Or get some identical black blades from HK ($1.xx a pair) and stick colored film (I do it lately because became kind of difficult to source NE blades) on them. Or prismatic film. |
Folks, I have been hunting now for a few days to find a video or a detailed description of setting up the swatch plate and pitch for the Mini. I mean, setting it up all the way from the beginning. Here is my issue. One of my Mini's got banged up and the collar on the shaft moved thus pushing the main gear down. Now the swatch plate and the pitch are all over the place, the heli spins up but there is no lift so clearly it is the set-up ( I hope). I compared it with another of my Minis and the when I power up both of them, then looking at the links, the swatch plate and the pitch of the blades they are now totally different. So I need to start of at ground zero. And that is the step I can not find. Here is the question I can not find the answer to. What is the FIRST thing you do when you need to make these adjustments. For instance, should all the servo arms be up or down or half way or set by just letting the heli power up and put on a horizontal surface to let it " determine what horizontal means". and use that as the basis. Then, how do you set the swash plate ( is that using all 3 links or just the two on the back of the heli) what to look for, how to measure etc. And finally, when the swash plate is level, how to level the pitch. BTW I watched one of the video's that suggested that, if the pitch is out ( with level swash plate) you have to lower or raise the swash plate to get the blades level ( pitch ZERO I guess). SO then you are back to leveling the swash plate . How do you determine and how to you fix that issue ( order of things in which to approach the fix) . As you can see, lots of questions and no answers. And, BTW it does not help that the components on the Mini are SO TINY :-)
But it does not tell why I am doing what I am doing
. I am looking to get a process so I know - no matter what the heli's brand is, how to approach the set-up as I explained . So I found another video that may get me closer to the total process . In this tread - MinisTx Setup Guides for Walkera & Blade - Update Devo Tx/Rx/MC Firmware -Save/Load Models post 13 seems to tell me more Here is the link to the youtube video.
United Kingdom, England, Sheffield
Joined Jun 2012
I was pointed towards finless bobs video collection a few months back and although there are a bunch of flybar and nitro vids, the first few were golden for me.
http://www.helifreak.com/showthread.php?t=41692 They aren't the most exciting videos but he has a real clear style, very experienced |
Well folks, this video gave me the information I needed to figure out how to get the swash plate and the pitch set correctly. So If it works for me, it could work for other people to... I had the heli flying ( and crashing again) in 30 minutes. Must say, that canopy and the way it " rides up" after even the smallest of bumps is ridiculous. Of course is splits as soon as you look at it like a cheap date. This is just not well thought out at all. So I am now trying to re-enforce the canopy with tape ( just sticky tape from Staples for instance), and put a strip of that just in front of the landing gear cut-outs. Like a dogs muzzle if that give a better picture. I am thinking that is a better than just flying without the canopy to protect the PCB . |
Joined Jun 2012
Yeah man, I broke my canopy and skids before even getting outside.
People seem to use a bit of plastic stuck inside the front attached to the heli but I just used a single piece of sellotape stuck to the bottom of the canopy and along the base below the battery and over one of the 'rungs' before sticking back to itself. Never had it move in a crash and the board seems well protected if your canopy does not pop off. Changed stuff around once and forgot to use some tape and the first crash mashed up the canopy again, retaped and all is safe. My canopy is well beaten up but sellotape will keep it strong enough to protect your heli, just keep it moving so people can't see the frankensteinian repair job ![]() https://lh6.googleusercontent.com/-T...0/DSC00326.jpg https://picasaweb.google.com/1012182...CMqwqJ6pwPaRKA |
| Thread Tools | |
| Cool World Smallest Lightest Indestructible 3D helicopter :Genius CP!! | DLY | Micro Helis | 9679 | Yesterday 10:09 PM |
| Discussion Walkera Genius CP-the smallest 3d flybarless heli in the world! @ oomodel | oomodel.com | Hot Online Deals | 12 | Oct 16, 2011 08:52 PM |
| Careful! World Smallest Lightest Indestructible 3D helicopter Genius CP "More Junk" | Iceblade1A | Micro Helis | 91 | Sep 25, 2011 11:38 AM |
| For Sale Walkera 52 CP 3S MICRO heli(smaller than a Gaui)$75 DELIVERED | Z06 Tony | Aircraft - Electric - Helis (FS/W) | 0 | Aug 16, 2009 07:38 PM |
| Question What’s Better than a Blade CP and Smaller than a Trex? | HavingFun2002 | Micro Helis | 74 | Mar 05, 2006 05:07 PM |
