Old Jan 27, 2012, 01:42 AM
bytemuncher is offline
Find More Posts by bytemuncher
Tokyo
Joined Jan 2010
Originally Posted by Kopteri2010 View Post
Right...and the swash holder is also stronger in Mini CP head... Thicker plastic on the swash holder arms...
Yes, and it is kind of angled backward toward the tail motor rather than 90 degrees vertical like on the genius. This caused problems with my xtreme metal swash as it has a short swash guide arm that came out of the holder. Have gone back to stock swash because of this.
bytemuncher is offline Find More Posts by bytemuncher
Old Jan 27, 2012, 09:59 AM
Tokyo
Joined Jan 2010
CCW Yaw Drift
After shattering a glass on my coffee table trying to flip the mini I decided to try some calmer flying.
I just got done hovering about 10 packs through it and noticed that the CCW yaw drift still seems to be present. On my genius I need -10 throttle/rudder to mix it out and on the mini I need from -6 to -8. I'm currently running an mcpx main so that could be affecting it...but I don't think so.
Curious if others have noticed this?
Old Jan 27, 2012, 02:02 PM
dkfuji is offline
Find More Posts by dkfuji
RC Helis: My Healthy Obsession
The OC, California
Joined Feb 2007
I do not have the yaw issue with any of my Mini's (I have 3). Maybe the MCPx mains do have an effect. Try binding the heli then unplug the heli pack and plug it back in to bind again.
dkfuji is offline Find More Posts by dkfuji
Old Jan 27, 2012, 07:23 PM
Tokyo
Joined Jan 2010
I don't remember having it with the stock or c05 so will have to put those in and check again.
Old Jan 27, 2012, 10:12 PM
dkfuji is offline
The OC, California
Joined Feb 2007
I figured I would post pics comparing the weight of my BL Mini, Stock Mini and double BL Genius. As you can see, the BL Mini is over 2g lighter than the stock and almost 6g lighter than the double BL (would be even lighter minus the motor and ESC plug). That probably explains why she is a monster in flight and the double BL is okay with shorter flight times. BTW, all of the helis were weighed without lipo pack.
Old Jan 28, 2012, 05:38 AM
Tokyo
Joined Jan 2010
More on the ccw yaw drift
Did some hover testing with the stock motor and mine definitely has a little ccw yaw drift (~90į/min). Using a devo 6 with 6s firmware.
Setting a -7 program mix (throttle master / rudder slave, L point 0, rest flat @ -7) seems to lock tail the best with the stock motor...at least for my mini. Tests were done using hyp 240's. Rudder gyro settings didn't seem to make a difference.
To be honest I didn't even notice it till I started looking/testing for it. I think it's a little more noticeable on the genius.
Old Jan 28, 2012, 02:00 PM
Z06 Tony is offline
Find More Posts by Z06 Tony
Z06 Tony's Avatar
United States, NY, Rochester
Joined Sep 2008
LOL the 1st pic is a Wolf in Sheeps(Genius Canopy)clothing. Looks like I will have to convert 1 of my Mini CP's to BL now
Z06 Tony is offline Find More Posts by Z06 Tony
Site Sponsor
Old Jan 28, 2012, 08:31 PM
stretch1100 is offline
Find More Posts by stretch1100
stretch1100's Avatar
USA, IL, Elgin
Joined Jan 2006
Anyone stateside have the mini in stock for sale?
stretch1100 is offline Find More Posts by stretch1100
Old Jan 28, 2012, 09:04 PM
vronny is offline
Find More Posts by vronny
los angeles,ca
Joined May 2010
Wow will probably have some friday. Stretch what happened to the v200D03. I'm still waiting for parts maybe next week. These are all Walkera vendors that will get the mini cp helircstore, clubheli & Wow.
vronny is offline Find More Posts by vronny
Old Jan 28, 2012, 09:18 PM
Tokyo
Joined Jan 2010
Hi dkfuji, I'd love to know the settings you use for 3d. Specifically the following:
TA (ele, ail, pitch)
DR
PC
Rudder Gyro
Old Jan 28, 2012, 11:01 PM
USA, IL, Elgin
Joined Jan 2006
The v200d03 is on my list too. I cancelled my order from that one place as a few people told me they were b.s.
Old Jan 29, 2012, 01:34 AM
buildem336 is offline
Find More Posts by buildem336
vista, Ca
Joined Nov 2006
These are the settings I am using on my Brushed Mini cp with my Devo 12.
Dual Rate/Expo
Elevator
D/R 115%
EXP LIN
AILE
D/R 105%
EXP LIN
Rudder
D/R 125%
EXP -70
Travel Adjust
Elevator U124% D124%
Aileron L124% R124%
Throttle H100% L100%
Rudder L121% R121%
Pitch H70% L70%
Throttle curve
Normal
L 0%
1 Inhibit
2 Inhibit
3 Inhibit
M 100%
4 Inhibit
5 Inhibit
6 Inhibit
H 100%
Stunt 1 and 2 100% across
L 100%
1 Inhibit
2 Inhibit
3 Inhibit
M 100%
4 Inhibit
5 Inhibit
6 Inhibit
H 100%
Pitch curve
Normal
L -20%
1 Inhibit
2 Inhibit
3 Inhibit
M 0%
4 Inhibit
5 Inhibit
6 Inhibit
H +100%
Stunt 1 and 2
L -100
1 Inhibit
2 Inhibit
3 Inhibit
M 0%
4 Inhibit
5 Inhibit
6 Inhibit
H +100%
Gyro settings
88.0%
Manuel Campos
buildem336 is offline Find More Posts by buildem336
Old Jan 29, 2012, 08:19 AM
Tokyo
Joined Jan 2010
Thanks Manny, giving these a try...intense, but fun. Can't believe how fast it piros now.
Old Jan 29, 2012, 02:00 PM
HeliFlyer711 is offline
Find More Posts by HeliFlyer711
♘ Heli's Lives Matter ♘
HeliFlyer711's Avatar
United States, PA, Philadelphia
Joined Oct 2009
I run all the micro walkera's tail at 120% with no expo since the 4G6, once you get into the negative expo with a motored tail though, it does help a little more especially for outside in the wind, you can also try bending the tail blades and adding more pitch angle to them...not a big piro fan, just want a locked tail .
HeliFlyer711 is offline Find More Posts by HeliFlyer711
Old Jan 29, 2012, 04:27 PM
fas66 is offline
Find More Posts by fas66
Auburn, NE
Joined Jan 2007
V200d03
Who was asking about the V200D03? BH has the Matrix 250R which is the V200D03 rebranded with a green canopy. The cone gears are a bear as they will strip out if you touch anything. Especially the one driven off the main gear. It seems to be a common problem because hardly anyone has replacements in stock. I like the heli but am really disappointed with the shaft driven tail problems.
fas66 is offline Find More Posts by fas66
Cool World Smallest Lightest Indestructible 3D helicopter :Genius CP!! DLY Micro Helis 9889 May 18, 2016 12:17 PM
Discussion Walkera Genius CP-the smallest 3d flybarless heli in the world! @ oomodel oomodel.com Hot Online Deals 17 Sep 28, 2015 10:48 AM
Careful! World Smallest Lightest Indestructible 3D helicopter Genius CP "More Junk" Iceblade1A Micro Helis 91 Sep 25, 2011 11:38 AM
For Sale Walkera 52 CP 3S MICRO heli(smaller than a Gaui)$75 DELIVERED Z06 Tony Aircraft - Electric - Helis (FS/W) 0 Aug 16, 2009 07:38 PM
Question Whatís Better than a Blade CP and Smaller than a Trex? HavingFun2002 Micro Helis 74 Mar 05, 2006 05:07 PM
