Old Jan 19, 2013, 10:57 AM
pmerritt is online now
Find More Posts by pmerritt
Joined Oct 2010
Originally Posted by sbstnp View Post
It will be a problem when Walkera decides to phase out this little bird in 6 months or so. If they won't use the same servos on the successor most will be SOL in a year or two.
So it has downsides.
with Walkera there's no telling what will happen. The new servos are a step in the right direction if you ask me though. now you can just buy a bunch of low priced servos to swap out. no turning tiny gears or sore pockets from buying servos.
pmerritt is online now Find More Posts by pmerritt
Old Jan 19, 2013, 11:07 AM
thomasprevere is offline
Find More Posts by thomasprevere
Greece, Attica, Nea Ionia
Joined Feb 2011
10a esc oversky for mcpx
Hi,my friend solder the signal wire on the minis rx at the 1 pin,like the photo describes ,but now when i start the throttle its reversed,when i have throttle on top the esc stops and when i get down starts reverse the throttle on tx works ok but only the main motor the tail motor is still reverse!
i have to reverse the input polarity with the usb?
What is the polarity negative or positive at the settings ? i have it on negative on walkera oversky 10a,and the same at this oversky for mcpx, is this the problem?
it needs positive ?or something else its wrong?
thomasprevere is offline Find More Posts by thomasprevere
Old Jan 19, 2013, 11:13 AM
OiOi is offline
Find More Posts by OiOi
Joined Apr 2009
Just a short question: Where are the "dumb" servos available for $4?
OiOi is offline Find More Posts by OiOi
Old Jan 19, 2013, 12:06 PM
Joined Feb 2011
I think that i answer my own question
http://www.helifreak.com/showthread.php?p=4416003
12. PWM input signal is like PWM output mentioned in 10 in terms of modulation for throttling but this setting is for input signal. The amount of throttle sent to brushed motor is determined by how long full power pulses are sent as opposed to how long zero power pulses are sent. Most ESCs run neg-ground which means pos voltage refers to ON. Some ESCs run pos-ground which means zero voltage refers to ON. If you have this setting wrong, zero throttle will be interpreted as 100% throttle and vice verse and everything in between. It won't kill the ESC.
Old Jan 19, 2013, 12:28 PM
sbstnp is offline
Find More Posts by sbstnp
Deviant
sbstnp's Avatar
Australia, NSW
Joined Jul 2012
If you solder on the back:
1. Set ESC PWM polarity to positive, signal tapped on the back IS POSITIVE.
2. Keep THR channel normal, not reverser.
Tail has nothing to do with THR channel if you use the stock tail setup, that is controller by the gyro.
You should read the whole thread on HF, the one started by me, because at the time I had probably the same issues as you.
sbstnp is offline Find More Posts by sbstnp
Old Jan 19, 2013, 12:43 PM
Joined Feb 2011
Thanks, i understand it now, i will reverse polarity to positive and the oversky 10a for mcpx ,will be run properly on mini!!!
Old Jan 19, 2013, 12:44 PM
Crasy666 is offline
Find More Posts by Crasy666
Crasy666's Avatar
Germany, BY, Nord
Joined Oct 2012
Hallo OiOi
Sorry Not 4$ maybe some Cent more you get it for 3,69Ä so approx 4,50$ at http://www.rcmaster.de/de-servo-wk-0...10-p232948.htm don't get confused by the Domain .de it is a Dealer from China, but we have got experience with them, Even fast answers and Shipping costs are fair, Pendant if you want express or cheap w longer Time.
Rgds
Wolfgang
Edition Thema Link is not working note as plain text to copy it in the browser
http://www.rcmaster.de/de-servo-wk-02-5-f%c3%bcr-walkera-super-cp-hm-super-fp-z-10-p232948.htm
Crasy666 is offline Find More Posts by Crasy666
Old Jan 19, 2013, 05:13 PM
Crash Survivor is offline
Find More Posts by Crash Survivor
Heli Crash Survivor
Crash Survivor's Avatar
United States, AR, North Little Rock
Joined Feb 2011
Just tested the 14'000kv Hobby King motor. It’s hotter than the HP05S, but was disappointed, because I was looking for longer flight times. At a flat 95% TC I could get a little over 3 minutes on the HP05S but had to lower to 85% on the 14'000kv Hobby King motor to get a little over. But even at 85% it doesn’t bog until after a little over 3 minutes. I’m using the 350ma FULLRIVER batteries that are stock for the V100D08 & a 8T pinion on both motors. It's one sweet little motor very powerful.
http://www.hobbyking.com/hobbyking/s...dProduct=25435
Crash Survivor is offline Find More Posts by Crash Survivor
Old Jan 21, 2013, 11:55 AM
Joined Feb 2011
Mini cp with oversky 10a esc mcpx solder on pin 1 like photo describes works just fine!!!!
I am very happy with my mini!!!
Old Jan 21, 2013, 03:17 PM
lent57 is offline
Find More Posts by lent57
Joined May 2012
HK 10a esc
I taped pin 2 on mini cp rx and it bricked it?
lent57 is offline Find More Posts by lent57
Old Jan 21, 2013, 03:21 PM
sbstnp is offline
Deviant
sbstnp's Avatar
Australia, NSW
Joined Jul 2012
No reason to, unless you shorted it out or overheated some other component.
Post a clear close up picture?
Old Jan 22, 2013, 03:00 AM
quacka is offline
Find More Posts by quacka
Ok
After buying a secondhand mini cp and see the battery doesn't last long during flight. I decided to take some people advise and resolder the battery terminal. It still doesn;t last long in flights. Around 1 min to 1:30.
I now take a fresh battery from my new quad copter which flies well over 6 minutes to test. It is rated at 300mah and it still only last 50 seconds only. The heli cannot even lifted off any more. I put this on my new battery tester, it stats it is at 3.9v. You guys think the main board is stuffed?
I just replaced the tail boom and got a spare genius cp motor and main gear here. Should I try it?
I just bought a Genius v1 cheap, should be coming in the next few days. I can try the battery from that to see the flight time difference.
quacka is offline Find More Posts by quacka
Old Jan 22, 2013, 03:41 AM
quacka is offline
Just tried the Genius motor. Even worse, the heli dont even lift and the telmentry went from 4.0v to 3.5v almost immediately.
Old Jan 22, 2013, 07:06 AM
BThirsk is offline
Find More Posts by BThirsk
Brent 黑雁
BThirsk's Avatar
Canada, AB, Ponoka
Joined Jan 2012
With the motor off, if you spin the main rotor, does it spin freely with no friction. It should spin many times if you give it a good flick. When the motor it install any you turn the main gear, check for drag cashed by improper gear mesh. If the main and pinion are too tight, it will create excessive friction. You need a little play between the 2 gears. Check at many points around the main gear as they are not always perfectly round.
The genius motor will not start as easily as the mini because it is a careless motor and the friction problem would be worse with it.
BThirsk is offline Find More Posts by BThirsk
Old Jan 22, 2013, 02:59 PM
quacka is offline
Thanks for the advice. I managed to get the genius motor off the ground now and fly smoothly but the fly time is only 2:30 with just basic hovering. At the end of the flight I check the voltage on the Nano tech 300mah, it is 3.9v. I put the same battery on my mini pet quad heli. It flies fine doing flips and stuff. I have tried ordering some new battery connector for the rx board and resolder it to see if this is the problem.
Even with the motor off and I am spinning the pinion, the Genius motor spins very smooth and the Mini CP motor clicks around. No idea if this motor has any problem but I guess 2min runtime on the mini motor and 2:30 on the genius seems about right?
I cannot get the Mini CP motor to spin the rotor even one revolution freely. The Genius motor I can.
Cool World Smallest Lightest Indestructible 3D helicopter :Genius CP!! DLY Micro Helis 9889 May 18, 2016 12:17 PM
Discussion Walkera Genius CP-the smallest 3d flybarless heli in the world! @ oomodel oomodel.com Hot Online Deals 17 Sep 28, 2015 10:48 AM
Careful! World Smallest Lightest Indestructible 3D helicopter Genius CP "More Junk" Iceblade1A Micro Helis 91 Sep 25, 2011 11:38 AM
For Sale Walkera 52 CP 3S MICRO heli(smaller than a Gaui)$75 DELIVERED Z06 Tony Aircraft - Electric - Helis (FS/W) 0 Aug 16, 2009 07:38 PM
Question Whatís Better than a Blade CP and Smaller than a Trex? HavingFun2002 Micro Helis 74 Mar 05, 2006 05:07 PM
