Joined Jul 2008
Joined Jul 2008
When i get my 10 batteries in the mail then I will charge them at 0.8 unless someone says different.
No one answered my question on locking the landing gear down so it doesnt come off in a crash. If the landing gear is locked down, then I can lock the canopy down to it. I hate having to remove the canopy to reinstall it after a crash. But is it better for the landing gear/battery to go flying off in a bad crash? If its better to let that happen, then how can we lock the canopy down? The carbon) rods will break if the canopy is locked down the landing gear. I viewed someone's video showing a broken heli blade glued to the bottom of the battery tray. Like a diving board the canopy is fit over it. Isnt the force of the impact already dissapated when the landing gear goes flying? |
If you have a mcp, then you must have a Devo. From what I read, Devo 6 and 7 only need a free firmware upgrade to use telemetry info, and atleast one (I think 2) people in a different thread recently posted that their Devo 8 (non S version) is also able to receive telemetry info with the original (non upgraded) module. IMO, even if it cost +$20 to upgrade to telemetry, I would do it. I have the same problem of getting in the habit of starting, and stopping the timer (although I think the Devo's can be programmed to auto start/stop the timer when THROTTLE stick is moved from/to zero position). Also I don't enjoy trying to remember which different LiPo has what amount of flight time, depending on brand, technology, size, age, temperature, etc. I'm thinking a Voltage activated alarm is a no-brainer, just program once and you'll have no-hassle Plug-n-Play forever no matter which battery is used. I don't have a mcp yet (I'm waiting for mcp parts to get stocked), but when I get one, my game plane is to first fly it till it drops, and immediately determine the "drop" Voltage, then program the TX to alarm 0.1V before the "drop" Voltage, so it gives me enough pre-warning time to come in under a powered (non Mayday) landing. |
Joined Jul 2008
I have the devo 7 and havent heard anything about it having telementary, only devo 6,8,12. And Hopefully there is a way to restart the timer with a throttle push on devo 7.
Just went to walkera site to find software update to telementary and the devo 7 isnt listed. |
Joined May 2011
Actually no usb cable either with which you could update the firmware, and the readme.txt file of the v1.3 upgrading tool doesn't list the DEVO 7 as supported yet... |
United States, TN, Memphis
Joined Dec 2011
Finally got a refund and am watching my bank account to see when it posts so I can order from WOW. For those who ordered from WOW, what all came with it? I see this on other sites and wanted to make sure it also came with the Mini-Devo8s combo at WOW.
Package Included: 1 x Mini CP helicopter 1 x DEVO8S transmitter 1 x Li-Po Battery Charger 1 x USB Charging wire 1 x 3.7V 240mAh Li-Po Battery 1 x RX801 receiver 1 x USB cable 1 x Neck strap 1 x Instruction manual disc |
USA, CA, El Segundo
Joined Jan 2011
![]() WOW are you listening! ![]()
These GensAce batteries are cheap and really good quality, wish they would make a micro battery, they are rated for 5C charge. I think the whole thing with batteries is to get enough so you can fly non-stop for whatever time you usually fly. The downside of chargeing @ a high C rating dosent give you a full charge to the battery, so you lose some performance in that way. Say you fly for an hour, each battery gives you 5 mins flight, take a few min break between flight so thats about 10 lipos to keep you flying for 1hr prety much non-stop. Now figure out how many batteries you can charge in an hour......I can do 3-1S per half hour on a balance charger @ 1C full charge, so that 6 per hour. Using this formula you can make 6 batteries keep you in the air indefinately if you fly 6 and are charging 6. 12 1S lipos is the magic number for me with the micros For the larger birds 5- or 6 lipos per hour can do the same thing, with slightly longer flights and more breaks in between. Can fly 2 450's a 2 120s basically all afternoon with a couple red bulls to keep the fingers steady Every season i cycle a few old batteries out and get some new ones to replace them, I also use voltage monitors with lights and audible alarms on the 450s. 6 bucks is cheap insurance to keep the lipos giving full output. It goes off when a cell hits 3.2V under load in the air. Then the esc gives a little tail flick every second or so.http://helidirect.com/maxpro-battery...ies-p-8159.hdx |
| Thread Tools | |
| Cool World Smallest Lightest Indestructible 3D helicopter :Genius CP!! | DLY | Micro Helis | 9681 | May 20, 2013 10:42 PM |
| Discussion Walkera Genius CP-the smallest 3d flybarless heli in the world! @ oomodel | oomodel.com | Hot Online Deals | 12 | Oct 16, 2011 08:52 PM |
| Careful! World Smallest Lightest Indestructible 3D helicopter Genius CP "More Junk" | Iceblade1A | Micro Helis | 91 | Sep 25, 2011 11:38 AM |
| For Sale Walkera 52 CP 3S MICRO heli(smaller than a Gaui)$75 DELIVERED | Z06 Tony | Aircraft - Electric - Helis (FS/W) | 0 | Aug 16, 2009 07:38 PM |
| Question What’s Better than a Blade CP and Smaller than a Trex? | HavingFun2002 | Micro Helis | 74 | Mar 05, 2006 05:07 PM |
