Old Feb 26, 2013, 12:21 PM
HPCR is offline
Find More Posts by HPCR
San Mateo, CA
HPCR's Avatar
United States, CA, San Mateo
Joined Dec 2012
My Mini CP's have this "ratcheting feel" when you turn the blades
Originally Posted by BThirsk View Post
Try using some plastic safe oil like triflo on the main bearings and the swash bearing. These need a little oil, usually about every 20 flights. Make sure your pinion has correct clearance as the motor may has shifted. It needs to be completely friction free with no sign of gear clogging. T
The coreless motor is great when you have zero friction, but will drastically lose flight time if friction is present as it does not have the same torque as the core motor.
Can you tell me how you would " adjust" for the correct clearance on the CP's ( Mini / Genius/ Super?? My Mini's ( I have 3 or 4) all have this "ratcheting feel" when you turn the blades. The Super and Genius's that I have are totally friction less. I looked to see where I could possibly vary the distance between the pinion and the gear but I can not see where I can make that adjustment. What are you'all doing to make that gearing smooth??
HPCR is offline Find More Posts by HPCR
Old Feb 26, 2013, 01:20 PM
Crash Survivor is online now
Find More Posts by Crash Survivor
Heli Crash Survivor
Crash Survivor's Avatar
United States, AR, North Little Rock
Joined Feb 2011
Originally Posted by Crasy666 View Post
yes already reduced the Gyrothe flat side of the poti is showing to 9:30 AM so it is reduced.
but it is still a difference to feel, the Super CP is more direct, I got this feedback also from other people here in Germany.
I am using the V1.3 FW; so not an old version on my Mini CP. and still here the Mini CP feel not so direct. it is not a big problem, the Mini CP flys great, also I did the firest invert flights. I like the Mini.
But the Super CP reacts directer, but with the issue on the tail, it is at the moment not my favourite. it is for me as a invert flight beginner very critical if the tail is not stabil... so the Mini CP is my favourite, My trust in the Mini CP is higher.
What I noticed with the SCP is if to much pitch is applied & causes any bog on the main the tail will not be stable. With my BL setup & pitch curve set to + & -40 ST1, + & - 45 ST2 I have a solid tail & still plenty of pitch to flip & fly inverted & no motor bog.
Crash Survivor is online now Find More Posts by Crash Survivor
Old Feb 26, 2013, 01:29 PM
Crasy666 is offline
Find More Posts by Crasy666
Crasy666's Avatar
Germany, BY, Nord
Joined Oct 2012
The two tails are 100% the same, anyway since I modded my tail to a.7 mm tail motor I used a mini CP boom.
Crasy666 is offline Find More Posts by Crasy666
Old Feb 26, 2013, 01:33 PM
PurpleShark is offline
Find More Posts by PurpleShark
...if you take the time
Israel, Tel Aviv
Joined Jul 2012
All this motor talk, made we wanna try the genius motor
Should I bother fitting the genius gear (I've read it requires frame mod), or just use the stock gear?
PurpleShark is offline Find More Posts by PurpleShark
Old Feb 26, 2013, 03:12 PM
sbstnp is offline
Find More Posts by sbstnp
Deviant
sbstnp's Avatar
Australia, NSW, Sydney
Joined Jul 2012
The stock Mini motor has very strong magnets, so ratchety feeling is normal. If you go brushless, outrunners have the same behaviour.
sbstnp is offline Find More Posts by sbstnp
Old Feb 26, 2013, 05:19 PM
helicopter_new is offline
Find More Posts by helicopter_new
Austria
Joined Sep 2008
Crasy666 what flight times do you get with your brushless Mini in stunt mode?
helicopter_new is offline Find More Posts by helicopter_new
Old Feb 27, 2013, 12:32 AM
zadaw is offline
Find More Posts by zadaw
Hong Kong
Joined Jan 2010
I would just use the stock gear. The Mini CP motor is definitely more powerful but I was able to all the basic 3D and aerobatic stuff with the Genius motor.
I have to admit though that I could give a valid comparison between the Super CP and Mini CP board. The Mini CP board I used have been repaired 3 to 4 times. It flies a bit worse after each repair. My impression was that a new Mini CP is definitely more stable than mine.
zadaw is offline Find More Posts by zadaw
Old Feb 27, 2013, 01:50 AM
Crasy666 is offline
Crasy666's Avatar
Germany, BY, Nord
Joined Oct 2012
I can fly approx 4:50 min in stunt mode and recharge 300 mAh in a 350 mAh wk battery
Old Feb 27, 2013, 08:26 AM
BThirsk is offline
Find More Posts by BThirsk
Brent 黑雁
BThirsk's Avatar
Canada, AB, Ponoka
Joined Jan 2012
Try it with the stock gear and see how you like it as it gives more head speed. Make sure you have no gear cogging feel when doing the swap as any at all creates friction, which puts drag on the motor. The coreless motor needs a no friction environment to work properly. You still may have to lengthen the bolt holes to get the correct gear mesh, but all that is required is a drill bit the just fits the slots. You just spin it up at high speed and you can lengthen the slots to give more gear clearance, which you definitely need to do with the genius gear anyway.
BThirsk is offline Find More Posts by BThirsk
Old Feb 27, 2013, 08:39 AM
Austria
Joined Sep 2008
Crasy666 thank you for your feedback.
Has anyone tried the FBL100/V922 motor on Mini?
On the FBL100 this motor seems to be very powerful, gives good climb rate with no bogging and flight time of 4 minutes.
Old Feb 27, 2013, 10:40 AM
microrcfiend is offline
Find More Posts by microrcfiend
microrcfiend's Avatar
United Kingdom, England, Sheffield
Joined Jun 2012
Not yet but I have one on it's way to me. what did confuse me though was banggood sell both the fb10o motor and the v922 motor and use the same picture with slightly different brightness but are very different prices.
Are they the same product or is the more expensive fb100 motor different/better than the cheaper v922?
microrcfiend is offline Find More Posts by microrcfiend
Old Feb 27, 2013, 10:54 AM
Austria
Joined Sep 2008
Same product, different brand.
Old Feb 27, 2013, 10:56 AM
zadaw is offline
Hong Kong
Joined Jan 2010
I am a bit worried about having to change pinions if I use the V922 motor. I have used the Mini CP tail motor in the V922 and the tail would not hold at all.
Old Feb 27, 2013, 11:05 AM
Austria
Joined Sep 2008
It maybe happened because of the smaller size of Mini's tail motor, Mini has 6mm tail motor whereas FBL100 has 7mm tail motor.
Old Feb 27, 2013, 01:05 PM
i812 is offline
Find More Posts by i812
Mike for President
i812's Avatar
Joined Aug 2009
There should be at least (not less than) a hair's width (or two) air gap between Pinion and Main Gear all along the circumference of the Main Gear as it is rotated against the Pinion. The air gap can be adjusted by loosening both Motor mount screws (under the Main Frame) and repositioning the Motor further or closer to the Main Gear as required, then retighten both Motor mount Screws, and re-verify there's at least (not less than) a hair's width air gap between Pinion and Main Gear all along the circumference of the Main Gear as it is rotated against the Pinion.
i812 is offline Find More Posts by i812
Cool World Smallest Lightest Indestructible 3D helicopter :Genius CP!! DLY Micro Helis 9888 Jan 15, 2016 02:26 AM
Discussion Walkera Genius CP-the smallest 3d flybarless heli in the world! @ oomodel oomodel.com Hot Online Deals 17 Sep 28, 2015 11:48 AM
Careful! World Smallest Lightest Indestructible 3D helicopter Genius CP "More Junk" Iceblade1A Micro Helis 91 Sep 25, 2011 12:38 PM
For Sale Walkera 52 CP 3S MICRO heli(smaller than a Gaui)$75 DELIVERED Z06 Tony Aircraft - Electric - Helis (FS/W) 0 Aug 16, 2009 08:38 PM
Question Whatís Better than a Blade CP and Smaller than a Trex? HavingFun2002 Micro Helis 74 Mar 05, 2006 06:07 PM
