012, 10:40 AM
Joined Jun 2011
so then where does the wire with the three plugs on one end plug into the board at?
Old Jan 09, 2012, 10:44 AM
WiseDuck is offline
Find More Posts by WiseDuck
Mmmmmmm!
WiseDuck's Avatar
Kingdom of Sweden, Dalarna County, Sater
Joined Oct 2011
You put the lone connector across three signal pins on say, your receiver and the other three on three different channels on the board. I.e. the cable needs to go to the signal pin on throttle, aileron, elevator and yaw. That's usually the top pin, the one closest to the middle of the board.
That's just one way of using that harness. Oh wait, he said that already, hrm, don't know!
WiseDuck is offline Find More Posts by WiseDuck
Old Jan 09, 2012, 10:45 AM
Halford is offline
Find More Posts by Halford
Belgium, Brussels
Joined Jul 2010
this plug goes from RX to the board.
on the RX you will plug it on the signal only pins... like connecting aileron, rudder and Elevation...and on the KK board you will connect each pin on the corresponding pin. the second wire you'll connect it normally from throttle to throttle... this is done so you only connect once the power...and save wire weight too
Halford is offline Find More Posts by Halford
Old Jan 09, 2012, 02:38 PM
Joined Jun 2011
okay thanks for the help guys I will post up a pic later when I get it connected and you guys can let me know if I have it all hooked up right.
Old Jan 09, 2012, 03:57 PM
Village Idiot!
Joined Apr 2011
See, on my KK board, the channels do NOT line up the same with my Rx. So having the ends spit up as singles works out because I can match up my channels. The single ends can go either on the board or the Rx. They just have to match the channels.
Old Jan 09, 2012, 04:54 PM
Dave8888 is offline
Find More Posts by Dave8888
United States, AZ, Seligman
Joined Nov 2011
Hopefully this helps. The signal wires on RX are connected to signal wires on KK board. Just on 1 end you have 3 connectors with 1 wire each. This photo has 1 connector with 3 wires. Connections are the same.
Dave8888 is offline Find More Posts by Dave8888
Old Jan 09, 2012, 10:58 PM
Joined Jun 2011
okay guys i think I got it will it work if I make my connections like this. sorry for the blurry pics i should have used my other camera let me know if you need a better pic.
Old Jan 10, 2012, 12:30 AM
Village Idiot!
Joined Apr 2011
Cant see from the blurry pictures, but looks about right.
<<edit>> because I look and dont read.
Old Jan 10, 2012, 12:59 AM
Joined Jun 2011
where will the channel 5 wire connect to on the kk board? and also where does the power plug into the kk board?
Old Jan 10, 2012, 01:25 AM
Village Idiot!
Joined Apr 2011
HA! Ive been looking at my CC boards too much lately! Sorry, my bad. No 5th channel for flight control on the KK.
No, power plug needed. The board gets its power from the ESC. Some run all the BEC's but most unplug all but one or use a separate BEC and unplug all the power leeds from the ESC's.
Old Jan 10, 2012, 10:40 AM
Joined Jun 2011
okay thanks for the help guys i'll get some esc's and motors ordered next week and see how it goes. what size battery should I use to power the quadcopter?
Old Jan 10, 2012, 10:46 AM
Village Idiot!
Joined Apr 2011
Im gusssing your building an avg size quad?
2200mah 3cell 30C is an avg size. What motors/esc's you getting?
Old Jan 10, 2012, 02:30 PM
Joined Jun 2011
I will probably be running some 1100kv motors with some 30 amp esc's not sure which brand yet though.
For Sale KK multicopter black board + Navi board set hemanthtguru Aircraft - Electric - Multirotor (FS/W) 5 Nov 11, 2011 11:48 PM
For Sale KK multicopter black board + Navi board set hemanthtguru Non R/C Items (FS/W) 0 Nov 07, 2011 10:21 AM
Discussion need help with Black KK board Marked Multirotor Talk 19 Oct 25, 2011 07:51 AM
Discussion Iím looking for some help regarding a minsoo Kim kk black board charles 1973 Multirotor Talk 10 Sep 24, 2011 05:04 PM
Discussion I need some help with Minsoo Kim KK board SeismicCWave Multirotor Talk 1 Apr 08, 2011 07:01 AM
