Old Jan 25, 2013, 06:11 PM
microrcfiend is offline
Find More Posts by microrcfiend
microrcfiend's Avatar
United Kingdom, England, Sheffield
Joined Jun 2012
I got 39.8g on mine no battery.
Anyone used the bigger tail motor/steel boom combo?
http://www.chinesejade.com/images/wa...Combo_tail.jpg
microrcfiend is offline Find More Posts by microrcfiend
Old Jan 25, 2013, 11:43 PM
sbstnp is offline
Find More Posts by sbstnp
Deviant
sbstnp's Avatar
Australia, NSW
Joined Jul 2012
That's the FBL100 tail. Can be had from HK for a few $.
http://www.hobbyking.com/hobbyking/s...100_Parts.html
I'm using that on mine and it's perfectly fine. Once I have the time will check it with the 14000kv motor from HK too and see if it holds.
sbstnp is offline Find More Posts by sbstnp
Old Jan 26, 2013, 07:38 AM
BThirsk is offline
Find More Posts by BThirsk
Brent 黑雁
BThirsk's Avatar
Canada, AB, Ponoka
Joined Jan 2012
Originally Posted by helicopter_new View Post
What is the weight of your Mini CP?
Mine is 38gm, 42gm with stock battey and 44gm with 350mah battery. This is with the Coreless motor which is over 2gm lighter than the stock motor.
The SuperCP is 42gm with stock battery.
BThirsk is offline Find More Posts by BThirsk
Old Jan 26, 2013, 08:25 AM
helicopter_new is offline
Find More Posts by helicopter_new
Austria
Joined Sep 2008
Mine is 35.5g with a coreless motor. Also I've removed the temperature sensor which I think it is useless and I've installed some tape on the canopy to reinforce it.
With stock battery it weighs 43.5g.
Mine Walkera and nanotech batteries weigh almost 8g.
helicopter_new is offline Find More Posts by helicopter_new
Old Jan 26, 2013, 09:26 AM
Joined Jun 2012
Thanks for the heads up, that's even cheaper than chinesejade, good call.
Old Jan 30, 2013, 03:05 AM
quacka is offline
Find More Posts by quacka
Originally Posted by quacka View Post
Thanks for the tip.
With the Genius motor in place and the rotor spins quite freely. I still get 2:30 flight time off a 300mah. I guess this part should be ok.
Anything else you can think off that can interfere with the flight time?
I got 10 new nano-tech 300mah batteries off HK today. Charged them in my Swallow EQ and gave it a test flight with the Genius motor.
Went to over 5 minutes run time which is impressive. At the end of it all, plugged the lipo into the cell meter and it still indicate 3.9v. This is the original voltage the battery came with before i charged it
quacka is offline Find More Posts by quacka
Old Jan 30, 2013, 03:34 AM
PurpleShark is offline
Find More Posts by PurpleShark
...if you take the time
Israel, Tel Aviv
Joined Jul 2012
Are you using telemetry? How low did you run them?
PurpleShark is offline Find More Posts by PurpleShark
Old Jan 30, 2013, 03:37 AM
OiOi is offline
Find More Posts by OiOi
Joined Apr 2009
@Quacka:
At what head speed did you run?
Would be interesting how much mAH you could again charge into the battery after the run.
OiOi is offline Find More Posts by OiOi
Old Jan 30, 2013, 03:55 AM
sbstnp is offline
Deviant
sbstnp's Avatar
Australia, NSW
Joined Jul 2012
Telemetry does not affect flight times.
Old Jan 30, 2013, 05:55 AM
Israel, Tel Aviv
Joined Jul 2012
Asked that to undestand how low he ran the battery. Let me rephrase -
Have you set a elemetry alarm? or are you running until it won't lift anymore...
Old Jan 30, 2013, 06:42 AM
quacka is offline
Originally Posted by OiOi View Post
@Quacka:
I run Deviantx on my devo8s and turned my teleoff in the ini file. I just got a devo6 with the stock firmware. might try this to see if there is a diff.
No idea how to checkw hat head speed I am running. Can you show me?
Old Jan 30, 2013, 10:27 AM
BThirsk is offline
Brent 黑雁
BThirsk's Avatar
Canada, AB, Ponoka
Joined Jan 2012
Do you have to swap the wires in the plug on that one to fit the mini. It looks the the plus and minus are on opposite sides.
Old Jan 30, 2013, 02:35 PM
quacka is offline
Yes I do. Its quick as you just use a small head device such as a philips screw driver and press in the hole and it pops out.
Old Jan 30, 2013, 02:38 PM
quacka is offline
I fly until it wont lift any more.
Old Feb 02, 2013, 09:43 AM
OiOi is offline
Joined Apr 2009
Wow, had recently bought another heli from RC711 (intended to be upgraded with a HK 14000kv motor). Today was the first day to fly the little thing (before it was all bad weather...).
Put that thing in the air, but it somehow lacked power, then after about 30 seconds, there was smoke coming out of the canopy. As i saw in there from the side, I saw that something was glowing red hot just in front of the servos.
Then it dropped to the ground.
First I thought there was a short at some servo-leads. But boy was I wrong. It was the servo itself. One servo PCB got so red glowing hot, that it melted a hole into the plastic encasing...WOW...
Anyone of you ever experienced this?
The funny thing is, that 'til the end the servo was still working...LOL
Cool World Smallest Lightest Indestructible 3D helicopter :Genius CP!! DLY Micro Helis 9888 Jan 15, 2016 01:26 AM
Discussion Walkera Genius CP-the smallest 3d flybarless heli in the world! @ oomodel oomodel.com Hot Online Deals 17 Sep 28, 2015 10:48 AM
Careful! World Smallest Lightest Indestructible 3D helicopter Genius CP "More Junk" Iceblade1A Micro Helis 91 Sep 25, 2011 11:38 AM
For Sale Walkera 52 CP 3S MICRO heli(smaller than a Gaui)$75 DELIVERED Z06 Tony Aircraft - Electric - Helis (FS/W) 0 Aug 16, 2009 07:38 PM
Question Whatís Better than a Blade CP and Smaller than a Trex? HavingFun2002 Micro Helis 74 Mar 05, 2006 05:07 PM
