Joined Jan 2013
Just tried to flip mine in stunt mode, stock motor and 300mah 35c battery. 4th cycle on them. They have good punch to start with, so tried straight after take off. But there wasnt enough power once over and crashed. Tried a few times but them the battery was shot. Maybe its mostly me as with my bigger heli i just loop, not flip.
Maybe i wasnt using all the cyclic available, hmmmm, will have to try again. |
[QUOTE=Titan33;24305310]
United States, MN, Le Sueur
Joined Nov 2012
No I have not resoved it. I now have 2 minis that wont bind. I replaced a servo on the 1 that was still binding. I removed the old servo plugged in the new one before intsalling so I could bind the heli work the servo, find the mid point of travel. the heli will no longer bind. Someone suggested the if thr red led stops blinking during the binding time then blinks again it means the RX is binding but one or more components are not. So, as I understand it the process is to unplug everything from the pc board, see if the rx will bind. Then one at a time plug in 1 component and see if it binds until you get t the 1 component or connector is discovered. I will probably try doing so today Hope it works now I have 4 cps I can't get to fly AGHHHHHH
Joined May 2012
Len |
United Kingdom, England, Sheffield
Joined Jun 2012
I found it easier to flip than real life mini but a lot harder to maintain an inverted hover than a real mini. Lent57 - what do you have your pitch travel adjust and rates at? Rodders - what are your pitch curves? |
Pitch curves are stock.
I just been out again trying. Was hovering lovery upside down. Numerous flips on the same pack. Then the inevitable happened. Instead of hitting the nice soft grass, i hit a brick wall and patio. Rammed the shaft right down and took all the servos out. Was going great till that point. Just seemed to get brain freeze and didnt correct.Batteries are getting better after each cycle still. |
Servo Saver Mod is almost free, and lasts forever |
Sweden, Helsingborg
Joined Jun 2012
On a real heli it drifts when you piro, in the sim it might as well be nailed inplace. Simming did not help me at all in doing circuits indoors. Just lots and lots of practice with the real thing. Rodders, check if banggood has the servos in stock. But expect som massive shipping times. Im looking forward to my latest mini cp purchases. 5x Oversky 400 mah 30c batterys. AEO m5 13500 kv motor FBL 100 tail motor / tail holder/ tail fin And as i got tired of how hard the minicp is to see at distance, some visual upgrades. Wasp100 canopy FBL 100 green main blades FBL 100 green tail blade And wasp100 main gear, landing gear and main shaft to check if they fit the mini cp. 1.1$ per main gear including shipping .
| Thread Tools | |
| Cool World Smallest Lightest Indestructible 3D helicopter :Genius CP!! | DLY | Micro Helis | 9681 | Yesterday 10:42 PM |
| Discussion Walkera Genius CP-the smallest 3d flybarless heli in the world! @ oomodel | oomodel.com | Hot Online Deals | 12 | Oct 16, 2011 08:52 PM |
| Careful! World Smallest Lightest Indestructible 3D helicopter Genius CP "More Junk" | Iceblade1A | Micro Helis | 91 | Sep 25, 2011 11:38 AM |
| For Sale Walkera 52 CP 3S MICRO heli(smaller than a Gaui)$75 DELIVERED | Z06 Tony | Aircraft - Electric - Helis (FS/W) | 0 | Aug 16, 2009 07:38 PM |
| Question What’s Better than a Blade CP and Smaller than a Trex? | HavingFun2002 | Micro Helis | 74 | Mar 05, 2006 05:07 PM |
